Beyma 18g50 ..does it work on 1850?
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=24045
Printed Date: 27 March 2026 at 8:37am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Beyma 18g50 ..does it work on 1850?
Posted By: sillysound
Subject: Beyma 18g50 ..does it work on 1850?
Date Posted: 15 February 2009 at 6:41pm
Hellos,
I'm a new user in this forum. My question is i have 4 Beyma 18G50 and i´m planning to build 4 1850 boxes. Is this a good driver for the boxes
It has a BL factor of 28.8 and EPB of 119,76 (fs=40hz and Qes=0.334
Anyone tested beymas in this setup?
thanks in advance
Posted By: Dream
Date Posted: 10 January 2010 at 8:31am
sillysound wrote:
Hellos,
thanks in advance
I wanted to build the 1850 two for my 18G50, but apparently the 18G50 cant have that pressure, a 186 horn would be much better as far as I heared. Im searching like hell for a decent explanation and how to adjust te horn to get the maximum out of the 18G50. If any one knows some good documentation, please send me a link.
------------- http://www.bsd-productions.com
Posted By: Robbo
Date Posted: 10 January 2010 at 10:48am
Beyma 18-G50 is a driver designed for use in front loading vented cabinets and if you load them into horn type cabinets then the ribbed cone rapidly disintegrates----For horn loaded cabinets you need the G550 with the smooth cone which is built for the job---If you go on the Beyma website, all of the specs for both drivers are on there.
