JBL 2451 1.5" HF overkill for X15?
Category: Plans
Forum Name: X10, X12, X15 and XM15
Forum Description: Discussion / Questions about the X10, X12, X15 and XM15
URL: https://forum.speakerplans.com/forum_posts.asp?TID=27285
Printed Date: 27 March 2026 at 8:37am
Topic: JBL 2451 1.5" HF overkill for X15?
Posted By: Lincoln1
Subject: JBL 2451 1.5" HF overkill for X15?
Date Posted: 30 May 2009 at 1:06am
Hi Guys. I am slowly collecting gear and updating and increasing my old RCF tops. I will be building 4 x X15 using the SN15MB on woofer duties (already have these sorted), and wanting something high end on the HF. I have also some p.audip BMD 750 coming 2nd hand from across the ditch but may or maynot always use these for every gig.
Some JBL neo HF's have come up on ebay. They are a 2451H driver, second hand. These new are over a grand each!! Because they are neo the can be relatively cheaply posted. Most other jbl pro drivers are around the 10 or more kg mark each, just blowing budget on postage alone.
Question is, are these good? On paper they look great and are nearly the most $$ of the JBL range. Next question is, are they an overkill for an X15 build?
Reason is I am going thru a mid-life chrisis, living in a house that wont sell, and the retail therapy is keeping me sane. However if they are the ducks nuts and nothing else is as good for the money then I will proceed. It looks like a grandish for the two with horns as the buynow is just a but more.
Posted By: Lincoln1
Date Posted: 30 May 2009 at 1:09am
Just to add I see Ceharden recommended the 18sound drivers, along with beymas on HF for a sttep up in quality. So if these are of the same audible quality as the JBL's then please let me know as it's double in $NZ!!
Posted By: ceharden
Date Posted: 30 May 2009 at 10:12am
I don't have any experience with the JBL's but I'm sure they'd do the job.  They are probably overkill and over-priced.  Overkill is never a bad thing but if you have to pay over the odds for it, it's worth considering alternatives.
Which driver manufacturers can you get at a good price?
18Sound, B&C and Beyma are the manufacturers I would normally look to for a decent compression driver.
Posted By: Lincoln1
Date Posted: 30 May 2009 at 11:22pm
Overpriced...I wondered that. My whole approach is a bit of value where possible. I dont mind any name if it sounds primo and doesnt go pop. Some JBL pro stuff does sound nice but if I am paying double for the name, then double again for exchange rate...Cry
As far as availability over here...well...I'm better to just buy off the US, as everything here is marked up and the states are the biggest marketplace thats closer than europe of the UK. There is only one p.audio dealer here which isnt that great and one is aussie which is good so they are a possibility. Just whatever is the best, within reason, within price. As far as that goes I dont really know what I want to spend. My RCF N481's 1" I've had for years are still OK, but they are passively crossed too low and the horns add some nasal sounds. I see anything similar is now worth heaps. I am looking at possibly reusing them with new horns as they can play down to 1kHz recommended, and are quite grunty.
Actually it was Calitri that had this recommendation with good quality HF's.
Quote "If you want to have high sound quality, well, there's always the 18Sound ND1480 or Beyma CP-755 with an 18Sound XR1464 horn which would give a superb sound quality and coverage but would be a bit pricy solution"
Posted By: Deadbeat
Date Posted: 31 May 2009 at 4:06pm
If you are in the US and looking for a good one, try BMS CDs from Assistance Audio. some of the DDS horns they sell are very good as well.
Away on extended leave.
Posted By: Lincoln1
Date Posted: 01 June 2009 at 3:22pm
Just another question (yes they keep coming), would just running 2 x comp drivers per 4 x 15's be good to go?
I mean if most HF's are either l-padded or 'turned down' at the preamp/amp stage, what is to stop you running the drivers without as much 'restriction'? ie running at 8ohms (not 16) say 100ish watts at say 106+ efficiency?, which most do these specs easily. The reason I ask is soon I will be staring at 4 x SN15MB's and see buying 4 x comps a whole lot more pricey than 2 x comps if all I am doing is turning the HF's down due to their high efficiency once on a decent horn?!
If this is the case I can prob afford to go more pricey on just 2 quality HF drivers and be done with it. Or even extend the X15 to take 2 x 15's each. Comments please.
Posted By: ceharden
Date Posted: 01 June 2009 at 4:14pm
2x15" per compression driver will be fine, especially if you're using decent HF drivers.  Redesigning the X15 to be a 2x15"+2" would be fine.  Might as well just start from scratch though.
Posted By: CLsystems
Date Posted: 06 June 2009 at 7:30pm
the Jbl's are overpriced.
Date Posted: 11 June 2009 at 5:28pm
^ ditto...very nicely built,but way to expensive. The only way to buy them is second-hand...the price drops from about a grand each new to a more realistic £200 a piece..at that figure they make more sense.
Posted By: Lincoln1
Date Posted: 22 June 2009 at 7:17am
Another set of p.audio 1.5" drivers are being sold by oceania here in NZ. Has anyone had anything to do with these p.audio SD 995N HF drivers? They seem to be the upper limit power-wise etc of p.audio ND 1.4" series.
http://www.trademe.co.nz/Browse/Listing.aspx?id=225320944 - http://www.trademe.co.nz/Browse/Listing.aspx?id=225320944
If I can get 2 for a grand and they're good then I might be onto something...
Posted By: Mircea Bartic
Date Posted: 22 June 2009 at 7:54am
Can you get P-audio WN-D63 , WN-D72 over there?
http://www.facebook.com/nexus.acoustics.research" rel="nofollow - http://www.facebook.com/nexus.acoustics.research
Ex Nexus_3
Posted By: Lincoln1
Date Posted: 22 June 2009 at 10:17am
I dont think so..Theres always the SD740NWink . Since rog specified them they must reasonable. I guess I dont mind spending a bit of extra money on the HF, as its not an area I like skimping on...
Forgot to ask, do u recommend those drivers? I havent come across those numbers before..
