184 Sub ports
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=2081
Printed Date: 27 March 2026 at 8:45am
Topic: 184 Sub ports
Posted By: Doctor Happy
Subject: 184 Sub ports
Date Posted: 19 June 2005 at 6:43pm
Can someone point me in the direction of a supplier of 6" diam tubes for the 184 sub? I've started building a pair and I'm damned if I can find any. If I use 4" diam soil pipe instead (which is actually 105mm diam) what should the tube lengths be adjusted to? Thanks in anticipation.
Posted By: norty303
Date Posted: 19 June 2005 at 7:19pm
You could always build shelf ports instead, removing the need for pipe then.  Prob a much easier build
My laser stuff: http://www.facebook.com/SubsonicSystems" rel="nofollow - Frikkin Lasers
Posted By: Tony Wilkes
Date Posted: 20 June 2005 at 5:01am
No use 6" it is very easy to get hold off, either visit a few building sites on the cadge or visit your local builders merchant. I got a 10' length for £13
I find the best stuff to stick the tube in the box is Araldite, not the quick setting stuff but the stuff that stays workable for a few hours.
Tony
Posted By: Centauri
Date Posted: 20 June 2005 at 7:34am
You could always make square ports from timber - 133mm square will give you the same area, and therefore the same length.
Cheers
Graeme
Posted By: Dom
Date Posted: 20 June 2005 at 1:27pm
Or you can just use the port lengths stated on the plans for 4" ports...
Posted By: james folkes
Date Posted: 21 June 2005 at 7:49pm
i found that the different port sizes modelled quite differently on bass
box pro, but i was only looking at building one for a fane xb. square
ports have much more wall surface area for the same cross sectional area
than a round port, for what it's worth. i don't know at what size that
argument becomes irrelevant.
i would on principle go for the 6", however the 4" version modelled better
for my speaker, which i wasn't expecting at all.
james.
Date Posted: 22 June 2005 at 8:24am
Thanks for your input. I have acquired some 6" underground soil pipe which has an internal diam of 152mm. I guess I just adjust the port length to give the same overall volume of port (is it that critical?)
Posted By: Centauri
Date Posted: 22 June 2005 at 9:31am
The 2mm difference won't have any noticable effect.  Don't try to get same volume - as the port is made larger diameter, the length needs to INCREASE. Just use the length on the plan.
Cheers
Graeme
