MT122 B&C
Category: Plans
Forum Name: MT122
Forum Description: Discussion / Questions about the MT122
URL: https://forum.speakerplans.com/forum_posts.asp?TID=2694
Printed Date: 26 March 2026 at 10:56pm
Topic: MT122 B&C
Posted By: SteveSmith
Subject: MT122 B&C
Date Posted: 26 September 2005 at 7:50am
I have four B&C 12PE32 drivers. Does anyone know if they will work in a mid horn? I read rog's faq, its seems they will perform well at least in the low mid. I like using them up to 4.8k though
steve
Posted By: ceharden
Date Posted: 26 September 2005 at 9:17am
A brief glance at the specs suggests they'd be good in a mid-horn such as the MT122.  Going by the manufacturers response plot I wouldn't recommend using them that high tho.  1.5k is as high as you can go before hitting some nasties (6dB notch at 2k then peaky up to 4k before rolling off).  I'm sure in an MT122 with a 2" comp driver (you'll need a meaty one to keep up) crossed at say 1.2k they'd be great.
What d'ya reckon about sticking them on porn horns anyone?
Date Posted: 03 October 2005 at 5:54am
thanks for your reply, ive got some p.audio cd's that work well from 1.2. Ill wait and see if anyone mentions the porn horns
steve
Date Posted: 20 December 2005 at 6:39am
Ive also got two B&C 12PL32's, I think theyre called the 12PLB76 now or at least theyre similar. Id like to build two seperate mid horns for them, does anyone know if they will work in the mt122? I need good response from 180hz up to maybe 1200hz or 2k
steve
Posted By: BharatBajaj
Date Posted: 02 January 2006 at 3:01am
Hello,
 I've made four Mt122's with B&C 12PE 32. On Highs I've used B&C ME60 Horn and De750 Compression Driver. I'am using Drive rack PA with QSC Plx amplification to run it.I drive it upto 1.25K.
i've used it twice (Live & Recorded Music ) worked really well with 1850 cabinets.
Date Posted: 03 January 2006 at 4:25am
thanks, Ill get building. will the 122's go down to 180hz?
Posted By: Mircea Bartic
Date Posted: 03 January 2006 at 4:41am
Yes
http://www.facebook.com/nexus.acoustics.research" rel="nofollow - http://www.facebook.com/nexus.acoustics.research
Ex Nexus_3
Date Posted: 03 January 2006 at 5:14am
Hello,
Yes they will go down till 180hz.
Date Posted: 04 January 2006 at 6:28am
ta thats great. Ive just finished building my first two 186's, theyre loaded with a paudio E18-600a, I havent had a chance to crank them up yet but they sound sweet right away. on high im using 4 b&c 12PE32's (direct) with 4 de12's. Im going to use the 2 12PL32's horn loaded 170hz to 390. I havent had a chance to test it all yet, im still building the tops. If it sounds ok Ill do an installation, its too heavy to cart around!!
What do the QSC plx sound like? worth getting over the rmx?
Posted By: PISSHEAD
Date Posted: 04 January 2006 at 6:57pm
Hi All,
POST YOUR PICTURES.......
The 'drunken master' strikes again.
Date Posted: 06 January 2006 at 3:38am
Hello,
 QSC PLX3402 would give you 1100 watts @ 4 ohms per Channel. hey are great on the Mids.As of Highs I'am Using FBT HP400 Amplifier,(100 watts @ 8ohms),great to drive DE750, single or Two per channel. Used to use PLX on 1850 Bass,clean but not so good,goes overload very fast. Overall I feel PLX is better than RMX. MT 122 looks big but is light weight. so is 1850'..
For the Basses I've tried Beta3 chinese amplifier. Its just Raw power.1600 watts per channel at 4ohms for about USD 1200.Got good damping factor.I'am happy with them,till I've fund to buy branded stuff.QSC ( PL Series)
Date Posted: 09 January 2006 at 8:20am
Ive got cs peavey mostly through. cs 1000x's on mid and on low mid and two bridged cs800's for bass. On highs ive got a rmx 850, which is clearer than the peavey. I havent had a chance to hear it all though
