RE AUDIO XXX SUB
Forum Name: 12v Powered Systems
Forum Description: From Mini-rigs to ICE, all your low voltage audio needs here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=24635
Printed Date: 28 March 2024 at 8:04pm Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: RE AUDIO XXX SUB
Posted By: Dav Singh
Subject: RE AUDIO XXX SUB
Date Posted: 05 March 2009 at 11:07am
Everybody iv got a treat for you, im selling an RE Audio XXX Sub which is LOUDDDD!!! if you want more details email me or look at my sale on ebay http://cgi.ebay.co.uk/RE-Audio-XXX-Subwoofer-Viper-Mono-Block-1200D-Amp_W0QQitemZ140304922565QQcmdZViewItemQQptZUK_Audio_TV_Electronics_In_Car_Entertainment_GPS_Car_Speakers_PP?hash=item140304922565&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318 - http://cgi.ebay.co.uk/RE-Audio-XXX-Subwoofer-Viper-Mono-Block-1200D-Amp_W0QQitemZ140304922565QQcmdZViewItemQQptZUK_Audio_TV_Electronics_In_Car_Entertainment_GPS_Car_Speakers_PP?hash=item140304922565&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
------------- Virsa Entertainment
Posted By: jonminns
Date Posted: 05 March 2009 at 12:23pm
Excuse me if I don't get too excited lol
Posted By: jonny4288
Date Posted: 06 March 2009 at 2:18pm
there very good car subs these :)
damn expensive though :P
Posted By: JohnnyPyro
Date Posted: 06 March 2009 at 7:05pm
good for SPL, dont rate the sound, ill stick to my JBL gti's
------------- Pyrotechnics... its not rocket science, well.... actually it is !! :o) Powered by MC2 & XTA
Posted By: Tip
Date Posted: 06 March 2009 at 11:13pm
You obviously havent heard one.
One of the best sounding car subs ever, but doesnt get as loud as some.
Posted By: SamV
Date Posted: 07 March 2009 at 3:03am
It's designed as a SQL sub, if it didn't sound good it wasn't installed properly. They go loooow but not as loud as some of the other supersubs.
Date Posted: 08 March 2009 at 10:18am
I have heard them i had 2, then swapped over to JBL gti's powered by an A6000Gti Crown amplifier.. only problem with the Gti subs is they are low current subs so only work well with the crown amp
Date Posted: 08 March 2009 at 3:06pm
when i brought this sub i put it up against the JBL gti, pioneer SPL, Kicker SoloX, orion HCCA,cerwin vega Vmax and JL W7 and the re audio xxx out done all of them, 10 tyms over for sound quality and also SPL and it also dropped lower, i tested these subs in a golf with the whole boot dynamateed and put a hifonics 2000D amp onto em re audio come out singing by farr
Posted By: MikeHunt79
Date Posted: 08 March 2009 at 5:24pm
One-Way, Linear Excursion -Xmax: 54 mm - anyone tried one of these in a horn?
------------- I'm English, and as such I crave disappointment. I actively seek it out.
Date Posted: 08 March 2009 at 7:14pm
neva heard of a Linear Excursion -Xmax: 54 mm what is it?
Posted By: gwarntek
Date Posted: 09 March 2009 at 12:30am
hahaha is it actually 54mm tho?
Even if its peak to peak each way, thats 27mm one way!! Intense!
Someones gotta try that
Posted By: SamV
Date Posted: 09 March 2009 at 2:45am
It does go 54mm one way and by god it's a sight to behold. Huge beasts though, massive baskets.
Posted By: Tip
Date Posted: 09 March 2009 at 9:10pm
It is linear xmax.
Measured on a dumax machine, but it is helped by the fact that the v4 uses a split coil design.
Posted By: DJkg
Date Posted: 26 April 2009 at 8:05pm
Ah, good ol car subs, the worst kind of subs out their. I really don't wanna piss people off, but car subs aren't made for quality sound, they are made to be noise makers. The REAL subs for quality, such as RCF, B&C, JBL Pro etc really are around 10-11 mm Xmax. All car subs are are basically big pistons compressing the air, no quality about that, and cmon, over 50 mm of Xmax? That would probably be the sloppiest sounding sub out their, it can probably play low, but has NO punch since it wouldn't be a quick in and out movement.
Posted By: SamV
Date Posted: 26 April 2009 at 10:57pm
As with anything it depends on the music you listen to, and as such you're install would represent that. The XXX as a sub is brilliant.
Posted By: Tip
Date Posted: 27 April 2009 at 4:15pm
They actually sound really nice, due to a motor design that maintains nearly as much force at +/- 50 mm xmax as when the cone is at rest.
The BL curve on these drivers is pretty much flat, not parabolic like most subs.
Posted By: torch1
Date Posted: 30 April 2009 at 4:45pm
I've got two 15" RE XE subs and love them, haven't heard the XXX but can only imagine they are a worthy big brother to the XE's
