Yet another MT121 Build
Category: Plans
Forum Name: MT122
Forum Description: Discussion / Questions about the MT122
URL: https://forum.speakerplans.com/forum_posts.asp?TID=25489
Printed Date: 27 March 2026 at 11:01am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Yet another MT121 Build
Posted By: Sequence Empire:::..
Subject: Yet another MT121 Build
Date Posted: 31 March 2009 at 10:50pm
Just about to start with the cutting on my companies Laser Cutter all the parts to make two MT121 Cabs loaded with P-Audio SN12B and Beyma cp750Nd's/TD460n horns
Plans drawn up with my idea on the MF Horizontal Flare
Will post some photo's up as the parts get cut, also have a custom grill panels coming from our Finn Power Turret Punch where I work, 2500 hits with a dia 8.2mm punch done in around 8mins
Open to discussion on the curved section for the flare. I intend to form and laminate 3 layers of 4mm ply over some formers, idea derived from the speakerplans readers project HD15 curve lamination photos.
Wish me luck! These will be going above Lab subs and Usb's
Date Posted: 29 April 2009 at 1:30am
Parts all CNC Router cut last night, I'll be posting up some photo's of them when I get home from work, cannae wait to start building!
Jim
Date Posted: 29 April 2009 at 10:28am
Right, heres a few quick shots of the router cutting & quick mock-up of the cab & showing off the grill
Get the table saw up & going this weekend to get bevels done then start dry fitting parts
tbc
Jim
Posted By: H...
Date Posted: 29 April 2009 at 12:29pm
Lovely grill work there fella!
------------- Don't worry F$cked up bigger gigs than this one...........
Posted By: cravings
Date Posted: 29 April 2009 at 12:50pm
Posted By: TDA-Audio
Date Posted: 29 April 2009 at 7:55pm
very good work
------------- horns plans http://photofile.ru/users/tda-audio/
Date Posted: 29 April 2009 at 9:09pm
TDA-Audio wrote:
very good work |
Inspired by your MT121 pics good sir!
Posted By: shadow1
Date Posted: 29 April 2009 at 10:21pm
Those grills are wicked.... I could do with some grills like those, wink wink !
Posted By: Saul
Date Posted: 29 April 2009 at 10:23pm
CNC cut wood will give you a brilliant finish!!
Posted By: studio45
Date Posted: 29 April 2009 at 10:54pm
Flex, bling, brap, and any other of the yoot'dem term to describe extreme goodness. Wish mine looked as good! Grille like that is about £50 a sheet in bnq
------------- Studio45 - Repairs & Building Commotion Soundsystem -Mobile PA
Date Posted: 01 May 2009 at 1:26am
Top & bottom panels pre-drilled last night, 12mm ply plant ons glued in place, SN-12B's on their way to my door...
Jig to form the horizontal dispersion parts of the mid freq flare constructed, see how the Lamination goes...
Cheers to all for the positive words first build of this scale, happy I've invested in quality ply & cnc router cutting this far
Date Posted: 01 May 2009 at 1:41am
shadow1 wrote:
Those grills are wicked.... I could do with some grills like those, wink wink ! |
Try a sheet-metal engineering shop in your local area if you want a custom design. Someone proficient with AutoCAD can draw up the profile for you, my grills were manufactured on a Turret Punch where I work. If you find a company with a Turret Punch & do a little research as to what tooling is available there, as working with what they have available will see the initial design go through to produce a really good end result. The holes in my design are 8.2mm dia, on 12mm circular pitch centre.
Date Posted: 10 May 2009 at 8:30am
Achieved this weekend... Bevel cuts Delivery 2/4 SN-12B Ordered 4 x Beyma CP750Ti
Two cabs dry fitted & screwed, Glue up im a f**kin screw up next weekend I hope! Jim
Posted By: jethrocker
Date Posted: 11 May 2009 at 4:20am
Really nice build there..
Posted By: gwarntek
Date Posted: 16 May 2009 at 12:44am
Nice build :)
I want those grills!! If anyone is up for getting some like that done, i'd be up for four
If i get any spare time i might check out the possiblites
Edit: markie if youre reading this, is this kinda custom punched thing available through you?? Im kinda guessing not, but just incase you may know someone?
Posted By: LjudLahger
Date Posted: 16 May 2009 at 8:47pm
Posted By: asaa00
Date Posted: 16 May 2009 at 10:13pm
glue up a f**kin screw up, got in-tro-duced to the game, bought a sub, and f**kin blew up.... :p
Date Posted: 16 May 2009 at 10:39pm
Posted By: asaa00
Date Posted: 03 June 2009 at 4:20am
thats f**king sexy-- would you happen to still have the files you used to cnc these? :p
Posted By: Father-Francis
Date Posted: 03 June 2009 at 8:00am
+1
------------- Music is the strongest form of magic.(+45 31879997)blakmanpro@gmail.com, foa@sweetboxaudio.dk
Date Posted: 03 June 2009 at 11:39pm
Thank you people! I aint much of a photographer but I'm very happy with the cabs this far.
The curved section is made in a jig from 3 laminates of 4mm 3-ply. First one split a little so had so sand it back to smooth curve again, the second one came out as good as I could have hoped for! Ill be getting another 4 x cabs CNC cut in the next few weeks, going for 6 in total now
Arrived yesterday 4 x P-Audio PH-4528 2" horns so I can now spend some time getting these finished!
I do have the 2-D AutoCAD .dxf files I used for the router cutting at work, I can email the dxf's if you drop me a private message.
Peace Jim
Posted By: psytron
Date Posted: 05 June 2009 at 7:05am
1 sn12mb : 1 cp750ti <-- you aint never gonna blow up your comps :)
I find 2 sn12mb : 1 cp750ti the mid section starts barking before the comp ever raises a sweat :) (mt122)
Posted By: Tekasis
Date Posted: 05 June 2009 at 1:17pm
Very nice looking so far.
------------- **Heavy Weight-Line**
Date Posted: 05 June 2009 at 10:58pm
Interesting info there Psytron, alternative??? I don't at all mind the idea of having my comp's running well below their limit, blowing them up was not the plan lol
Posted By: psytron
Date Posted: 05 June 2009 at 11:07pm
Cant say i have an alternative but this is an expensive driver (at least i paid a bit for it) for a single 12 section perhaps you only need about 60w for a similar efficiency comp.
to my ears the 750ti does not quite come down low enough to meet my 12's dont take this as a final word as i am still playing with it :)
Date Posted: 06 June 2009 at 2:47am
What are you running on the sub/bass & where are you crossing up sub/bass > 12's > 750ti ???
Posted By: soundcraft2208
Date Posted: 04 April 2010 at 9:10am
nice and simple build, powerful! thanks for sharing i love it!
Posted By: Imperialsoundsystem
Date Posted: 07 April 2010 at 2:00am
Amazing build quality, cnc cutting looks the business!
------------- The only way of finding the limits of the possible is by going beyond them into the impossible.
Posted By: soundguymatt
Date Posted: 07 April 2010 at 9:44am
very nice indeed, (wonders if i can get a cnc router? hummmm...
Posted By: streetsounds
Date Posted: 07 April 2010 at 11:28am
very professional looking, how did you do the nice curve on the flare.
------------- Bass matters...
Posted By: huai0592
Date Posted: 21 May 2011 at 3:25am
I am a newer here. Glad to meet u. http://office2010sale.blogcindario.com/2011/05/00003-office-2010-using. - Office 2010 Using Just you know why!
Posted By: djeddie
Date Posted: 21 May 2011 at 10:39am
Thanks for that, dumbass.
------------- Chas n Dave : it's like Drum and Bass but with beards. E=mc² ±3dB
Posted By: Muckerbarnes1
Date Posted: 21 May 2011 at 10:55am
Too funny Ed.
------------- Billy Dawg.
Posted By: Meat
Date Posted: 21 May 2011 at 11:05am
Very nice build there. CNC does look to be the way forwards. Now, if I could find a place to CNC wood in my region...
------------- Don't test the champignon sound
Posted By: discosucks
Date Posted: 25 April 2012 at 3:13am
love to see how this ended up?
Posted By: stoeprand
Date Posted: 23 February 2013 at 7:47pm
+1 Verry nice indeed! And do you still have the dxf's?
