Maybe build the Punisher 2’s???
Category: Plans
Forum Name: Punisher and X-tro
Forum Description: Discussion / Questions about the Punisher and X-tro
URL: https://forum.speakerplans.com/forum_posts.asp?TID=2064
Printed Date: 26 March 2026 at 10:56pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Maybe build the Punisher 2’s???
Posted By: Tom Umney
Subject: Maybe build the Punisher 2’s???
Date Posted: 17 June 2005 at 10:04pm
The 15 inch scoop I bought from mans1000 is extremelly heavy and thats unloaded too. Probably cos its made of 22mm MDF. And even the help of my strong friend we couldn't lift it up the stairs.
So will have to keep that in the garage and only use that for events on the ground floor.
So I guess the Punisher 2 is more compact and less heavy than a 15 inch scoop, if I build a Punisher out of 15mm birch ply???
But hopefully 2x Punishers 2's stacked together and used in events I do on the 2nd floor with max 100 ppl will be sufficent?? [mostly reggae,dub or dnb is played].
I would use the suggested Ciare driver and power it with either a bridged rmx2450 each punisher 2 bin[giving it 1500w rms each], or get a rmx1850hd and then [two in bridge,900w rms each driver] or rmx4050hd [two punisher 2 bin's in bridge] but 2000w rms to each driver might f**k it.
But how difficult is it to build the punisher 2??? And how heavy would it be with the Ciare driver in it, if I make it out of 15mm birch ply???
Cost is not a problem this time as the Ciare drivers is only £99 each. So could afford to spend more on 15mm or 18mm birch ply.
Posted By: rastaman
Date Posted: 17 June 2005 at 11:31pm
It's a how long is a piece of string question innit?
The punisher certainly looks more complicated than a scoop, which is
more complicated than an X1 which is more complicated than a closed
box. Have you ever built a box? You seem to talk about buying or having
them made for you a lot, so I figure your a box building newb like my
good self.
Speaking of which I was out looking at table saws today, my local store
has a small one for $87 so that maybe the way to go. I can swivel the
blade on it and everything.
http://www.protechpower.com/pages/41064.pdf">
Please all critcise it now, before I buy it.
I'm thinking of skipping the shallow end, and jumping in the middle of
the pool by building some scoops to start with, hey with a handle like
rastaman, what do you expect
Then after a slew of scoops I will progress towards the deep end, with
some folded horns, like looneys, or punishers, or LABhorns depending
what fits in best, maybe one of Roborgs http://roborg.freefronthost.com/plans.htm - infrabass beasties.
So Toxic is the Punisher more like half a LAB or a cut down looney bin?
At tb_mikes advice I've been reading through the LAB history, and they
talk at one point about a halfLAB, though it sounds like it's kind of a
one hand clapping deal, where you need the other halfLAB to get
anywhere, wheras Punisher people say that even one a side produces some
nice sounds.
Anyone in the Midwest who wants to show of their horn in me barnyard,
get in touch I have the luxury of no close neighbours, we could run
experiments on how corn responds to sub-bass (or after reading the
Holliman stuff, infrabass)
Date Posted: 18 June 2005 at 3:59am
Ahhhhhhhh! so thats how crop-circles are made! CORN + HEAVY BASS = FLATTENING.
------------- Be seeing you.
Date Posted: 18 June 2005 at 4:06am
| errrrrrrr....a daft question,but were u planning to use it in your bedroom?.....i can see a new topic coming on....."ultimate bedroom Hi-fi".......or."how many bass cabs can i fit in a room and still leave room for a bed" or....."No Mum,im sure the ceiling wont collapse under the weight,i have positioned it all carefully......."
Posted By: Timber_MG
Date Posted: 18 June 2005 at 4:13am
A punisher and a scoop are different animals completely. The punishers
would pull the pants off the scoop output-wise. When stacked huugely
the scoops might go a little lower, but as to the rest....
Two punishers should be more than enough for 100 peeps (actually, one
should be enough). Two mid-tops like the X12 would be a simple addition
or if you want it really simple but a little bigger X15s.
Date Posted: 18 June 2005 at 9:17am
Ok one Punisher 2 then!!!
And although my woodworking skills are pretty crap,my m8 offered to help me build it[as his job is a carpenter].
So if I use the pair of RCF ART 500's and pair of Behringer B1520's too[modified with Eminence Delta Pro 15's now] with 1x Punisher 2, I don't want the Punisher 2 to over power the mid/tops or the mid/tops to over power the Punisher 2. What I mean by that is don't wanna hear just bass or don't wanna hear just a lot of mid/highs.
Date Posted: 18 June 2005 at 9:26am
So apart from the driver and wood and bits and pieces like screws are there any special things the Punisher 2 has???
I know the Labsub has special metal access covers, not sure if Punisher 2 has that? Or just a normal wooden access panel.
Also what adhesive and what sealent are used to make the Punisher2??
Posted By: Lyndon A
Date Posted: 18 June 2005 at 12:31pm
Punisher is about 45kg I think. Access cover is just 15mm birch ply. I think our carpenter is going to caulk (spelling?) the joints. Just make sure the sealed section is a very good air tight seal.
Get the 2005 driver with 8 bits on the spider. We're buildng one now and trying it out as an idea as to what it can do but chances are we will stick with them.
Date Posted: 18 June 2005 at 12:56pm
Someone told me to make the whole punisher 2 out of 15mm birch ply as its much lighter than making it out of 18mm birch ply.
Will poly filler give a good enough air tight seal??
Date Posted: 18 June 2005 at 1:02pm
Oh and does the Punisher double as a sub bass bin and a kick bin in one???
I mean would I be able to get from 45hz-200hz out of it??
Posted By: whitehousejamie
Date Posted: 18 June 2005 at 1:58pm
Wouldn't you be better off building a pair of 18in reflex cabinets?
They would work easily down to 40hz, and upto 200hz like you want, and would be lightweight and much cheaper / easier to build.
Or you could buy a couple of Basys B15 subs
Date Posted: 18 June 2005 at 3:09pm
Had 18 inch reflex cabs before, hated them and got rid of them.
Cost is not a problem as the Punisher driver is only £99, and 15mm birch ply for 1 Punisher won't cost more than £100. My m8 is a carpenter and is willing to help so even if its complex to build,with his help I'll get them done. And as long as two people can lift the punisher its not too heavy.
Just wanna make sure 1x Punisher covers the range 50hz-200hz.
Date Posted: 18 June 2005 at 3:24pm
@ Jamie: you need a very, very clever 18" Bass-Reflex to get to a
listenable result crossed that high. It can be done, but it is very
rare to see it done.
The Punisher will make it that high, but it is recommended to cross it
below 130Hz if you can. However if the sound of scoops doesn't phase
(warning: pun) you used that high, neither would that of the punishers.
Posted By: Contour
Date Posted: 18 June 2005 at 6:17pm
Hello,
The Punisher sounds best when crossed low (90-130hz) this is the same for almost every folded horn I know of. Crossing them low also gives you the advantage that all the power (1500W on a single Punisher can be seen as optimal) is in the real bass range so that way the cabinet moves most air.
Punisher is build out of 15mm birch ply. But it uses 4 reinforcement panels so it is quite a strong cab. The 15mm wood gives you a low weight which is favorable with transport. If you are planning to build them for an install job you can use 18mm for the outer panels.
Best regards,
Walt
Posted By: james folkes
Date Posted: 21 June 2005 at 3:38am
walt, although 1500 W is the recommended power for these boxes i don't
currently own anything that'll do that without resorting to bridged mode.
what is the bare minimum you have to use to get the driver to 'wake up'? i
know the ciare is of the 'low sensitivity-high power handling' school of
driver construction, have you ever tried them on something a little less
powerful, or is this missing the point of this cab.
james.
Posted By: Contour
Date Posted: 21 June 2005 at 5:02am
Hello,
We have run the Punisher for cheaper low wattage amps. This will work but won't let the Ciare stretch its legs. I think 800W RMS is minimum.
Best regards,
Walt
Date Posted: 21 June 2005 at 7:38am
hmm. i kind of figured this was the case. i shall be keeping my eyes open
for something which will make them sing as there isn't really any point
building them and never powering them properly. like 1850 horns, these
boxes are only for people who can afford big amps. an infinite 8
would just about do the trick at 1300 W into 8 ? and 2400 W into 4 ?.
and it's over a grand... boo-hoo!
such a tempting cab though with its inexpensive driver, compact size, low
weight and huge output and i've heard encouraging noises about
using 1 a side. hmm, just a thought but can you get the ciare (or similar)
in a 4 ? version? i could easily give it 725 w then, which is getting on for
useful.
james.
edit: footnote. curses, all those question marks were neat little omega
symbols, i was feeling very smug for remembering the shortcut key too.
Posted By: Contour
Date Posted: 21 June 2005 at 10:09am
Hello,
Here in Holland we get both 4 ohm and 8 ohm Ciare 12.00SW for the same price. I think you have to talk to your Ciare supplier.
Best regards,
Walt
Posted By: rastaman
Date Posted: 21 June 2005 at 11:13am
| I'll say the horrible word Behringer
I think you just missed norty selling one.
Dom said he's still waiting for his to break down, as I recall.
Posted By: Lyndon A
Date Posted: 21 June 2005 at 11:23am
I think we might just use our two old amps in bridge mode which will maximise our amps (only 8ohm bridge stable) but provide a nice 1400w RMS. Get two punishers and thats 2800w RMS total. Hopefully that'll be louder+deeper than our current mess of 18" Bass Reflexs (totaling 1600w RMS)
Posted By: norty303
Date Posted: 21 June 2005 at 11:31am
Dom said he's still waiting for his to break down, as I recall. |
Thats where mine went actually, going into the club with the other one.
My T.amp will do 1400w @ 8R bridge....
------------- My laser stuff: http://www.facebook.com/SubsonicSystems" rel="nofollow - Frikkin Lasers
Posted By: rastaman
Date Posted: 21 June 2005 at 2:43pm
Why haven't I seen that on Behringer's website then?
As used by Dom, god of the HD15
At least it's one reliable report with positive thinsg to say.
Date Posted: 21 June 2005 at 4:33pm
i'm scared of bridge mode. should i be?
james.
Posted By: rastaman
Date Posted: 21 June 2005 at 4:52pm
I don't think so. Most amps will take it.
I seem to recall an external bridging device in one of the popular
electronics magazines in the UK during the 80's, made some outrageous
claim along the lines of 1 bridging device plus two 100W amps gave you
1000W or some such, they had the circuit for the bridge and amps. I
remember being very impressed at that young age until of course reality
said it was impossible.
I'd be wary of putting too low an impedance on a bridged amp. Then
again some of todays amps will drive in bridge down to an ohm or so I
believe (don't own any myself).
Date Posted: 21 June 2005 at 8:17pm
using 4 ohm drivers, you could give a pair of cabs 1200 W each for £250
with a ta-2400. powered, you'd have change from £600 for all materials
with not a bridged amp in sight.
but then you'd have 4 ohm cabs, which later on might annoy. dunno.
pretty hypothetical at present.
james.
Posted By: rastaman
Date Posted: 21 June 2005 at 8:49pm
Do Neutrik Speakon's allow you to do socket switching?
What I mean is, if you build 4 ohm cabs and you use 1/4" jacks you can
just have an input, and two outputs, one is a parallel out, the other
interrupts the path of the -ve from the driver and allows you to link
another cab in, in series. So you're two 4 ohm cabs that present an 8
ohm load, you then use the parallel out to connect to another two cabs also
wired similarly so you have 4 cabs presenting a 4 ohm load, and all
sharing the power evenly.
Of course you could just parallel it with one real 8 ohm cab, but then the 8 ohm cab gets twice the power of the 4 ohms.
Care must be taken when wiring the series jack to get the -ve signal
feeding out on tip, and back on ring to keep the other series speaker
in phase, also the parallel out must be wired across both speakers when
the series jack is being used but apart from that it's pretty simple.
If I had MATLAB or
something, I'd sketch you a circuit.
Posted By: tb_mike
Date Posted: 21 June 2005 at 9:12pm
the angst with bridging,is probably based on two things
1)manufacturers inflated claims that dont work for low impedence dip drivers under 8hrs of stress at a real gig
2)You must remember that when bridge - each amplifer effectively sees half of the load resistance.Odd concept but its true. So bridging is effective for the higher loads while paralleling for the low loads. But theres always a limit.Im suprised we do as well as we do.
Mike
Posted By: rastaman
Date Posted: 21 June 2005 at 9:21pm
Hang on, are you saying what I think your saying or the opposite?
Each channel see's a half of the total load resistance, ie. in a 4 ohm
load, #1 sees 2 ohms, and #2 sees 2 ohms? That's to be expected, your
connecting between the two positives? Or are you saying the other, in
which case I'm baffled and surprised.
The other thing to remember is, as you lower the load, the losses in
cables connectors etc. become more noticeable, or I should say more
significant, leading to the troubles of warm cables, connectors etc.
That cheap ass piece of 20 gauge you used to hook up one driver starts
factoring in, that piece of solder you wound round another driver and
terminal, as you didn't have any wire (I have seen this done, it scared
me), heats up too.
If you run a low impedance load 2ohms especially but even 4 ohms, make
sure all your interconnects are high quality, and clean. If someone
drops a cable end in the mud, clean it up before you bung it in.
Sorry, rant over.
Date Posted: 22 June 2005 at 3:36am
i know these things about bridging (especially about each channel seeing
half the load resistance, self explanatory really) and it lurks at the back of
my mind as something for driving big 8 ohm loads with. it is a heavy but
innexpensive (ish) way of powering adult cabs, consider that 4 x ta-1400
or even 4 x ep-2500 would power a few cabs in anger and still come in at
significantly less than any of the big boys out there. 8 ohm loads all
round of course.
regarding series/ paralell wiring, i came up with areally trick way of doing
it with four pole speakons but you need to make up some special leads to
do it. with 2 sockets per cab you can have any combination of series and
parallel, but i gave up in the end as it just seemed unneccesary. two 4
ohm loads in series and you are back to 8 ohms but with the biggest
power rating ever, this really wouldn't help.
hey ho. james.
Posted By: Hyb^
Date Posted: 22 June 2005 at 3:54pm
boxes are only for people who can afford [I]big[/I] amps. an infinite 8
weight and huge output [I]and[/I] i've heard encouraging noises about
useful. |
Indeed, the "Cool, but now WTF do we drive them with?" question arises.
We conluded that no amp would power them sufficiently by themselves and not drop below 4ohm, while pairs of amps to do the required job is just more spendy.
We resigned to spending more in the end.
Alex @ PAP can get hold of the 4ohm versions for the same price but with a little lead time, I recall. Which would give you some more of the grunt power - but obviously with the high impedance tradeoff.
HTH,
Date Posted: 22 June 2005 at 8:47pm
ah, just the person! i have just been corresponding with loophole (is that
the right verb for the act of a correspondance? doesn't look right...) about
punishers who said you were one of the people to talk to about real world
experiences.
you elected getting two big amps to drive all four of yours then, what
have you gone for in the end? i'd really like to know what you've got away
with and what you thought got the sweetest balance, i'm sure they must
bark a teensy bit (or should i say itsy bit) with 1500W.
i'd love to know if you've tried doing owt with one a side also, the 4 ohm
version makes a bit more sense then. whilst i kind of shudder at the
thought of 2 ohm loads i feel i've wasted carrying stuff if i'm not running
at 4. at low frequencies will a 4 ohm driver in fact drop down in
impedance to around 2 or have i got confusled again. the high impedance
trade off i presume implies that an amp can control a signal into a higher
resistive load better than into a lower one.
james.
Date Posted: 22 June 2005 at 9:33pm
What I mean is, if you build 4 ohm cabs and you use 1/4" jacks you can just have an input, and two outputs, one is a parallel out, the other interrupts the path of the -ve from the driver and allows you to link another cab in, in series. So you're two 4 ohm cabs that present an 8 ohm load, you then use the parallel out to connect to another two cabs also wired similarly so you have 4 cabs presenting a 4 ohm load, and all sharing the power evenly.
Care must be taken when wiring the series jack to get the -ve signal feeding out on tip, and back on ring to keep the other series speaker in phase, also the parallel out must be wired across both speakers when the series jack is being used but apart from that it's pretty simple. If I had MATLAB or something, I'd sketch you a circuit.
LOL don't ever use 1/4 inch jacks as they can't carry high powers and the sound quality is crap using them.
XLR or speakon instead!!!
Posted By: rastaman
Date Posted: 22 June 2005 at 9:48pm
ToXiC wrote:
LOL <blah> crap <blah>.
<blah>!!! |
I knew it, I just knew it.
As soon as I mention old skool (or is it olde world)
technology, some young buck, still in short trousers, comes latching
onto the wrong end of the stick like a rabid yorkie in a field of
lamposts.
Note: I asked about
Speakons, as I know that 1/4" are not suitable for high power speaker
connections, however I also know that the only other common
alternative, the Cannon or XLR is not capable of having a switched
socket (at least in any configuration I have known). Hence me asking
about Speakons.
<insert rant about the good old days here>
NB the switching capability of the 1/4" jack allows for many useful
functions. That's why the sound stops coming through your speakers,
when you plug headphones into a receiver. Thats how my active bass know
to turn the preamp on when I insert the jack. Thats how a guitar
effects pedal knows to turn on or off to save the battery. Thats also
how some of my other speaker cabs know whether they are running in mono
or stereo, parallel or series, or one speaker or two.
Seems like Neutrik missed a bit when they designed the Speakon, special cables pfft!
(who trusts anyone except themselves to know how and where to use a special cable?)
Date Posted: 22 June 2005 at 11:16pm
Yes I know 1/4 inch jacks were used ages ago in the until the late 80's. But the 1/4 inch jacks were only used on guitar cabs or crappy disco speakers.As i've seen some pretty old pa speakers[Martin Audio CX2 co-axials] that were around 20 years old and had XLR's on them.
Because Speakons have only been around for the last 15 years or so I think.
Posted By: LunchieTey
Date Posted: 23 June 2005 at 12:16am
up until 5 years ago or even less,many big name companies still didn't use anything but 1/4 plugs. They can handle quite a bit of pwer(theres still plenty of metal in QUALITY plugs-sometimes more than speakons)
As far as sound quality goes-no one can pick the difference. They are only popular now because of 2-4-8 pole models,can't short them,good contact. They can handle 30a current too but a 1/4 plug can handle almost as much unless you actually use a cheap 50c headphone model.
Before speakons came out,that's what was used and there was definately plenty of power running thru them
You know what really sounds crap? Clipping amps and overdriven bass drivers in cheap full-range cabs...
------------- Speaker addict
Date Posted: 23 June 2005 at 8:58am
Sorry but thats just utter bullsh*t.
XLR's were used on big name companies before Speakons.
I lot of the Martin Audio,Turbosound and Court Acoustics pro gear used XLR's because I've seen soundsystems using them old boxes of those makes.And I've actually had a few of the old boxes from Court and Martin Audio and know they do NOT use 1/4 inch jacks.
Yes and the sound quality is crap, all the power coming through a tiny point, and no they can't handle much power.
http://colomar.com/Shavano/speaker_wiring.html - http://colomar.com/Shavano/speaker_wiring.html
1/4 inch jacks are only ok for signal not speaker.Except they pull out easier , so locking Cannon XLR for signal is the best!
Posted By: norty303
Date Posted: 23 June 2005 at 9:06am
You really devalue the quality of your posts by the fact that you come across as a complete arse Toxic. If you, for once, could enter into a debate without swearing, being derogatory or using the smilie then people 'might' pay some attention. As it is you're just here for entertainment value.
Posted By: rastaman
Date Posted: 23 June 2005 at 9:40am
OK, didn't mean to start a war here, but you can settle this fairly easily.
Can we all agree that Switchcraft are a fairly reputable brand, if not the brand for 1/4" jacks?
Just look at their specsheets.
http://switchcraft.com/products/jack-133b.html - Heavy Duty 1/4" Jack Plug
http://switchcraft.com/products/jack-133a.html - Loudspeaker 1/4" Jack Plug
http://switchcraft.com/products/jack-101.html - Speaker Jack Socket
All of these are rated at 15A continuous (RMS), now 15A into an 8 ohm
load is 1800W which is enough for a lot of drivers. The Heavy Duty jack
can take up to a 12 gauge cable again more than sufficient for a lot of
uses.
An average Speakon (NL2 and NL4) can also accomodate 12 gauge cable, and can handle up to 30A continuous.
NB XLR's can also handle a max of 15A (16A on Neutrik HD).
So yes Toxic yours is bigger, but are you ever going to be able to use it all?
PS I am not now, nor ever have been an advocate of 1/4" please read
posts before replying, it saves on the egg on the face
Posted By: Carl-
Date Posted: 23 June 2005 at 9:49am
Maybe Toxic is not saying it in the utmost friendly way, but he is 100% right, Jacks are no good for speaker applications.
There is enough metal in the good types, but the point where the current goes from cable part to amp- or speaker part is nothing more than that: a point! from the round tip to the flat contact of the chassispart. You can wire your connector with 4 qmm cable, the contact area is maybe only 0,1 qmm.
Don't worry, be happy! (and use speakons, that do not exist with switches afaik)
------------- People who think they know everything are annoying to us who really do.
Date Posted: 23 June 2005 at 9:52am
damn it man, you can't buy entertainment like this....
the thing i'm particularly into about speakons is that they terminate with
screw terminals, i hate soldering speaker cables. that said, i have a proper
seal clubbing soldering iron (apparently it's for tin or something) which is
substantial enough to join 4mm cable to chassis connectors with ease. i
think you can get chassis connectors with screws too, but they are a tad
pricey.
anyway. punisher 2 people?
james.
Date Posted: 23 June 2005 at 10:48am
Entertainment lol , no it's the truth.
If 1/4 inch jacks were so great everyone would be using them, but nothing nowadays[except extremelly sub budget speakers like Kam use them] doesn't that tell you something.
Yes in the 60's, and 70's technology wasn't as good as it was now so they used 1/4 inch jacks, then by the 80's pro speaker companies used XLR's, and then Speakons by the 90's.
The ONLY benefit of a 1/4 inch is it comes out if someone trips over it, preventing the cable being ripped out of the plug.
But because of poor contact,degraded sound quality and can't carry high powers and comes out easily, they are not used anymore except on very budget - sub budget crappy speakers like Kam.
Posted By: rastaman
Date Posted: 23 June 2005 at 11:16am
Good Lord, it's threads like this that make me see why Rog went to Tibet.
The benefit of 1/4" jacks, is they allow you to do nifty things with
switching jacks. As I am aware 1/4" is not de rigeur for speakers, I
asked, do Speakon jacks have a similar capability. One person, who has
the attention span and ability to read an entire post managed to answer
the question I asked. Toxic, I'm afraid to say it wasn't you.
It's like stopping someone on the street and saying:
Excuse me, could you direct me to the cinema, I have to meet my wife at the cafe next door to it?
to which they reply:
Nah mate, you don't want to go to the cinema, cinemas are crap.
Nuffin but sh*t on in them, you want to go to the AV store mate, by
yourself a nice DVD system, surround sound, nice big subwoofer, rent
yourself some good movies mate. Some Chuck Norris or Arnold
Schwarzenegger, yer, thats what you want. I know these things like,
I've been around a bit me.
All very interesting but absolutely irrelevant, completely useless and a total f**king waste of space.
To james ind st. the person that both answered my question, and was the
one who prompted it, oh well you already know how to wire Speakons for
series parallel, without needing switching capability, so go for it.
Posted By: kula
Date Posted: 23 June 2005 at 11:30am
i agree with toxic all the old style cabs i have seen have xlr`s on not jack`s i use speakon`s as they are hard to short and wont come out of the cab in less you take them out
Posted By: norty303
Date Posted: 23 June 2005 at 11:33am
I was going to do a thing with speakons on my X15's that would allow me to run passive or active depending on the dummy plug in the second NL4 socket. One set of bridges would go to the passive xover the other pair would go direct to the driver.
never got round to it....
Date Posted: 23 June 2005 at 7:22pm
No one used 1/4 eh? someone better ask jbl/peavey etc...I bought some new jbl cabs 3 years ago and they didn't have speakons OR XLR. Like I said on the SQ issue-bet you my house on the beach you cant tell up to 15A power. If you don't clean them,then they will get 'scratchy' but that's only on insertion. No one uses 1/4 anymore because speakon is better(xlr is a more solid connection too),but 1/4 work fine(I only use speakon)
It's just another 'hi-fi' debate about contact area too by the way. There are crossover components in speakers with rather thin wire(resistors,caps etc) but they're fine because it's only short,therefore resistance is low. The 1/4 sockets I used to have had WAAAAY more contact area than that(wierd half moon shaped strap that 'bent' around the shaft,id say 10mm2 at least on the earth,maybe half that on the pin-and that's being conservative)
I'm also not saying 1/4 are the best,I'm just saying that they DO work fine for most jobs and people shouldn't be afraid of using them. And yes SPEAKONS are better.
Oh and Toxic-I used to know someone like you who used to jump in and start carrying on about what he 'knew' and swore all the time and challenged everyone. I SAW him get hit very hard in the face with a baseball bat when he chose the wrong people to do it to-haven't seen him since...although at least he wasn't hiding behind his screen
Maybe we could start a Toxic conversion dictionary/thesaurus?
Like - mailto:Bulls*@t - Bulls**t = I disagree
- I know a m8 = Read it on the net somewhere...
- Damn s**t speaker blew up = I was drunk and don't know what a clip light/HPF is for
You get the idea...
Posted By: Disco Stu
Date Posted: 23 June 2005 at 7:51pm
LOLOLOL
I go away for a week and come back to find this!
Interesting thoughts though - why does anyone still use jacks for loudspeaker connectors? I dont see that theyre any cheaper than speakons and most amps are speakon out these days!
I suppose its the same debate for wtf does dj equipment still have outputs on phono plugs in fact wtf does ANYONE still use phonos? Even a goddamn minijack is a better prospect!
Who gives a monkeys about it all anyway!
This thread is about the punisher 2 and what a fine well oiled working machine they are!
Who has built them and what do you think? - I have to recommend subs to a friend soon and these are on the list i sure could use some advice!
Stu
------------- All you need to know is:
My acts:
Date Posted: 23 June 2005 at 8:17pm
why are rca plugs so bad? co-axial nature is good for inteference
shielding and absolutely everything unbalanced has them. my mixer has
balanced outs on trs, i agreee that this feature is lacking from too many
bits of kit, and xlrs would be nicer still.
check the rane empath, i usually borrow my pal's for events and its got
everything on the back. my favourite mixer - and it doesn't clip like an
a&h xone series (i may be mistaken about the cause but i don't like the
sound of them when the lights go above +3 dB).
james.
Date Posted: 24 June 2005 at 8:24pm
You get the idea...
[/QUOTE]
Well JBL or peavey ain't exactly nice cabs, except for JBL vertex array.
This post is about Punisher 2's, so dunno where the subject of 1/4 inch jacks came in.
P.S. you think I don't know anything, well I suggest you come you come to the regular events[every 2nd sat of the month] I do at a fixed location[ wood green, day centre,which gets used at night for a event] which the ppl who own it, let me use the building for free and even provide me with a van for free; as I used to be temporary staff for the day centre and help out a lot.And that 'thing' of me hiding behind my screen as you put it.I'm not hiding from anyone, come an see me djing at one of the f**king events I do.
Date Posted: 24 June 2005 at 8:46pm
Dunno if you've noticed but I'm on the other side of the world,prolly won't be today then...
And I'm usually working sat nights too. However I own my own transport(car and identically painted trailer with matching 17" rims all around) and do well paid corporate events(and just picked up long term work at a wedding reception centre with 2 venues/cathedral things) as well as local clubs/pubs who use me.
It's good that you are getting regular gigs(which is how everyone basically gets into this) but why must you continually swear at everyone and bag some things you lack reliable information on? And then one day later you totally contradict yourself(mdf/ply debate for one)?
I think there are e few people who are just getting a little tired of the barrage of smileys and f**k this f**k that and then look on another post and see you do the exact opposite,and then if someone challenges you,you tell them they don't know what they're talking about and tell them it's bulls**t etc.
Why do you ask for advise on this forum and go do your own thing?
