Mcgregor PW15
Category: Plans
Forum Name: Ported Enclosures
Forum Description: Post all your reflex and bandpass and 'other' boxes with holes in stuff here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=28516
Printed Date: 26 March 2026 at 9:25pm
Topic: Mcgregor PW15
Posted By: jonny4288
Subject: Mcgregor PW15
Date Posted: 07 July 2009 at 9:47am
http://www.mcgregoramps.co.uk/documents/utils.php?action=download&filename=PS_PW%20Speakers.pdf - http://www.mcgregoramps.co.uk/documents/utils.php?action=download&filename=PS_PW%20Speakers.pdf
Lo all, been offered four of the above cabs for a good price, would usually turn them down but the price is rather tempting. I believe they still have the original drivers in.
Could anyone recommend a replacement driver for these cabs,im trying to find tech specs to match a suitable driver, would like to stick a decent pd/paudio ect driver in.
only info in that pdf unfortunatly is
model pw15/600
Quote
BASS CABINETS - (CARPET OR PAINTED)
Bass cabinets can be used with full range enclosures to extend bass response and increase low frequency sound pressure. The McGregor range of dual chamber,
band pass cabinets are more efficient than the more commonly available tuned reflex types. Two way crossovers are fitted as standard and the crossover allows
parallel connection (4 ohm load) or two way crossover (8 ohm load) to additional cabinets.
MODEL DIMS MM IMP WEIGHT DRIVERS POWER X-OVER SPL RESPONSE CONNECTORS COVERING
PW15/600 710 X 494 X 445 8 ohm 30kgs 15” 600W 150Hz 100dB 45Hz - 400Hz SPEAKON CARPET
