I take it there aint gonna be a Porn Horn mk3 then
Category: Plans
Forum Name: Po rn Horns
Forum Description: Discussion / Questions about the Po rn Horns
URL: https://forum.speakerplans.com/forum_posts.asp?TID=21354
Printed Date: 26 March 2026 at 7:09pm
Topic: I take it there aint gonna be a Porn Horn mk3 then
Posted By: richard stringer
Subject: I take it there aint gonna be a Porn Horn mk3 then
Date Posted: 16 November 2008 at 10:39pm
Is there ever gonna be a Porn Horn mk3? Maybe that goes down to 90-100hz? I was just curious. Have people gone off the Porn Horns? Maybe becuase they need kick bins below them, then subs below that which is too much money and hassle for a lot of people to do just to be able to use POorn Horns.
Posted By: mykey
Date Posted: 17 November 2008 at 4:14am
I bet Rog has sold less than 10 Mk2, so why should he bother with a Mk3?
......just all them hanging there like giant bananas.
Posted By: darkmatter
Date Posted: 17 November 2008 at 1:37pm
a porn horn that goes significantly lower wouldn't be a porn horn.
have a read of horn theory, and the bandwidth that various horn expansions/sizes can support.
Posted By: Deadbeat
Date Posted: 17 November 2008 at 3:03pm
It would warrant a kick section, and become the TMS-porn
Away on extended leave.
Posted By: quadro
Date Posted: 17 November 2008 at 5:16pm
I HAVE 4 OF THE MK1 PORN HORNS I GOT SIX BOXES MADE SO IF ANY ONE OUT THERE GOT ANY FOR SALE I WILL BE INTRESTED
Date Posted: 17 November 2008 at 5:32pm
I was gonna get somemk2 Porn Horns but had a think about the fact that they don't go low enough and decided against it. He could make some Porn Horn mk3 on the same principle as the RCF 4Pro 6001 but passive couldn't he? Thats an all horn loaded cabinet. But I guess thats not gonna happen. How come he's probably sold less than 10 then? Because they don't don't go down low enough?
Date Posted: 17 November 2008 at 5:34pm
Hey thats definately not a bad thing.
Posted By: Deadbeat
Date Posted: 17 November 2008 at 6:43pm
They're really meant for systems that use bass systems that go high enough. I think they're a very classy design, tbh. If you want lower extension, stick a USB on the bottom.
4pro is a double 12 reflex.
Date Posted: 17 November 2008 at 7:49pm
The 4Pro 6001-AS speakera are horn loaded. The dual 12" drivers are angled and slightly inside the cabinet, not on the front of the cabinet.
RCF 4Pro 6001-AS Speaker Cabinet
See.
http://www.rcf.it/html/images/pic/W7_2669.jpg -
Posted By: Deadbeat
Date Posted: 17 November 2008 at 8:04pm
That is a clamshell baffle, and is not hornloaded. Clamshell saves space and allows one to place drivers coaxially. Advantages include smaller frontal baffle space, better coupling, and acoustic centre closer to the speaker above. Some manufacturers claim this to be 'semi-horn loading', but that's marketing drivel. Nothing to do with horns at all.
The mid is however unquestionably a horn.
Posted By: Heathrow_B_line
Date Posted: 17 November 2008 at 8:38pm
porn horn 2 is a great cab!
Posted By: Timebomb
Date Posted: 18 November 2008 at 1:38am
You can buy the 4pro 6001 8" mid horn and closed back driver off the shelf:
http://www.toutlehautparleur.com/pavillons/rcf-h6000-p-2804.html - http://www.toutlehautparleur.com/pavillons/rcf-h6000-p-2804.html
Plots look very nice, 107dB @1m/1w for a 80 x 60 horn its pritty loud.
http://www.rcfaudio.com/vediMacro.phtml/sLang/EN/IDMacro/2722/menuAttivo/2293/m1/0/LowFrequencyNeoWoofersMR8N301/product.htm - http://www.rcfaudio.com/vediMacro.phtml/sLang/EN/IDMacro/2722/menuAttivo/2293/m1/0/LowFrequencyNeoWoofersMR8N301/product.htm
Posted By: ceharden
Date Posted: 18 November 2008 at 2:21am
Nice!  Funny, I was just thinking recently I could do with something like that!!!
Posted By: Timebomb
Date Posted: 18 November 2008 at 4:53am
http://translate.google.com/translate?pev=/language_tools&u=www.toutlehautparleur.com/pavillons/rcf-h6000-p-2804.html - http://translate.google.com/translate?pev=/language_tools&u=www.toutlehautparleur.com/pavillons/rcf-h6000-p-2804.html
"equipped with a warhead of dispersion"  Wink
Every system should have one..
Been quite tempted by these but i cant really justify the expence of the drivers.
They do a 10" closed back driver too with a phaze plug for it, no 10" horn though.
http://www.rcfaudio.com/vediMacro.phtml/sLang/EN/IDMacro/3632/Downloads/ - http://www.rcfaudio.com/vediMacro.phtml/sLang/EN/IDMacro/3632/Downloads/
In the transducers pdf.
Posted By: adambomb
Date Posted: 18 November 2008 at 9:55am
aahhaaar!.. that's what those little horns are.. (last seen in show off thread).
http://www.freespeakerplans.com" rel="nofollow - www.freespeakerplans.com
Posted By: Wrighty
Date Posted: 18 November 2008 at 10:19am
That's a very short horn - only 83mm, so it's not going to go down very low. I would imagine it does the high mid quite well, but I think I'll stick with my 8" A.S.S. horns, which are about 230mm long and happily go down to 400Hz.
ALL YOUR BASS ARE BELONG TO US.
Date Posted: 27 November 2008 at 5:05pm
id think four MT121's.... my favourite out of these rave 12" type midtops.
ive personally heard the porn horn mk2, boke ma-whatevers, mt121's in a 'soundoff' over some hd15's and x1's, with rog doing the setups!!
i found the pornhorns, although brutally loud and very well dispersed, too screamy and were distorting quite badly, which some will argue was down to the berry ep2500 amps, but i dont care, heard the exact rig on the same processing.
the mt121 is a good free diy design too, without having to rippoff mogale or anyone else.
Posted By: LunchieTey
Date Posted: 27 November 2008 at 11:47pm
See.
Isn't there also some benefit in the 'resonant' cavity crated by drive loading like this? There are bass cabs that claim the air volume inside the 'v' boosts midbass like a quasi-bandpass?
Speaker addict
