recent XTRO build
Category: Plans
Forum Name: Punisher and X-tro
Forum Description: Discussion / Questions about the Punisher and X-tro
URL: https://forum.speakerplans.com/forum_posts.asp?TID=29168
Printed Date: 27 March 2026 at 6:53am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: recent XTRO build
Posted By: Saul
Subject: recent XTRO build
Date Posted: 26 July 2009 at 11:07pm
finally bought a camera cable!
heres some recent XTROS with XT8 horns. 18sound 15nd930, b&c 8PE21, beyma cp380.
excuse the paintjob. they've only had one quick spraydown, waiting on new batch of paint to arrive.
fully biscuited, latvian birch. All went together beautifully, mitres were perfect - AutoCAD rocks.
they sound gorgeous.
and before anyone asks, the "X" in the brace DOES stand for XTRO  . The brace will be painted white to match XT8 horn.
they also have "xtro" routed across the back now, along with my build logo. Castors are fitted to the doors. for some reason i dont have a pic of the finished back.  , will take one in due course. maybe once ive given them a proper spray spatter finish.
http://img87.imageshack.us/my.php?image=dscf1959.jpg">
http://img229.imageshack.us/my.php?image=dscf1958.jpg">
http://img229.imageshack.us/my.php?image=dscf1957p.jpg">
http://img87.imageshack.us/my.php?image=dscf1953b.jpg">
http://img229.imageshack.us/my.php?image=dscf1949.jpg">
http://img229.imageshack.us/my.php?image=dscf1946rlv.jpg">
http://img195.imageshack.us/my.php?image=dscf1945.jpg">
http://img195.imageshack.us/my.php?image=dscf1938.jpg">
Posted By: Jake_Fielder
Date Posted: 26 July 2009 at 11:25pm
you should use photobucket, image shack give me loads of gip and adverts when i click on a pic!
looks really good though man
Posted By: Ryan94
Date Posted: 26 July 2009 at 11:30pm
lovely buid mate! im also loving the little finishing touches!
Posted By: stitchy
Date Posted: 27 July 2009 at 5:26am
nice build Saul top job have you tried it with the rhino you built?
Posted By: Saul
Date Posted: 27 July 2009 at 8:09am
stitchy wrote:
nice build Saul top job have you tried it with the rhino you built? |
yep, i have 4 Rhinos now, with 2 XTROs above= brilliant.
Posted By: AUDIO HABIT
Date Posted: 27 July 2009 at 8:25am
Very nice indeed!!! What is the horn in the middle for, does it have a com driver on it
------------- https://www.facebook.com/fxstageproductions
Posted By: Saul
Date Posted: 27 July 2009 at 8:26am
Posted By: AM55
Date Posted: 27 July 2009 at 8:30am
that looks precision, is it all cnced?
Posted By: Saul
Date Posted: 27 July 2009 at 8:37am
no not CNC'ed, i use AutoCAD for exact calculations, so all the mitres and panel lengths were spot on.
Posted By: Saul
Date Posted: 27 July 2009 at 6:00pm
next on the list, big pile of ES18s for live work/dance music.
Posted By: UpComingSound
Date Posted: 29 July 2009 at 8:54pm
whats a good xover to put in the xtro boxes?
Posted By: Saul
Date Posted: 29 July 2009 at 9:20pm
i wouldnt use a passive xover for these boxes. much easier to use an active unit
Posted By: Heathrow_B_line
Date Posted: 29 July 2009 at 9:28pm
why did you bother with biscuits?
fully rebated would have been worth the effort
what does a biscuit give that a steel screw doesnt?
good effort
------------- Produce a killer sound. Take no prisoners.
Posted By: TechnoChef
Date Posted: 29 July 2009 at 9:31pm
You can't dunk a screw in your .....
....sorry, wrong thread!
------------- I think I'm in love with your mum.
Posted By: Saul
Date Posted: 29 July 2009 at 9:42pm
good effort |
biscuiting gives the same effect as rebating by determining your panel positions and also adding a glued fixing between each panel. You then slide your panels on the biscuits so it stays in place (absolutely no movement), while you screw it down.
biscuited the whole lot for these two boxes in about 90 minutes. Strengh wise it just as strong - you can biscuit ply edge on edge, (with glue) and then stand on it between two tressels!
rebating takes a little longer.
Date Posted: 29 July 2009 at 9:50pm
good effort |
I tried rebating and its far too messy (dust and noise) and takes too long. I made a biscuiting template and biscuited the whole lot for these two boxes in about 90 minutes. Strengh wise it just as strong - you can biscuit ply edge on edge, (with glue) and then stand on it between two tressels!
So no, your wrong, rebating really isn't worth the effort.
On too many occasions, people say "my box is rebated", and everyone else then replies "oh well it must be a good build". Bo****ks!!! Some of the worst builds ive seen have been rebated.
If your getting ply CNC'ed then only then would i consider rebating, as you dont have to do the work! |
you miss my point young blud
rebating is indeed messy, noisy, time consuming but it can double gluing area [=stronger cab], increase the bracing effect to the entire cab [=stronger cab]
biscuiting is quick, looks pretty [so good for impressing the average joe], and as you have stated doesnt take too much effort.
it is your wood, your build, do what you feel is best
good effort
Posted By: Saul
Date Posted: 29 July 2009 at 9:57pm
good effort |
good effort |
i see your point, but really, the increase in glueing area is minimal, and the increase in the area of 20mm biscuits probably isnt far behind. i think that you've missed the fact that biscuiting also has all the advantages like rebating.
We all know that the glue is stonger than the wood itself, so even a properly made butt jointed cab should be up to the toughest beating. It's the clean mitres and tight joints that make a good build. The thing is, many people seem to ignore this fact, and think the fix on the ends of the panels is the only important bit.
thanks for comments anyway.
Date Posted: 29 July 2009 at 10:02pm
@hbl
For rebating to double the gluing area it would have to be 9mm deep (in 18mm cab) this would will be halving the thickness of the outside wall. are you sure it should be done that deep?
Posted By: Saul
Date Posted: 29 July 2009 at 10:07pm
Jake_Fielder wrote:
@hbl
For rebating to double the gluing area it would have to be 9mm deep (in 18mm cab) this would will be halving the thickness of the outside wall. are you sure it should be done that deep? |
very good point. rebating should really only go in a maximum of 5mm, cos as you say, you reduce the thickness in you side wall, and also, you then have to be careful about how deep your screw go. (i use an impact driver, and sometimes it still takes me by surprise!  )
Date Posted: 29 July 2009 at 10:12pm
glue is stronger then wood = true in the joints
but birch is best, the more birch in a cab with the least amount of pieces is best
but if it so strong why dont we build a cab out of 100% glue?
a good builder makes good cabs, be that rebated, butt jointed or biscuited
i stated the gluing area is almost doubled [assuming a 8mm rebate]. how is this minimal?!
draw it in autocad, biscuiting will locate the panel but take up valuable space which could have been taken up by a steel screw and provid no extra gluing area to the birch
Posted By: Saul
Date Posted: 29 July 2009 at 10:14pm
gand provid no extra gluing area to the birch
you glue them in
Posted By: Saul
Date Posted: 29 July 2009 at 10:16pm
anyway, this is completely off topic, and its a debate thats happenned many times before, and will go on forever.
MORE XTRO PORN!
Date Posted: 29 July 2009 at 10:20pm
good effort, i am sure they are strong cabs
Posted By: Strange Daze
Date Posted: 30 July 2009 at 1:40pm
Biscuits for the win... Nice build Saul... (ps- My faves are HobNobs....mmm...... <laughs>)
Posted By: shadow1
Date Posted: 05 August 2009 at 10:21am
Can't see any pics.
------------- Smile, the worst is yet to come.
Posted By: Saul
Date Posted: 05 August 2009 at 11:21am
ah, bummer, i deleted them from imageshack, i'll put them back on later....
Posted By: wash with gasoline
Date Posted: 05 August 2009 at 8:45pm
Nice, i saw the pics the other day. I am going to be building a pair in the next few weeks. I think i am going to use biscuits as well, in my opinion they are a good FAST compromise between but joints and rebating. What compression horn are you using? I can get the ones on the plan, but they are around $75 us each. Im just looking around for tested alternatives before i spend that much. thanks
------------- dry with match
Posted By: harold
Date Posted: 08 August 2009 at 8:17pm
What are those xt8 horns?
Posted By: Saul
Date Posted: 08 August 2009 at 9:08pm
http://www.janaudio.net/products/detail.php?cat=Fibreglass%20Horns%20and%20Speakers%20Cabinets&id=13&coll_page=1 - http://www.janaudio.net/products/detail.php?cat=Fibreglass%20Horns%20and%20Speakers%20Cabinets&id=13&coll_page=1
Posted By: harold
Date Posted: 08 August 2009 at 9:47pm
Ok thanks interesting site. Does someone know what the xt8 will do for the sound of the x-tro.
And they are allmost ready. I have 8 punsh. and 4 xtro's then loaded with the recommend drivers. Does anyone know how many people you can cver with this set outdoors?
Posted By: Saul
Date Posted: 08 August 2009 at 10:58pm
The original 8 inch wooden horn was always a weak spot in the XTRO cabinet.
The XT8s are much louder and sound very accurate and clear. They "complete" the xtro cabinet.
Posted By: thoams87
Date Posted: 12 August 2009 at 10:22pm
Lovely build there. I'm about to start some new cabs and I dont want to do rebating so these busciut joints look like just the job especailly for pannel allignment and working as a third hand. Any chance you can go into more detail or do a little guide on how you did the biscuit cutting and the jig used. I'm looking at the pics but cant really see how you'd do it fast and accurately.
Posted By: Saul
Date Posted: 13 August 2009 at 11:15pm
Posted By: Sheggy
Date Posted: 14 August 2009 at 6:17pm
Yeah, very nice "young blud" ( )
Are they for sale or personal use Saul?
Posted By: Saul
Date Posted: 14 August 2009 at 8:51pm
the ones in the pics are personal.
However i have built these for customers, and still do.
Posted By: harold
Date Posted: 15 August 2009 at 6:11pm
where do i ge the xt8 i send message to jan audio but got no reply??
Date Posted: 15 August 2009 at 6:14pm
I believe Robbo on here still has some?
Posted By: Deej
Date Posted: 15 August 2009 at 9:17pm
I wish. They havn't been available for months with no news as to when the next shipment is coming from mykey...
Posted By: Saul
Date Posted: 16 August 2009 at 1:27pm
gave them a proper test last night, with Jake fielders xp5000s on midbass and sub duty (custom ported horns )
Posted By: jonny4288
Date Posted: 16 August 2009 at 2:43pm
bet that was rather punchy :) :)
Posted By: Saul
Date Posted: 16 August 2009 at 3:16pm
just a bit, my left ear does hurt from standing a little too close.
i dont think the XP5000s ever registered more than -6dB either.
Date Posted: 17 August 2009 at 10:02am
Yeah, it was a good setup. After this i am seriously considering xtros.
Cos my cabs sound a bit poop above 90Hz.
The efficiency and sound of the xt8 horn really impressed me, as this is the first time i have heard xtros with no other midtops.
Posted By: Saul
Date Posted: 17 August 2009 at 11:50am
Posted By: loonie
Date Posted: 17 August 2009 at 8:00pm
Jake, do it, I've got 2, Saul has 2 if you got 2 we could cover some serious bass.
------------- Team DB
Date Posted: 17 August 2009 at 10:59pm
Sweet, its gotta be done!!
problem is i bet they're a tad pricy to load!!
Posted By: Saul
Date Posted: 17 August 2009 at 11:04pm
yes and no,
kappa 15s are cheap, and do a fairly good job. The ones you heard the other night are 18sound loaded. (these do cost a fair bit.)
8pe21s are reasonable
1" is up to you.
Posted By: mykey
Date Posted: 18 August 2009 at 6:17am
The efficiency and sound of the xt8 horn really impressed me, as this is the first time i have heard xtros with no other midtops. |
------------- ......just all them hanging there like giant bananas.
Posted By: angrykid
Date Posted: 01 January 2010 at 7:04pm
Your build looks the dogs mate. I'm wanting 2 XTro's built can you give me a quote?
Posted By: Sinfinity
Date Posted: 02 January 2010 at 2:19pm
angrykid wrote:
Your build looks the dogs mate. I'm wanting 2 XTro's built can you give me a quote? |
What do you want them loaded with ?
------------- Matt at ukamp dot co dot uk
Posted By: mr 4enzics
Date Posted: 07 January 2010 at 12:35am
hey, sinfinity do u think u could give me a quote also, would poss like to buy let me no the options...
mr 4enzics
------------- Techno - destroying forests since 1986
http://soundcloud.com/4enzic
Posted By: backlash
Date Posted: 07 January 2010 at 1:36am
Saul wrote:
gave them a proper test last night, with Jake fielders xp5000s on midbass and sub duty (custom ported horns )  .......
I reckon those X-tro's can keep up with twice that bass - damn they look smart there though!
------------- According to suicide statistics, Monday is the favored day for self-destruction.
http://www.truesoundhire.co.uk/" rel="nofollow - Sound Hire
Date Posted: 07 January 2010 at 8:30am
mr 4enzics |
I was asking your loading requirements so the builders on here would be able to give you an accurate quote.
Your probably best off chatting to the likes of Saul or Loonie. I believe they have both built for other people. There are other builders on this forum that may also be able to quote for you. I built mine with my Dad for personal enjoyment of the build as much as the listening.
Having said that they may well be for sale in about a month to free up funds for other projects.
Will post them in for for sale section as and when the dreaded time comes.
Posted By: Saul
Date Posted: 07 January 2010 at 10:06am
did you get my pm? I can do a rebated or biscuited or butted build - up to you.
Posted By: Saul
Date Posted: 07 January 2010 at 10:11am
I agree will. These things go LOUD!
Date Posted: 07 January 2010 at 11:23am
Saul wrote:
did you get my pm? I can do a rebated or biscuited or butted build - up to you. |
Hey no i dint get your quote although i checked my inbox a couple of times, would really like theses speakers maybe 2, also what are the oprtions gthat they can be loaded with?...
Posted By: Saul
Date Posted: 07 January 2010 at 2:06pm
hi sorry - it wasnt you who pm'ed me at all - so i wouldnt have PM'ed you - sorry, my mistake..
