Punisher II exploded
Category: Plans
Forum Name: Punisher and X-tro
Forum Description: Discussion / Questions about the Punisher and X-tro
URL: https://forum.speakerplans.com/forum_posts.asp?TID=2148
Printed Date: 27 March 2026 at 12:38am
Topic: Punisher II exploded
Posted By: Contour
Subject: Punisher II exploded
Date Posted: 30 June 2005 at 4:01pm
Here are some exploded views for the Punisher II:
http://www.speakerstore.nl/constructions/speakerstore/Punisher/21.jpg - http://www.speakerstore.nl/constructions/speakerstore/Punish er/21.jpg
http://www.speakerstore.nl/constructions/speakerstore/Punisher/20.jpg - http://www.speakerstore.nl/constructions/speakerstore/Punish er/20.jpg
Best regards,
Walt
Posted By: Timebomb
Date Posted: 30 June 2005 at 7:00pm
Very cool.
Posted By: JD01
Date Posted: 30 June 2005 at 7:46pm
The topic sounds BAD. Really really BAD. How did that happen? TNT inside the horn?
Posted By: james folkes
Date Posted: 30 June 2005 at 7:48pm
proper mind mangling complexity indeed. my admiration for this
wonderful little cab continues to grow, damn it i really must hear
some! preferably two a side with an x-tro. classy.
james.
Posted By: roborg
Date Posted: 30 June 2005 at 9:07pm
maybe it was a cardboard replica of a punisher with a high compression ratio
Posted By: PoteirosCorp
Date Posted: 30 June 2005 at 10:37pm
That's what I call "Customer service"
Keep on the great job Walt
Posted By: Tony Wilkes
Date Posted: 01 July 2005 at 5:12am
What program do you use for your 3d?
I think it would probably look better without a single point light source, the shadows tend to complicate matters.
Oh by the way brilliant job,
Tony
Posted By: Contour
Date Posted: 01 July 2005 at 8:32am
Hello,
I use Pro-Engineer software. This software is intended for real design purposes.
Best regards,
Walt
Date Posted: 02 July 2005 at 2:59am
Hi Walt I use a program called Varicad which is brilliant for 3D but you have to use a seperate program fo rendering.
Tony
Posted By: Disco Stu
Date Posted: 02 July 2005 at 12:13pm
Btw tony this is off topic but did you ever get that 15" bandpass cab done that rog gave you?
Stu
All you need to know is:
My acts:
Date Posted: 03 July 2005 at 4:06am
Yes I fully built a prototype, I found that the ports that Rog had spec'd did not work?  I had to work on the low band port to get a flat response between 40 - 100 hz.
In the end I gave up because I did not really get a gain in the bandpass region to make the effort worth while.
I have since decided to forget the extra 10hz the design gave me and I am currently building a double PD154 bass reflex.
What has suprised me with reflex loading the PD154's in even small boxes i.e. 60L is how much real bass they are capable of without the usual freqeuncy doubling distortion setting in. Shows the good motor drive I suppose.
A friend has just built some 100L boxes with PD154's and he is very impressed with the results and is now selling his Eminence loaded boxes!!
Tony
Date Posted: 03 July 2005 at 3:17pm
Hmm interesting, I use B&C 15PZB40s in 120l cabs for bass in my bands PA and they are pretty good but 60l? surely not? that would mean I could stick 2 154s in the same size box that im using now and have twice the power handling! Were those 60l boxes for live or for recorded music?
Stu
My acts:
Date Posted: 04 July 2005 at 4:25am
The performance was a surprise to me as well. It came about when I was after a driver to try in my Berry B1500X when I become fed up with the wooley bass that they emitted, as I had the 154's for the sub project I gave it a go and was very impressed. The standard ports worked fine which I also confirmed with some RTA tests.
I will be putting the doubles into 150L boxes and porting them for a fairly low Fb.
I use mine for mainly live use but when I am asked to play a few tunes between acts they still sound pretty impressive.
I am not so sure that low QTS i.e. 0.2 - 0.3  drivers in reflex boxes always model correctly. The graphs for the 60L 154's certainly do not tell the whole story?
Tony
Posted By: bobby
Date Posted: 04 July 2005 at 3:51pm
Walt    this  punishers looks preety impresive ..   any idea on when this prototipe will be tested ??  any plans for the building of this cabinets  in the near future ?   they look awesome    Thanks .  Bobby
Posted By: Jez_Ultra
Date Posted: 04 July 2005 at 5:51pm
Originally posted by Contour Contour wrote:
Hello,
Best regards,
Walt
pro engineer, is the daddy of 3D modelling software.
