"Modular Horn" by Mr Punisher?
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=23080
Printed Date: 27 March 2026 at 10:02am
Topic: "Modular Horn" by Mr Punisher?
Posted By: FUBARD303
Subject: "Modular Horn" by Mr Punisher?
Date Posted: 19 January 2009 at 4:06pm
So I've found that speakerstore, the place where the punnisher lives, houses some other interesting designs. One that caught my eye as I was looking to find a loving home for my sweet new quartet of 18sound 18lf1400 was the "Module-Horn"designed by the same pair also responcible for the legendary Punisher horn. Anyone else looked into this crazy new concept? What's this puppy do in simulation? Anyone built some?
Go to 'Speakerstore.nl' then hit 'constructions' then find 'module-horn' on list.        Sorry can't cut n paste right now.
"Always look on the bright side of life" -Brian
Posted By: bitzo
Date Posted: 19 January 2009 at 4:36pm
http://www.speakerstore.nl/index.php?pg=11&c=17 - http://www.speakerstore.nl/index.php?pg=11&c=17
Quite similar to a scoop layout but with a sealed chamber. how do they join the 2 cabs? only with 2 strings?
Posted By: darkmatter
Date Posted: 19 January 2009 at 5:25pm
It will be a very nice sounding cab. The 'modules' are held together by their weight and a ratchet strap.
I imagine they'd be great for a system where efficiency is more important than things like size and weight.
Date Posted: 19 January 2009 at 6:28pm
Rachett straps are in the design but I was thinking of a set of lids for storage and transit with opposite genders on recessed latches such as the ones used in gig racks n cases. Anyone think they'd hold up to the vibes?
Date Posted: 22 January 2009 at 4:12pm
I was thinking the same when I was looking into this. I also thought of routing a small groove with silicon sealant in all the way round the edge between where the modules seal together. It'd compress to give an airtight seal when you put them together. It'd wear out yeah, but it wouldn't be visible when stacked and could easily by re applied every few months.
Posted By: Robbo
Date Posted: 22 January 2009 at 4:36pm
With a bit of thought during construction, the two halves could be fastened together with locating lugs or strips and heavy duty flightcase butterfly catches.
Posted By: norty303
Date Posted: 22 January 2009 at 5:53pm
Might want to search for the thread about Rog's monster scoops which were in 2 sections.  There was quite a lot of discussion about joining methods in there...
Edit:  the Rubic Horn, worth looking if only for the costume  Big smile
http://www.speakerplans.com/forum/forum_posts.asp?TID=14904&KW=scoop - http://www.speakerplans.com/forum/forum_posts.asp?TID=14904&KW=scoop
My laser stuff: http://www.facebook.com/SubsonicSystems" rel="nofollow - Frikkin Lasers
Posted By: H...
Date Posted: 22 January 2009 at 6:24pm
Just do it in one cab......................
Buy a bigger truck and  start working out
Date Posted: 22 January 2009 at 7:46pm
How'd y'all know I drive me a truck?
I've got D-bag cloths of my own, thx... Maybe when (and if) I finish the cabs, I'll get a shot of my amazing DIY 'blown up' jeans featuring 70 inch cuffs. Ahhh, the rediculous 90's Rave scene.
I think I'll try adding a lip bisecting the joining surfaces w neoprene material between and twist locks to hold em together. I wonder if King Rog (respectfully) would be willing to divuldge which brand of lock he found that doesn't rattle ones brains to pieces as I suspect most would.
Posted By: SonicXtasy
Date Posted: 22 January 2009 at 10:14pm
Can anybody input these plans in Hornresp? Can the throat and sealed chamber be modified to fit a 15? I assume that it would not be as efficient but should still have the effortless 35Hz?
The member formally known as vwbidder.
Posted By: Preacher
Date Posted: 23 January 2009 at 10:19am
Don't the Dandilion reggae sound system have some modular (2 part) scoops? I swear they were on the forum some place.
It's all about the music & the vibe, so enjoy it while you can.
Date Posted: 23 January 2009 at 11:38am
Because Y'ALL from TexasTongue! I don't even think they have cars there unless they are as big as trucksWink.
Date Posted: 23 January 2009 at 4:03pm
I really need to sit down n learn hornresp. I so wish I had a graph of theese guys with the reccomended. 18sound 18lf1400 in em. Now my stupider question is...
If the horn resonates down to 35hz when laired and lower when I build all 4 of em, won't the depth be stopped by my driver's 31hz resonant peak? I mean one IS supposed to cut it just above the RP right?
Date Posted: 23 January 2009 at 5:56pm
These are definitely not correct, I haven't a clue how to use HornResp properly and I couldn't be bothered to work out Atc/Vtc properly so I guessedConfused
Date Posted: 26 January 2009 at 3:44am
Confused
Posted By: boycey
Date Posted: 26 January 2009 at 11:10am
darkmatter- where did you take the throat? or where do you reckon it should be? i've been thinking about building a pair of these, possibly modded for a v18 1000. might have a play about with this today.
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
Posted By: boycey
Date Posted: 26 January 2009 at 12:40pm
i've calculated the rear chamber to be very very close to 120l, my mac is behaving like a twat though and i can't seem to download pdfs properly, can anyone tell me how much volume the driver takes up?
edit:  and s1=670
Date Posted: 26 January 2009 at 2:24pm
my 105 was a rough estimate based on 119.5 minus driver and handles volume.
start of the throat was guessed by eye, as was horn length, Vtc, AtcEmbarrassed at least it got the ball rolling hehe
Posted By: boycey
Date Posted: 26 January 2009 at 2:41pm
i'm taking s1 to be the vertical distance on the first fold from the driver- there being no corner piece right of there to extend the horn and bring Vtc down. whaddya reckon?
having an mare calculating Vtc though... if you (or any other helpful person) can riddle me this it would get us there much quicker. my various sine/cosine rule manipulations have given me a headache and are producing results which don't match the plan...
anyways:
we have an irregular quadrilateral, with angles: A=78, B=99, C=159, D=24. side AB=154mm and AD=520mm.
what is the area of quadrilateral ABCD?
i'm off to make lunch
edit: correction to side ABEmbarrassed
Posted By: Deadbeat
Date Posted: 26 January 2009 at 3:24pm
Split it into triangles...
or... http://mathworld.wolfram.com/Quadrilateral.html - http://mathworld.wolfram.com/Quadrilateral.html
Away on extended leave.
Posted By: boycey
Date Posted: 26 January 2009 at 3:44pm
according to the quite lovely crispy on the urban75 board my quadrilateral intersects itself, hence my issues.
i have put it in hands more capable than my own for now, there's a whole team beavering at this. i'll keep you posted. it should be there quite soon.
Posted By: boycey
Date Posted: 26 January 2009 at 3:59pm
anyways:
Posted By: boycey
Date Posted: 26 January 2009 at 4:46pm
ok then, Vtc according to me and crispy is 37.78l
Date Posted: 27 January 2009 at 1:28am
This feels like history in the making...
Cool
Posted By: mykey
Date Posted: 27 January 2009 at 4:45am
be careful if you're going to build something like this
the energy levels are very high, especially with a horn that size
so expect some rattling, unless you BOLT them together, and after a few gig's you'll get tired of it
......just all them hanging there like giant bananas.
Posted By: H...
Date Posted: 27 January 2009 at 6:59am
Bolts / lock nuts / neopean (sp?) gasket................... or just make them as one a big berther for the year 2009!
Posted By: tomschute
Date Posted: 27 January 2009 at 10:49am
http://www.protex.com/latches.asp - http://www.protex.com/latches.asp
Wink
www.stableaudio.co.uk
Speaker Building Services
Posted By: boycey
Date Posted: 27 January 2009 at 1:13pm
just so everyone else can have a play, the data i got was:
Vrc = 120L - volume of driver
Vtc = 38L
S1 = 670cm^2
con = 77cm
S2 = 1290cm^2
exp = 91cm
S3 = 2655cm^2
exp2(or L34 or whatever it's called) = 69cm
S4 = 4585cm^2
sorry i can't post pics, i think i may have screwed up the length of the horn- it may be a bit longer and i can't help feeling that the mouth could have made more use of the front footprint? the lack of a "corner piece" at the first fold theoretically shortens the horn and increases Vtc quite a bit, perhaps it'd be worth playing with that too. finally, as i'm on a sh*te pooter i couldn't get the thiele/small for the recommended driver and the void gave a very lumpy response. even if it does look like it's worth playing with.
Date Posted: 27 January 2009 at 4:47pm
Haha I've just realized that the triangle in the bottom box isn't part of the horn, ignore my measurements then lol.
I was thinking it was a bit odd that the horn path would enter the second box so soon, I should've known better than to think that Walt wouldn't have thought of this!
Posted By: boycey
Date Posted: 27 January 2009 at 6:00pm
lol!
can you or anyone else post the necessaries from the 18sound woofer that's recomended?
Posted By: FlipC
Date Posted: 28 January 2009 at 10:23am
18LW1400
Sd 1225
Cms 1.39E-04
Mmd 164.97
Re 5
Bl 24.41
Rms 5.13
Le 2.38
And the HR #s posted cant be right cause that is only 500 Lt. One would assume this thing is 900 plus ?
Date Posted: 28 January 2009 at 5:21pm
As taken from www.eighteensound.it looking at the specs page for the 18lw1400 (walt's recomended driver)
I'm not familiar with hornresp or anything else so I'll post everything I see.
Fs.    31Hz
Re.   5 Ohm
Sd.   0.1225 sqm
Qms 7.2
Qes. 0.31
Qts. 0.29
Vas. 297 lt.
Mms 190gr
BL.    24.7 Tm
Xmax. (+-) 9mm
Le1kHz.   2.3 mH
1W@1m(1/2sp). 96.5 dB
Hope this helps.
THANX!
Posted By: tommysb
Date Posted: 28 January 2009 at 7:32pm
That'll be the driver's free air resonance. If you stick a horn in front of it, that's a lot of air, all of which has mass. If you imagine glueing weights to the cone, that would bring its Fs down.
The same thing should happen with the mass of air in a horn, so the Fs of the driver will effectively be lower than 31Hz.
Date Posted: 29 January 2009 at 3:14pm
Juicy! :) THANX tommysb.
I can't wait to see a curve on this thing. Should be in the brown range, LOL!
Posted By: mykey
Date Posted: 30 January 2009 at 2:44pm
I was bored
http://imageshack.us">
http://g.imageshack.us/img90/waltshornrd0.jpg/1/"> http://imageshack.us">
http://g.imageshack.us/img89/waltshorn1ul9.jpg/1/"> my bin (DEMO1) black line, walts modular grey
http://g.imageshack.us/img212/waltshorn2ep5.jpg/1/">
just shows you what you can get from a smaller cabWink 48w 48 d 24 h
http://imageshack.us/">
Date Posted: 30 January 2009 at 6:06pm
niceSmile what's the compression ratio like in yours? is it the same picture when you plot more bins in a stack?
Posted By: mykey
Date Posted: 30 January 2009 at 6:15pm
Not telling you that
aready f**ked up with amano and the brute 45
I drew walts horn up in autocad, so its near spot on
 that driver simmed is my driver, pretty close to the 18lw1400 but a nats better
more bins of walts? you want me to make you a cup of tea and rub your back aswell?
Posted By: mykey
Date Posted: 30 January 2009 at 6:24pm
I know we don't like sims, but this is easily the best bin I have designed and below compared to the Rubic horn
8 x Demo1 would be 8ft x 8ft wall, 4ft deep
with 8 x demo1 we are talking less space than a rubic with hair raising results
 4 x DEMO1 (demolition one) 2.0 x pi 1w1m
Date Posted: 30 January 2009 at 6:26pm
Backrub, THEN tea please. I keep my speakerplans tension in my shoulders. Ahhh, that's nice....
Antlyway, Yes, I belive Walts horn was designed to be placed in pairs. Wouldn't that smooth out this kilamonjaro of a chart?
Posted By: mykey
Date Posted: 30 January 2009 at 6:29pm
yes it would
but you would still need a truck the size of Kilamonjaro to transport it, and the patience of a post office counter person to assemble it
Posted By: mykey
Date Posted: 30 January 2009 at 6:30pm
i have 2 versions of the Demo1, one with a slight different throat, this gives me a flat response, i'm still testing what one to go with
Posted By: mykey
Date Posted: 30 January 2009 at 6:48pm
also doubles up as a hair dryer
so no probs with wet gig hair chaps
Date Posted: 30 January 2009 at 7:38pm
Que the 'hot air' shots... :))
Posted By: bitzo
Date Posted: 30 January 2009 at 7:47pm
one question mykey..... could you post a raw sketch of demo1's layout? Clown
Posted By: mykey
Date Posted: 31 January 2009 at 2:46am
only if you let me shag your sister, in all the holes
Posted By: mykey
LOL  are you dissaponted that the modular didn't make you sh*t yourself
Posted By: Bespoke
Date Posted: 31 January 2009 at 2:57am
Cool.............. Just bring them over here
Gone
Posted By: mykey
Date Posted: 31 January 2009 at 3:01am
4 on there way to 4D soon
will do 8 myself for a outdoor rave
Posted By: Bespoke
Date Posted: 31 January 2009 at 3:03am
Are these plots based on the final desgin ?
Gone
Posted By: mykey
Date Posted: 31 January 2009 at 3:08am
I know where this is going bruv, don't go there
you don't even no how the tas works so how can you put it into hr
nineleaves has already said hes done something special that HR can't sim
nobody wants to carry around a waredrobe.....unless its full of gucci...it won't be a winner
Posted By: Bespoke
Date Posted: 31 January 2009 at 3:30am
Mykey only asking.... if you dont ask you dont get.
Now as i've said before i like the idea behind the brute 45 AND i said this before we even made a sub.
Try not to jump down my neck for asking very simple questions.
I wish you all the best with your cabinet(s) and look forward to hearing it
Gone
Posted By: mykey
Date Posted: 31 January 2009 at 3:35am
damb! i can't piss you off......what you after lol
thanks bespoke, likewise
Posted By: Bespoke
Date Posted: 31 January 2009 at 3:43am
Not many people can wind me up LOL ( 6 years of Aikido showed me how to keep things to myself )
I am not after anything, i really was just asking about your sub.
All the best
Gone
Posted By: mykey
Date Posted: 31 January 2009 at 4:00am
cool, I'm also a martial arts man
my list, in order of training from the age of 7
judo, Boxing, karate, Kung fu,  kempo, greco Roman wrestling, systema, Muay thai boxing, and now currently boxing 4 times a week...and love it
if you want to win a fight, it has to be Systema and boxing
Posted By: Bespoke
Date Posted: 31 January 2009 at 4:15am
WOW ...... LOL
As you prob know Aikido is a bit more ummmm relexed Ying Yang, trying not to hurt people and trying not to get hurt.
We use to love the '' judo '' kids coming over telling us how its done with legs flying etc etc ........ BANG they hit the floor and start thinking f**k how they do that ( with 1 arm ) LOL
Also Aikido is more about your mind and control rather than ... who can we beat up the fastest.
Gone
Posted By: B.P.Sound
Date Posted: 31 January 2009 at 9:41am
Controlled Aggression thats what wins fights
And feeling no pain helps!
http://uk.youtube.com/watch?v=CHCbE-OjboI - http://uk.youtube.com/watch?v=CHCbE-OjboI
http://www.londoneventrentals.co.uk/ https://www.facebook.com/LondonEventRentals
Posted By: nickyburnell
Date Posted: 31 January 2009 at 9:54am
Boxers, too bloody accurate, whistling noises in the head, time to get the hell out.
 Peace (well sometimes).Ying YangOuch
Posted By: bitzo
Date Posted: 31 January 2009 at 11:34am
mykey, respect each one first of all, a joke is joke, family is another thing, holy thing in every country. Why you don't have to keep a gentleman behaviour?
Posted By: mykey
Date Posted: 31 January 2009 at 11:47am
you were lucky.....I was going to say 'while your mum and dad watched'
you called me a clown and I was hoping you didn't have a sisterEmbarrassed
sorry me old china
Posted By: mykey
Date Posted: 31 January 2009 at 11:48am
the fella on the left looks like the geezer out of jack ass
Posted By: Deadbeat
Date Posted: 31 January 2009 at 12:42pm
Honestly, it's simple physics.
Walt's design is a compromise as it is designed to be used in one or two sections.
And no, you are definitely not going to get brown notes with that horn.
Much better ways to get low.
Posted By: mykey
Date Posted: 31 January 2009 at 2:15pm
+1, and quite easy to design
you could have a 'brown accident' by trying to lift one
Posted By: bitzo
Date Posted: 31 January 2009 at 6:40pm
sorry me old china
I don't call you clown, I make the clown, you know make joke than smile... too much blow in your martial arts training training could you loose your english sense of humor? arigato sensei mykey, your cabs is always the best, this unworthy pupil must learn from his unforgivable mystakes by meditating under the waterfall. (this is another joke, smile )
Date Posted: 31 January 2009 at 11:34pm
ok ok, pissing contest asside: the mod-horn has been proven to be impractical.
mykey, no offence mate, and i do appreciate all your help but your unwilingness to offer a plan sort of undoes the entire experience. unless perhaps, youre willing to email me plans for 'testing' since my long distance and small time nature would probably NEVER threaten the fortune you'll surely make with this superrior feat of acoustical engeneering genious. (stroke stroke)
since there are still 4 homeless 18lf1400's can anyone WITH A DESIGN able to offer a viable comparible design?
what's a guy have to do to get a good plan around here, lol!
Posted By: mykey
Date Posted: 01 February 2009 at 3:50am
build a hybrid Fubard
its seems fubard you have a sense of humour, and very nice it is too
but Bitzo, you haven't got a sense of humour its seems
still, I suppose all Italian like slap stick, and I don't now how you can put that into words
do your self a favour......rent ''EXTRAS'' on dvd......its English humour at its finest
I lived in Italy in the 80's Bitzo, Milan, i do understand that all Italian fathers love their daughters A LITTLE TOO MUCH, I don't mean in a perverted way, I mean in a over protective way
and Italian men talk about there mums far too much FACT
don't be so sensitive, and tell your mum your fine and not to worry
Posted By: mykey
Date Posted: 01 February 2009 at 4:02am
i was just explaining that the design was good, but you could do a more practical design
i have just done 4 drawings of scoops for SP, isn't that enough
18 sound LW1400 is a great driver, theres allot you can do with that
Posted By: Bespoke
Date Posted: 01 February 2009 at 4:08am
LOL Looks like your in the same boat as us now Mykey ..... - WELCOME - Hug
Gone
Posted By: mykey
Date Posted: 01 February 2009 at 4:10am
fight fight fight lol
Posted By: Bespoke
Date Posted: 01 February 2009 at 4:15am
Its all down hill from here my friend, unless you give them WHAT THEY WANT your f**ked.
Funny isn't as you have given a way so much of your time and different plans yet people still want more from you.....thats becuase ''More is never enough'' Wink
Please post full plans of the brute 45 when you get time Mykey LOL
Gone
Posted By: H...
Date Posted: 01 February 2009 at 4:36am
some people don't just want a free lunch but breakfast, dinner and a bloody midnight snack.
When do we get the plans for the Tits 'n' Arse System then?
Posted By: mykey
Date Posted: 01 February 2009 at 5:59am
stop chewing tobacco and use the search functionWink
they say that everyone one has a twin in the world somewhere
well this site also has twins
http://www.speakerplans.com/forum/forum_posts.asp?TID=20528 - http://www.speakerplans.com/forum/forum_posts.asp?TID=20528
http://www.speakerplans.com/forum/forum_posts.asp?TID=20718&PN=1 - http://www.speakerplans.com/forum/forum_posts.asp?TID=20718&PN=1
stick your 18 sound in these
Posted By: Bespoke
Date Posted: 01 February 2009 at 2:48pm
LOL Very good Clap
But i am sure you can do better than that................
Now in anwser to your question above ^  just like the Brute 45 / Shortman scoop ( the list goes on ) the plans will not be posted here or anywhere else sorry
Gone
Date Posted: 01 February 2009 at 8:23pm
Alright b!tches,
i guess i was confused thinking this was 'speakerplans.com' as opposed to the clearly implyed 'myspeakerplanisbetterthanyours.fu' guess i'll not be making that mistake again. you guys rock like yani.
anywho,
i do like the idea of the vented horn but from what i can tell, the reccomended driver is quite diferent from what ive got. i think the 186 is best for me right now as theres a tasty bit on that forum with such interaction and it doesnt look too far over my head.
and I'll be keeping my tobakey THANX! Pig
Posted By: bitzo
Date Posted: 01 February 2009 at 8:31pm
fubard don't get angry because of this.....I agree with you there are few forum member from you could learn. I guess so much people search who have/build/designed the best cab, but IMHO I have to search how...not who. good luck for other thread
Date Posted: 01 February 2009 at 9:05pm
Not angry, just frustrated at the fact that im being forced by this comunity to educate myself, research and make a positive contribution before being given anything. comunists Angry !
Wink
Posted By: mykey
Date Posted: 02 February 2009 at 4:48am
Fubard
put the 18 sound in both of these, I have simmed them for you and you will likey allot
now, you both get an extra 30 minutes in the playground for being extra nice today
ppwwaatttt....ttinnnnggggg!!!!  <spitting>
Posted By: mykey
Date Posted: 02 February 2009 at 5:01am
Wink
if we didn't do it this way, you would take your plans and we would never see you again......your not a Chinese texan?
would be nice for you to stick around, I like your sense of humour, you remind me of HBL
"bitches" LOL
Date Posted: 02 February 2009 at 2:41pm
Sweet, thx mykey! I LOVE the playground as long as there's plenty of mud.
So, gimme a few weeks to make ply purchases; I will post pics of the TexSpit sound machine once it's up n runnin.
Posted By: Amano
Date Posted: 03 February 2009 at 1:25pm
http://amanosempai.narod.ru/booster.htm - http://amanosempai.narod.ru/booster.htm
Date Posted: 03 February 2009 at 3:10pm
Sweet one Amano, this great looking cab deserves it's own thread!
I like... :)
Posted By: Contour
Date Posted: 03 February 2009 at 9:39pm
Hello guys,
This M-horn is quite an old design, way before the Punisher was designed. Using a stack of 3 Punishers is about the same size as one full M-horn and will give up to 10dB higher maximum output.
So far I know only very few people build a M-horn, nobody seems to have the perfect solutions for coupling both modules.
If you are very limited on the money I still think it is a good idea to buy one good driver (this can be 18" or 12" doesn't really matter) and build a horn for it as big as possible.
However, for the same bulk multiple Punishers will be louder, this is because bigger power handling. As can be read in csg's Punisher construction topic a stack of Punishers goes low enough for most applications.
Best regards,
Walt
Posted By: mykey
Date Posted: 04 February 2009 at 3:31am
"However, for the same bulk multiple Punishers will be louder, this is because bigger power handling. As can be read in csg's Punisher construction topic a stack of Punishers goes low enough for most applications. "
exactly
Posted By: H...
Date Posted: 04 February 2009 at 5:41am
Looks like you've been 'boosted' mykey........... what ya saying about this? Me thinks he drives a Saab!!
Posted By: mykey
Date Posted: 04 February 2009 at 10:49am
I haven't been boosted
me thinks he wears glass's, has no friends and uses a bus
he wants to make some friends on here though, who wants to put him up for the summer holidays? just make sure you have plenty of white salty bread and spam in the house....OH! and vodka if its cold
Date Posted: 10 February 2009 at 6:36pm
Thanks for the testamony Walt! It's an honor to have started a thread featuring your wizdom.
Mykey you too. Everyone, you've been GREAT HELP. Thank you all.
I hereby pernonuce my questions answered and this thread; SQUASHED!
