handles on top/bottom
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=29065
Printed Date: 27 March 2026 at 8:37am
Topic: handles on top/bottom
Posted By: breakdabeat pete
Subject: handles on top/bottom
Date Posted: 23 July 2009 at 1:32pm
getting to the stage where i should be putting handles in
instead of carrying the horns with one person either side which makes it hard to get through average doors in the house i was wondering if i could put handles in the top/bottom
iv seen cut outs on the bottom of horns before and wondered if this changes the sound much??
heres a example of cut outs on the bottom panel
http://photos-b.ak.fbcdn.net/hphotos-ak-snc1/hs049.snc1/4451_81702670269_832620269_1713745_7859840_n.jpg - http://photos-b.ak.fbcdn.net/hphotos-ak-snc1/hs049.snc1/4451_81702670269_832620269_1713745_7859840_n.jpg
٩(̾●̮̮̃̾•̃̾)۶
Posted By: Wrighty
Date Posted: 23 July 2009 at 2:30pm
The major problem you'll have with this is putting handles in the top, as there's not a lot of space and any protrusions into it would alter the front chamber / throat characteristics.
ALL YOUR BASS ARE BELONG TO US.
Posted By: Saul
Date Posted: 23 July 2009 at 3:29pm
handles on the end of the horn mouth wont make any difference, handles on top is a little bit more tricky. Easiest thing is to put them into the dead spaces.
you dont have to put a little box on the back of them then either.
Posted By: biotec
Date Posted: 23 July 2009 at 4:29pm
I've had 1850s in the past with both types of arrangement. The only way of getting handles in the top of the cab without protruding excessively in the throat of the horn is to use the flip out type handles. If you use decent heavy duty ones from penn they are plenty man enough for 1850s but just make sure that you rebate them sufficiently so that rubber tube on the handle doesn't stick out from the surface of the cabs.
If I was to build 1850s again I would use both handle arranegemts, I would use two bar handles on each side and two flip-out handles on each end.
Having handles on the ends makes going though doors much easier as you say but also makes it much easier when stacking cabs 2 or 3 high on their sides; you can lift and tip the cab without having to lift it from underneath.
Having the bar handles on the sides makes getting the cabs into vans much easier though.
Posted By: drivebycar
Date Posted: 23 July 2009 at 4:43pm
What cabs are you building pete?
Posted By: Silas ))))))
Date Posted: 23 July 2009 at 6:52pm
I put handles in just the sides on mine and yer never really use them, I probably wouldn't use them on the top or bottom either, its easiest to move just carrying  the bottom edge and then someone with the top edge on the angle. Easy - no handles needed
power in the blood
Posted By: Saul
Date Posted: 23 July 2009 at 7:02pm
if i was to build 1850s again i would put handles in the bottom of the horn mouth, and then some directly opposite in the dead space at the top of the horn mouth. This way, when theyre on their backs (on their castors), they can be lifted up over steps n stuff easily.
Posted By: Sinfinity
Date Posted: 23 July 2009 at 10:19pm
like this ?
Matt at ukamp dot co dot uk
Posted By: Saul
Date Posted: 23 July 2009 at 10:32pm
yep
Posted By: biotec
Date Posted: 24 July 2009 at 10:02am
I used to borrow 4 1850's which had this handle layout too (yes I loved 1850s!) and I always found that the handles were too high up the cabinet when it was on its wheels to lift properly. You keep banging your legs on the box and you have to lift your hands too high to cary the box at a comfortable height.
I found it most comfortable with the handles as near the back of the cab as you can put them without the box becoming unstable when you cary it. Slightly below the centre of gravity when they are on their wheels is fine but not too much.
Date Posted: 24 July 2009 at 6:51pm
186's which are replacing our c subs
my mate has some dual 15" reflexs to go under the 186's
still undecided about handles
the pull out ones look ok altho i would have to recess the wood 12mm to get them flat
if i get castors i will put them on the bottom angles panel wheelbarrow style
٩(̾●̮̮̃̾•̃̾)۶
Posted By: Jake_Fielder
Date Posted: 24 July 2009 at 8:02pm
15" reflex under 186s?
how many 186s r u building?
Posted By: kunak23
Date Posted: 01 January 2010 at 6:42pm
and is it possible to put black metallic handles??
