XTro Powering and Delay settings Help
Category: Plans
Forum Name: Punisher and X-tro
Forum Description: Discussion / Questions about the Punisher and X-tro
URL: https://forum.speakerplans.com/forum_posts.asp?TID=27801
Printed Date: 26 March 2026 at 10:04pm
Topic: XTro Powering and Delay settings Help
Posted By: yodominic
Subject: XTro Powering and Delay settings Help
Date Posted: 15 June 2009 at 9:55am
Recently bought a pair of Xtros loaded with the following drivers
1" = B&C DE500 on TD245 horn
8" = B&C PE21 + Mykeys horn
15" = B&C 15NW76
Need a bit of advice as to which ampliers to choose them to power and the delay settings. I have the following amps already and will be using a Beri Ultradrive
QSC RMX 2450
EV P1250
Also will be using 2 * B&C TBX100 per cab loaded subs underneath them powered by a Void Inf 8 mk1.
Posted By: illex
Date Posted: 15 June 2009 at 11:37am
there should be a .doc file with delay and gain-eq settings  on the speakerstore.nl site at the punisher design
Posted By: dlyxover
Date Posted: 15 June 2009 at 2:09pm
found this on the net, hope it helps
2x Punisher/1x X-tro processor settings
All filters 24db/oct Linkwitz/Riley
sub
hp: 40,5 hz (For a single cabinet a side  45Hz can be used)
lp: 91,0 hz
low
hp: 99,2 hz
lp: 297 hz
mid
hp: 315 hz
lp: 2,38 khz
high
hp: 2,45 khz
Delay
sub
0
low
5,99 ft
1,82 mtr
5,31 msec
mid
6,81 ft
2,07 mtr
6,04 msec
high
7,21 ft
2,19 mtr
6,40 msec
sub1
40-50Hz (depending on number of cabinets)
gain: personal taste
Q = 3-4
sub2
105 hz
-1,0 db
Q = 4,410
mid
2,25 khz
+ 4,0 db
Q = 1,215
high
14,3 khz
+1,0 db
Q = 1,789
Lignum_ww@icloud.com
GNKaudio@icloud.com
Posted By: Sinfinity
Date Posted: 15 June 2009 at 6:43pm
I seem to remember that from a while back.
I think this information was written before mykey developed the xt8's.
I dont think it takes the mykeys phase bunged xt8 into account so you may need to tweek the 8" section slightly.
Congratulations yodominic, that was a cracking buy. I have a pair myself which I am looking forward to hearing for the first time tomorow night.
Matt at ukamp dot co dot uk
Posted By: Saul
Date Posted: 15 June 2009 at 8:03pm
what kind of tweaking do you think is needed then? Higher xover? I'm finally getting my XT8s tommorow!
Date Posted: 15 June 2009 at 8:08pm
I dont know yet, but I will know more on Wednesday night. Smile
Date Posted: 15 June 2009 at 8:10pm
I will use the above settings at a starting point but I am sure I have read somewhere that mykeys xt8 adds a bit of response to the 8". Im expecting to dial it down a fraction, but won't know for sure until I get a chance to play with it for a while.
Posted By: MessyM2k8
Date Posted: 15 June 2009 at 8:27pm
snap, was ment to get it today but dhl couldn't find my house. Can't wait looking forward to testing the xtro. I'm gonna try a turbosound Compression driver as i still haven't got my DE 500 yet (ordered it over a month ago).
Posted By: Saul
Date Posted: 15 June 2009 at 8:30pm
yeah snap on that too - Couriers are bloody useless soon as they see some countryside.
although i do live where the nearest house is 2 miles awayLOL
Date Posted: 15 June 2009 at 8:56pm
Thanks for the info guys, any recommendations on the amps to be used.
Date Posted: 15 June 2009 at 11:45pm
Im running mine from matrix.
Posted By: Mark James
Date Posted: 16 June 2009 at 1:03am
the delay setings will differ as you are using differnt bass cabs.
insert silly sentence here
Posted By: Saul
Date Posted: 16 June 2009 at 10:11am
well that's kinda obvious isn't it.
we were asking about the difference between the Original 8" horn, and the XT8.
personally i think delay wise, it'll be no difference, and eq wise, it might need reducing a tad.
