Punisher vs limmer 042 ?
Category: Plans
Forum Name: Punisher and X-tro
Forum Description: Discussion / Questions about the Punisher and X-tro
URL: https://forum.speakerplans.com/forum_posts.asp?TID=23513
Printed Date: 27 March 2026 at 7:15am
Topic: Punisher vs limmer 042 ?
Posted By: vakarm
Subject: Punisher vs limmer 042 ?
Date Posted: 31 January 2009 at 5:18pm
Smilehello, be that the punisher is compatible with limmer 042? Would example 2 punisher with 1 limmer 042 that be good like configuration?
Cryafflicted for my English!!
FOCSASUB!! i love Neurofunk
Posted By: pfly
Date Posted: 31 January 2009 at 6:41pm
You need something to put in between. 15" reflex or straight horn (or double that) would be nice.
edit: 2x punishers from 45hz to 100hz, 15" horn from 100hz to 500-600hz and 042 up from there.
Posted By: vakarm
Date Posted: 31 January 2009 at 8:08pm
Ok, thank you for your answer.
Posted By: bitzo
Date Posted: 31 January 2009 at 8:45pm
straight horn= jbl4512 replaced driver with a 15" or some selenium plan
Posted By: cravings
Date Posted: 31 January 2009 at 9:21pm
http://www.speakerstore.nl/index.php?pg=11&c=24 - limmer p3 as someone suggested a  15" in between? i've always thought these looked like a nice speaker.
Posted By: huhts
Date Posted: 28 January 2010 at 4:43pm
I've been also thinking what to put between punisher and limmer 042. I'd like to build three punishers per side. How to cover 100-500Hz easily with nice amount of output and maybe in the same enclosure with 042 bi-amped? Just a 15" in a reflex or some straight horn with 12" or 15"? Any good successions or experience with similar setups? The system would be for electronic music and a nice kick would also be needed.
Posted By: Chrise
Date Posted: 28 January 2010 at 6:48pm
IF there any DIY Horn for that frequencyrange?
[GER-User]
