RE Driver Sims - Criteria for top 5?
Category: Plans
Forum Name: HD 15 horn
Forum Description: Discussion / Questions about the HD 15 horn
URL: https://forum.speakerplans.com/forum_posts.asp?TID=2625
Printed Date: 27 March 2026 at 8:46am
Topic: RE Driver Sims - Criteria for top 5?
Posted By: Dave Slater
Subject: RE Driver Sims - Criteria for top 5?
Date Posted: 15 September 2005 at 3:07am
i'm thinking that the driver sims thread is going to get a little out of hand however i believe it's going to be best to have as many drivers as possible in there if only to stop the 'is this driver suitable?' threads
what we need then is a top 5
suggest some criteria for me to start whittling them down
obviously i'll be simulating them again with full power to check cone excursion etc but there's far too many to do them all
i'm thinking
4" voice coil
high power rating (>500W)
high sensitivity (>98dB)
large Xmax (>7mm)
high EBP (>150)
i figure the actual power rating is largely unimportant it's more about the output at Xmax i'm just wanting to weed out some that blatently aren't contenders (i'll post the power required to reach Xmax in the results)
anything else or do you disagree with my starting figures?
Posted By: norty303
Date Posted: 15 September 2005 at 8:12am
I think Power >=500w or you'll omit some classics (PD154?)
How about including some good drivers for those not chucking loads of power at em too.
But yeah, a top 5 would be cool, although it'll be subjective as some have very high peaks around 100hz but poor response curves so someone'll have to decide what characteristics are more desirable
e.g. one with a high peak and fast rolloff would be fine with subs underneath but one with a flatter response with slower rolloff/lower response would be better with just HD15's
My laser stuff: http://www.facebook.com/SubsonicSystems" rel="nofollow - Frikkin Lasers
Posted By: tb_mike
Date Posted: 12 October 2005 at 11:31pm
Id do a dozen max of the most popular and if people want to do their own they should feel welcome.
