Recommended cab for Pyle PPA18
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=24221
Printed Date: 26 March 2026 at 7:10pm
Topic: Recommended cab for Pyle PPA18
Posted By: smithshorn
Subject: Recommended cab for Pyle PPA18
Date Posted: 20 February 2009 at 8:37pm
Qts   .39
Vas   17.77 cu.ft.
Fs     24.2
x-max    un-known
Not much info available on this.
Yes, I know they would make great paper weights!Tongue
Posted By: _djk_
Date Posted: 22 February 2009 at 8:22am
http://www.pyleaudio.com/manuals/PPA8-10-12-15-18.pdf - http://www.pyleaudio.com/manuals/PPA8-10-12-15-18.pdf
BP6A
7 cu ft, 8" dia x 4-5/8" long
3 cu ft, 10" dia x 1-1/2" long (two thicknesses of 3/4")
98.3dB/2.83V/1M
Will handle 800W peaks without x-max problems
42hz~120hz
djk
Posted By: Glenn
Date Posted: 22 February 2009 at 1:31pm
In metric and with the chamber tuning frequencies from winisd. 6th order bandpass.
Rear Chamber 198.2L 42.87hz
Front Chamber 84.9L 89.23hz
Efficiency ranges from 98-101db/w@1m. But group delay/transient response looks poor.
Alternatively a simple reflex box with box volume 145L tuned to 37hz might be ok to get a bit of spl from this lowish efficiency driver. It is a bit of a compromise as this driver has a very low fs and fairly high qts. More like a hifi driver!
Good luck.
Date Posted: 23 February 2009 at 12:59am
Thanks! This makes a great start for these.Smile
Posted By: nefarious
Date Posted: 21 October 2024 at 3:00am
anyone have the pyle manual?
the link on pyleusa website no longer works.
http://manuals.pyleusa.com/PDF/PPA8-10-12-15-18.pdf
filename: PPA8-10-12-15-18.PDF
Posted By: APW
Date Posted: 23 October 2024 at 3:34pm
a Google search returned...
https://www.manua.ls/pyle/ppa18/manual" rel="nofollow - https://www.manua.ls/pyle/ppa18/manual
or
https://www.bhphotovideo.com/lit_files/865214.pdf" rel="nofollow - https://www.bhphotovideo.com/lit_files/865214.pdf
Date Posted: 24 October 2024 at 3:45am
THANK YOU for your reply with the working links.
I am interested to know what text you searched for and in what part of the country your ip resides? I am not a beginner interwebs person, my father worked the DarpaNet project,  I've had Internet access before basically anyone. But searching Google for the file name and /or the model  came back with this and several other forums as well as Pyle's website, with all the forums pointing to the original Pyle USA link that is no longer working. (I contacted Pyle about their server link expiration).
I believe the Comcast public access WiFi I am currently connected to REALLY takes advantage of the fact the even though the FCC voted 3-2 to restore Net Neutrality in April 2024, the federal court BLOCKED the
restoration of net neutrality rules in August 2024.
So, with this information one can see that a a person's search on Google in one area for
 the exact same thing a person searches for in another area can & will get VERY
DIFFERENT RESULTS or no results at all. It all comes down to the mighty $
as seen by the fact that FCC members are not approached by lobbyists but those
that appoint federal judges MOST certainly are! 😉
Posted By: APW
Date Posted: 24 October 2024 at 9:05am
I'm in the UK and searched "pyle ppa18 manual" using Google.co.uk
According to whois.com:
B&H Photo ( http://www.bhphotovideo.com" rel="nofollow - www.bhphotovideo.com ) is an American site and  " http://www.manua.ls" rel="nofollow - www.manua.ls" is Dutch.
