Quick Punisher question...
Category: Plans
Forum Name: Punisher and X-tro
Forum Description: Discussion / Questions about the Punisher and X-tro
URL: https://forum.speakerplans.com/forum_posts.asp?TID=2305
Printed Date: 27 March 2026 at 8:46am
Topic: Quick Punisher question...
Posted By: MixMan X
Subject: Quick Punisher question...
Date Posted: 01 August 2005 at 5:14am
Guys,
Can anyone tell me how many 8x4 sheets of 15mm ply I need for a pair of punishers?
I'm getting my local timber merchant to cut the panels, but I wan't to know how much it's going to cost in advance.
Posted By: Lyndon A
Date Posted: 01 August 2005 at 9:57am
I'm 95% sure you can get one punisher onto 1.5 8x4 sheets.
Therefore you can make 2 Punishers from three sheets.  I've been moving the panels onto 8x4 sheets today as an autocad drawing working out the best layout.
Posted By: MixMan X
Date Posted: 01 August 2005 at 1:04pm
Thanks, 8x4 sheets are about £40 each, so that's going to be alright.
If anyone needs wood cut in Bristol I can recommend Avon Plywood in Keynsham, if you give them a cutting list they put it all in the computer and it works out the most economical layout. They do charge a bit extra for cutting, I think it's about 50p a metre after the first 4 metres of cuts, but they are very accurate, I've used them loads of times and they are always within 1mm.
Posted By: Lyndon A
Date Posted: 01 August 2005 at 1:47pm
We got our ply at £44 for two sheets
so for 50p a metre cut does that include all the mitre cuts? Sounds like quite a good price
Posted By: MixMan X
Date Posted: 01 August 2005 at 2:27pm
Not sure if they do mitre cuts, I always do my own when I get the bits home. I don't think they are the cheapest place, but I've always used them because of their accuracy.
Posted By: Beavis
Date Posted: 07 August 2005 at 3:52pm
MixMan, how much is the 15 out keynsham, im noyl down the road, in brislington.. if i can get my stuff chopped there, there is a little palce in the dings area if you know it, who can do mitre cuts for a price
Posted By: Andrew
Date Posted: 07 August 2005 at 4:09pm
Do Avon supply drawings from their computer, i.e. so you know what sequence they will but the wood?
If you need a dimension such as 578mm x 578mm as on a HD15, will they do this by turning the wood around, and not reset 578mm after cutting another dimension?
Posted By: MixMan X
Date Posted: 08 August 2005 at 3:14am
Beavis, it's around £40 a sheet for 8x4 15mm birch ply.
Andrew, I've never asked to see a drawing of how they are going to cut it, but they cut in a certain way if you want the grain in a certain direction, so I guess they would do what yo ask too?
