Weight reduction in Super Scoopers
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=2372
Printed Date: 26 March 2026 at 10:03pm
Topic: Weight reduction in Super Scoopers
Posted By: ijaman
Subject: Weight reduction in Super Scoopers
Date Posted: 12 August 2005 at 11:11am
Hi,
I just thought about some (minimal) weight reduction in the Super Scoopers. I want to cut some larger holes in those vertical braces.
Will this influence the sound in any way?
Posted By: LunchieTey
Date Posted: 17 August 2005 at 2:36am
Assuming the brace loses NO structural integrity then no it shouldn't(at least in low frequencies)
Speaker addict
Posted By: Tom Umney
Date Posted: 21 August 2005 at 10:28am
Use 15mm birch ply then.
Posted By: kersley
Date Posted: 24 August 2005 at 1:09pm
wow.
that is so clever.well done that man anyway to save weight is good. have you anymore such good ideas ??
thanks
Date Posted: 25 August 2005 at 9:59am
Just make sure the 15mm birch ply is at least made of 11 ply for strength.
Posted By: Jay Lawless
Date Posted: 26 August 2005 at 3:15am
Neo Drivers? Find a suitable Neo Driver for your scoops, that should take a few pounds/kilos off
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist
Date Posted: 26 August 2005 at 9:24pm
Yeah that too!!!
PDN.18SB40 neodymium weighing only 8.5kg,QTS 0.32,BL 25.77,xmax 6mm, 4 inch vc,600w rms. Can see that Neo PD driver working in the super scooper!!!
Or P. Audio P18N Neo 18 inch weighing only 7.5kg.,QTS 0.26,BL 31,xmax 5mm, 3.91 inch vc,800w rms.
BL is well high of 31.
Date Posted: 26 August 2005 at 9:33pm
I bet if you make the super scooper 18 out of 15mm birch ply and use the P.Audio P18N weighing only 7.5kg, you could probably lift the scoop in your own.
Date Posted: 30 August 2005 at 6:26pm
I really can't think of anything else to help reduce the wieght.
15mm birch ply
Neo drivers
Thats about all that comes to mind.
Date Posted: 31 August 2005 at 10:46pm
Build it out of plexiglass, so you can use it as a fish tank when you not playing music through it.
Posted By: Mircea Bartic
Date Posted: 01 September 2005 at 5:33am
Plexiglass is extremly expensive (at least here in Romania)
http://www.facebook.com/nexus.acoustics.research" rel="nofollow - http://www.facebook.com/nexus.acoustics.research
Ex Nexus_3
Posted By: Dave Slater
Date Posted: 05 September 2005 at 8:12am
you might want to use a mixture of 18mm and 15mm for structural integrity
the baffle for example should be out of 18mm as should the panel behind it that forms the rear chamber
the rest you should be able to get away with using 15mm
