Push pull sub bass cabs
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=2596
Printed Date: 27 March 2026 at 8:46am
Topic: Push pull sub bass cabs
Posted By: MARTYNJONHALL
Subject: Push pull sub bass cabs
Date Posted: 11 September 2005 at 10:36am
anyone got designs for a double 18" push pull sub bass cab?
Posted By: stereokiller
Date Posted: 11 September 2005 at 3:57pm
Hi
i did about ten years ago a clamshell design with two Fane 15B in a bandpass enclosure. Size was 50x50x57 cm and it was flat from about
33 Hz to 120, sounded absolutely marvelous, very fast response and really low. the only (and the biggest) problem was that is was missing absolute SPL, which meant that it wasnt made for live purposes unless stacking a ridiculous amount of subs, which wasnt an issue at this time budgetwise. if you are interested, i can try to get out old infos.
i may even have the plot i did at this time, with a neutrik system (no sim).
basically you should be able to make a sim with winISD, which will give you already an idea.
Posted By: Timber_MG
Date Posted: 11 September 2005 at 4:06pm
Using the same drivers would result in more cleaner output (assuming your chosen design goal isn't maximally flat response in the same size enclosure). Clamshell designs generally mean incorrect driver choice in my book as the acoustic output is the same as one driver.
Posted By: _djk_
Date Posted: 12 September 2005 at 5:22am
I've built nothing but push-pull subs for the last 20 years or so. Dual and quad 12s, dual 18s, and lots and lots of dual 15s.
None were clamshell, that is a waste of time, money, efficiency, and output.
The box design must be specific to the T/S parameters of the driver you want to use.
djk
Date Posted: 12 September 2005 at 6:23am
You mean with the two drivers facing in different directions wired out of phase to cancel some distortion products? That does make sense (assuming the enclosure is vented, or more specifically the air temperature around the motor assembly is resonably similar)
Posted By: _djk_
Date Posted: 13 September 2005 at 6:07am
Kind of like this:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=7339275215&category=47094&rd=1 - http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=73392 75215&category=47094&rd=1
This was a box EV came out with after I talked with one of their engineers at a trade show about 20 years ago.
EV showed me the light in 1974 with the Interface A, an SBB4 alignment with a Q=2 filter ahead of the amplifier, so it became a B6.
All my best vented designs were assisted B6 or C6 after that.
Around 1980 a friend of mine that was a FOH engineer with dB Sound turned me on to the (then) unreleased MTL4 design. I thought it was cool, but didn't like the short x-max 18s (I don't like 18s in general), and didn't want to have to use a fork lift to move it.
I built a half-height design with two 15s facing each other on a narrow slot. On one of the pair I mounted the drivers push-pull (the reversed driver hooked up out-of-phase electrically).
This sounded so different I thought it sounded funny (at first).
It sounded funny because it had no distortion. It made a large 40hz bass horn sound distorted in comparison. I had Eminence custom make me a large x-max 15 that had the same volume displacement as a good 18 (and went lower).
Now, of course, we see push-pull boxes from EAW, TAD, etc, although I have not seen any exactly the same as the ones I made.
I took an engineering type job (doing L-band RF stuff for the military) about seven years ago and haven't really made anything much since then. I've been thinking it may be time for another production run as some of my old used boxes are trading hands for more than I sold them for new.
djk
Date Posted: 13 September 2005 at 7:17am
Perhaps an introduction might be in order?
The two drivers are loaded by a cavity (resonance) which might make for some interresting effects a little higher up the frequency spectrum.
Date Posted: 13 September 2005 at 3:48pm
I was looking for designs for somthing like these :-
http://www.smartsounddirect.com/content/ProductDetails.asp?ProductID=SSD1013 - http://www.smartsounddirect.com/content/ProductDetails.asp?P roductID=SSD1013
Posted By: _djk_
Date Posted: 15 September 2005 at 3:16am
"The two drivers are loaded by a cavity (resonance) which might make for some interresting effects a little higher up the frequency spectrum."
It does limit the useable HF response. The EV MTL4 has a huge (6dB) cavity resonance at 160hz, they EQ it out in the dedicated electronic crossover.
With careful design I can get mine to where you can cross them at 250hz without a peak.
smartsounddirect.com looks like an EAW clone. Simple to design and build.
djk
Posted By: LunchieTey
Date Posted: 15 September 2005 at 7:28pm
It's just a simple ported cab with one driver reverse mounted and inset. If you can use a pencil,ruler,win isd and a calculator(for volume) then just design one yourself.
Speaker addict
Posted By: billc
Date Posted: 14 November 2005 at 8:17pm
hey i was thinking of puting some jbl 2226s into a push and pull cab as subs. idealy i want a flat responce right down low and a high sensitivity (im shure thats all designers dream). i think they will be used for smaller spaces so i dont think horns will be good for this?
im fairly new to speaker design. i built some bass reflex cabs and they sounded good so i have some experience. im studying as an engineer so i have ability in involved calculations so i would like to get right in to it all tho time is scarce right now
can anyone suggest how i might go about tackeling this design? or info on this sort of design?
billy
Date Posted: 15 November 2005 at 3:38am
You won't get high sensitivity from compound loading. In reality,you won't do a whole lot better than 6th order bandpass. The only reason you would want to compound load is if you needed REALLY small boxes. If you can make a pair of 6th order cabs(space wise) you will get as much output as possible.You would even do ok from large ported boxes.
The compound cab might be able to get a little lower but at the expense of output(power divided by 2 drivers and you can only 'hear' one). If you were to build a large compound cab,driver control(excursion) would be a little limited and you will run out of cone travel early with low power(and output)
Speaker addict
Posted By: ceharden
Date Posted: 15 November 2005 at 8:37am
Sounds to me like there is some confusion between push-pull using two drivers in a double cabinet but one reversed to cancel non-linearities in the motor and isobarik compound loading (two drivers stuck together, usually face to face).
The former will perform like a normal twin driver cabinet but benefit from some reduction in distortion.  The latter roughly behaves as one driver with a stronger motor, lower resonance and is described above by LunchieTey.
Sorry for the spam if nobody was actually confused on this!!!
Posted By: Mircea Bartic
Date Posted: 15 November 2005 at 8:44am
I was on my way to post the exact same thing
it seems there is indeed a confusion between theese tipes of loading
http://www.facebook.com/nexus.acoustics.research" rel="nofollow - http://www.facebook.com/nexus.acoustics.research
Ex Nexus_3
