wiring xlr's
Forum Name: Electro Frying Forum
Forum Description: Talk about drivers, processors and mixers
URL: https://forum.speakerplans.com/forum_posts.asp?TID=24720
Printed Date: 29 March 2024 at 6:48am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: wiring xlr's
Posted By: rich_gale
Subject: wiring xlr's
Date Posted: 07 March 2009 at 7:00pm
pin2 xlr-> rca(phono) centre pin
pin3 xlr -> rca(phono) barrel
is this right? ouput comes from the back of a mixer via the rca's into a crossover with xlr inputs.
cheers
------------- REFLEX ALL THE WAY.... (however, im playing with horns again...) That ok Mister Valiant? :)
Posted By: Joe Grime
Date Posted: 07 March 2009 at 7:11pm
http://www.rane.com/note110.html - http://www.rane.com/note110.html
Date Posted: 07 March 2009 at 7:28pm
cheers steve.
#17 looks like the right one for me. didnt know you have to ignore the shielding and just use the red and black (red and blue in my case).
Posted By: csg
Date Posted: 07 March 2009 at 7:56pm
In order to avoid droping 6db when going from balanced to unblanced, wire as:
( xlr) pin 2 hot - centre pin ( phono)
( xlr) pin 1 earth - screen ( phono)
( xlr) pin 3 cold - screen ( phono)
so, hot to hot, and common the screen and cold at the unbalanced end. Nothing else will work correctly.
Posted By: cnics
Date Posted: 07 March 2009 at 9:41pm
What he said.
Don't leave any of it floating.
------------- Rob Beech - Technical Director - Cnics Audio
Date Posted: 22 December 2010 at 10:14pm
cheers
Posted By: Pasi
Date Posted: 22 December 2010 at 10:16pm
so, hot to hot, and common the screen and cold at the unbalanced end. Nothing else will work correctly. |
And how does this save that 6dB?
Posted By: cilla.scope
Date Posted: 22 December 2010 at 10:46pm
The easy remember way is to think "XLR -- xcreen, live, return" pins 1, 2, 3
screen/xcreen is pin 1, live is pin 2, return is pin 3.
when connecting a balanced input or output to an unbalnced thingy ... you may be able to connect the two screens together, the two lives together and on the XLR end, connect the screen and the return (pins 1 & 3) together.
If the balanced end is any good, leaving the return (pin 3) unconnected should result in a drop of 70+db, If it only drops 6db, what you have is a very poor balanced input.
------------- My girlfriend thinks I'm a stalker. Well, she's not exactly my girlfriend yet ...
Date Posted: 22 December 2010 at 11:22pm
to feed a LMS (with xlr in's) a signal from a mixer with only unbalanced rca outputs can i just use pins 2 and 3 on the xlr, wired to the centre pin and barrel respectively? im really having to cain the mixer to get any real signal flickering on the front of the LMS... makes me wonder if this is right..
Posted By: kevinmcdonough
Date Posted: 23 December 2010 at 1:08am
hey
to explain more fully, you are changing between balanced and unbalanced, and you need different connections depending on what way you are going. Most of the replies here seem to have misunderstood you and think you are going from a balanced output to an unbalanced input.
In this case although this isn't what your looking for, for future reference, you have three pins on the balanced end and you need to somehow get them down to two pins at the unbalanced end. The "hot" pin two of the XLR is the main signal, and so this always goes to the centre pin of the RCA (or the tip of the jack if its an unbalanced jack).
You are then left with the shield and the inverted "cold" signal. The shield (xlr pin 1) will be connected at the XLR end and so there is no real reason to connect it at the RCA end it works just fine with one end soldered (and in some situations it is actually better to leave it only connected at one end helps stop ground loops). But you can also solder it to the barrel of the RCA doesnt really matter.
As for the "cold" signal, again you can choose. The unbalanced input cant do anything with it and if you connect it to the centre pin of the RCA it will cancel out the main signal and you will get silence, which obviously you dont want, so you can either connect it to ground and bus it away (good practice and your bet bet really) or just leave it unconnected.
BUT.........
what your looking for is to go the other way, from the unbalanced RCA to the balanced XLR. In this case, your going from two pins to three pins. Just like before the main signal is always the main signal, so the centre pin of the RCA gets connected to the "hot" pin 2 of the XLR. No big deal.
You now have the barrel of the RCA which is connected to the shield wire. Now the point of the shield wire is to pick up any interference, radio waves or random noise and keep it away from the main signal, bus it off to earth. But at the XLR end, pin 3 of a balanced XLR eventually gets blended into the main signal (look up what balanced is to understand why if your not sure) and so if you attach the shield wire here you have the possibility of introducing that noise that your trying to keep away back into the main signal, not good. So the barrel of the RCA should be connected through the shield wire to Pin 1, where it can get sent away to ground, and pin 3 should be left unconnected so as to not introduce anything unwanted into the signal.
k
Date Posted: 23 December 2010 at 1:13am
oh and in terms of having to pump the mixer, hopefully getting the correct wire as above will sort it. if not but check that you have the correct setting if it has a +4/-10dbu input selection, and also check you haven't accidental padded down or lowered the input level somehow.
k
Posted By: audiomik
Date Posted: 23 December 2010 at 2:12am
might be worth considering the actual circuit operation of Balanced inputs.
Firstly a 'Balanced Transformer coupled input': for an XLR input 'hot' (XLR pin 2) is connected to one end of the center tapped primary winding of the input Transformer and 'cold' (XLR pin 3) to the other end of this same winding. Ground (XLR pin 1) is connected to a center tap so for an unbalanced source signal in order not to short half of the input transformer winding then use pin 2 of the XLR as 'hot' and pin 3 as 'cold'. In this case there should be no connection to pin 1 of the XLR input connector. Alternatively 6dB of gain can be achieved if pin 3 of the XLR is left open circuit and pin 1 only is used for the ground/screen of the unbalanced signal source.
Secondly for an 'Electronically Balanced Input': These circuits are normally designed to operate either as Balanced (Differential) inputs or can be used unbalanced. For Unbalanced use, the 'hot' is used as the signal input and both 'cold' and Ground for the screen from an unbalanced source are connected together. (pins 1 and 3 on an XLR) This is most effective since the 'cold' or 'negative' input circuitry of a differential amplifier circuit used as the input when grounded provides 6dB of additional gain for the unbalanced signal. (assuming a unity gain differential amplifier input circuit which is most commonly used in this type of application).
Hope this assists Mik
------------- Warning! May contain Nuts plus springs, washers, screws, etc, etc.
Date Posted: 23 December 2010 at 2:18am
kevinmcdonough wrote:
hey
BUT.........
Nice try, but, sadly, incorrect.
Hint: with a proper electronically balanced output or a traditional transformer balanced output you will get naff all out of the phono if pin 3 is left unconnected ... remember in a properly transformer balanced output, if you only connect the "hot" end of the transformer coil, and leave the "cold" end floating you won't get anything at all out of the unbalnced end. "proper" electronically balanced outputs, confgiured to drives into 600R will correctly simulate this. You might well get away with it on poorrly designed electronically balanced outputs though.
Regardless of which way around it is going, screen should go to the sleeve of the phono and pin 1 and 3 of the XLR, live/hot should go from pin 2 .. should work in all circumstances.
Date Posted: 23 December 2010 at 2:23am
Firstly a 'Balanced Transformer coupled input': for an XLR input 'hot' (XLR pin 2) is connected to one end of the center tapped primary winding of the input Transformer and 'cold' (XLR pin 3) to the other end of this same winding. Ground (XLR pin 1) is connected to a center tap so for an unbalanced source signal in order not to short half of the input transformer winding then use pin 2 of the XLR as 'hot' and pin 3 as 'cold'. In this case there should be no connection to pin 1 of the XLR input connector. Alternatively 6dB of gain can be achieved if pin 3 of the XLR is left open circuit and pin 1 only is used for the ground/screen of the unbalanced signal source. |
Errm .. sorry, have to disagree there.
The screen is NOT connected to the centretap, in fact, usually, there is no centre-tap unless the device is phantom powered. The normal configuration for a transformer balanced input is simple the two ends of the primary, one to pin 2 , the other to pin 3. If you leave pin 2 or 3 diconnected, you will get naff all. You shold be able to measure several megaohms between pin 1 and pins 2/3 in a normal, non-phantom, balanced input.
Posted By: audiomik
Date Posted: 23 December 2010 at 2:31am
just to pick up on this point on getting unbalanced signals from electronically balanced outputs, some circuits are specifically designed to provide a 6dB increase in output signal when used in unbalanced mode by shorting one of the outputs to ground locally at the output (usually the '-' or cold)..... this then retains the full signal level weather balanced or not.
Probably not used though on low cost kit Mik
Posted By: audiomik
Date Posted: 23 December 2010 at 2:39am
Re: The screen is NOT connected to the centretap, in fact, usually, there is no centre-tap unless the device is phantom powered. The normal configuration for a transformer balanced input is simple the two ends of the primary, one to pin 2 , the other to pin 3. If you leave pin 2 or 3 diconnected, you will get naff all. You shold be able to measure several megaohms between pin 1 and pins 2/3 in a normal, non-phantom, balanced input.
Normal configuration for 'floating' balanced line isolated inputs using transformers is what I refer to. Do agree that in some instances the CT is left open circuit, however with long cable runs this can cause problems with CMRR..... - 'voice of much experience'! Mik
Date Posted: 23 December 2010 at 9:44am
hey
BUT.........
Hint: with a proper electronically balanced output or a traditional transformer balanced output you will get naff all out of the phono if pin 3 is left unconnected ... remember in a properly transformer balanced output, if you only connect the "hot" end of the transformer coil, and leave the "cold" end floating you won't get anything at all out of the unbalnced end. "proper" electronically balanced outputs, configured to drives into 600R will correctly simulate this. You might well get away with it on poorrly designed electronically balanced outputs though.
interesting. I'm not an electrical engineer by any means and have never read up on the actual transformer side of things so bow to your knowledge, but this is the way I have always done it (only when going from an unbalanced output such as a DJ mixer or CD player etc into a balanced input) into everything from berry desks all the way up to big boy Midas desks and XTA crossover etc, (so i assume not cheap inputs) and never had a problem.
k
Date Posted: 23 December 2010 at 12:35pm
A decent electronic balanced to unbalanced input, should not produce any output with only one leg connected. The cheap units simply feed each pin into an op-amp (one inverting, one non-inverting input) and take the difference of the two signals. This is OK to a point, but doesn't correctly mimic the current flow in a true balanced circuit (ie, a bit of unblanced current injected into the "hot" pin should flow through the input circuit and back out the "cold" pin. Not a problem on short runs, but can seriously mess up the CMRR on longer feeds and produce noise in some situations.
The top class inputs (have a look at the input circuit on Sony broadcast kit) will not produce any output, as the op amps are cross connected on the input pad to mimic this current flow, if you leave pin 2 or 3 floating, nothing comes out. They also take the trouble to do this on their output circuits, if you ground pin 2, pin 3 goes up 6db. I have seen similar circuitry on other top-end gear, and as I said, on traditional transformer balanced gear it works this way.
On kit with cheap input circuits, you will get away with it, personally I would ground the pin anyway, for the day it gets plugged into somethig with a transformer input and no one can figure out why it works in this bit of kit and not in this bit of kit ...
Posted By: Louder than loud
Date Posted: 23 December 2010 at 12:37pm
just wire them all together
Posted By: demanddeepbass
Date Posted: 23 December 2010 at 12:52pm
If you leave pin 3 floating on the input of a soundweb green they can blow the input op-am. Not seen this on any other piece of kit but I always ground pin 3.
------------- "These amps go up to 11"
Posted By: audiomik
Date Posted: 23 December 2010 at 3:07pm
I remember that Switchcraft used to do XLR line connectors with small slide switches built in - used to find them useful for a switched attenuator when needing to better match signal levels.... Think if these are still available then the switch could be wired to provide an on/off link between pins 1 and 3, thus solving the potential compatibility problem between the different inputs being described in this thread.
These were the sort of useful bits, together with the really useful Switchcraft kits to interconnect between many different things that I used to buy at Future Film Developments in Wardour Street. I understand they are no longer there but might still be trading somewhere else.
By the way, does anyone know if those Switchcraft 'adapter kits' are still available anywhere? Mik
Date Posted: 23 December 2010 at 8:05pm
Louder than loud wrote:
just wire them all together |
problem solved.
Date Posted: 23 December 2010 at 8:07pm
I thought FFD moved to Uxbridge some time ago ... still, they were always a purveyor of decent bits, used to use them for jackfields and musa patch panels and the like.
