12v portable soundsystem
Forum Name: 12v Powered Systems
Forum Description: From Mini-rigs to ICE, all your low voltage audio needs here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=29684
Printed Date: 26 March 2026 at 11:31pm
Topic: 12v portable soundsystem
Posted By: tektonik
Subject: 12v portable soundsystem
Date Posted: 13 August 2009 at 1:52pm
here are some pics of the start of another portable sound system
the cab kindly given to me by mark
the mid bass driver is a sn-12mb neo and a p-audio copy 1" compression driver for hf
im useing 4 12v 20ah sealed lead-acid batteries in parallel powering a active crossover and a alpine car amplifier. in put will be through phono plugs mounted in a panel in the back. more pics to follow
http://www.myspace.com/recyclesoundsystem
Posted By: Hemisphere
Date Posted: 14 August 2009 at 5:16pm
Each of those batteries is 20ah? They look so small!
Posted By: james folkes
Date Posted: 15 August 2009 at 10:51am
they aren't 20... i have no idea how large they are but i will bet a substantial amount on them being nearer 2 than 20, they are a lot smaller than the 7s i have sat in front of me now.
cool mission though, i feel a 12 volt speakerplans shootout is becoming inevitable! tektonik, are you building a bass cab to go with? i like the way you are incorporating all the power and electronics in the mid top cab, really smart use of space as you (i'm assuming) won't need the extension provided by greater cabinet volume.
good project!
james.
mardy hippy.
Date Posted: 16 August 2009 at 7:27pm
actually just noticed that block of wood is covering half of them! They probably are 20 - looks about the same as this http://cgi.ebay.co.uk/12V-20AH-SLA-BATTERIES-X-4-12VOLT-20AH_W0QQitemZ130318261318QQcmdZViewItemQQptZUK_ConsumerElectronics_Batteries_SM?hash=item1e5792dc46&_trksid=p3286.c0.m14 if you account for the covered section.
Anyway good to see more 12v projects! Always interesting for me :)
Posted By: subbass
Date Posted: 16 August 2009 at 9:50pm
look about the same size as my 7Ah jobbies
good luck if they are 20! I have 3 24Ah batteries and they are a b*tch to carry (especially after i gaffer taped them together in parallel Dead)
Posted By: workidz
Date Posted: 17 August 2009 at 4:45am
im keen to see how it ends up :)
Posted By: tektonik
Date Posted: 17 August 2009 at 1:37pm
managed to get this finished over the weekend
changed the alpine for a sony xplode one channel for mid bass other for hf using a active crossover
drivers installed
back of cab on left cigarette lighter socket for charging on right rca input and power switches
the bike for when i want to be portable
it can also be charged from my converted exercise bike when no mains power is available
i will be at the southern sounds festival dorset with this setup and a larger pedal powered rig
if anybody is going come and say hello
Posted By: Mark James
Date Posted: 20 August 2009 at 2:34pm
i never thought id see that with a driver in again
lol! was my bedsite cabinet for years :P
btw that is actualy made for a 10" and piezo not a 12" and 1"
glad its back in use :p
insert silly sentence here
Date Posted: 20 August 2009 at 3:16pm
just seen this and heard it
sounds good considering !!!
top marks for effort there
Posted By: Strange Daze
Date Posted: 06 September 2009 at 11:18pm
nicelly done!!!
Posted By: subbass
Date Posted: 06 September 2009 at 11:32pm
sweet :)
have already got my next 12v system on the drawing board, lol. gonna be portable unlike my current beast :D
Date Posted: 07 September 2009 at 9:39am
wow! what's the score with the trike conversion? did you hack the front off a go-cart? i'm very interested in how you achieved this.
james.
p.s. oh yeah, speaker looks good too! Smile
mardy hippy.
Posted By: tektonik
Date Posted: 08 September 2009 at 4:27pm
the front end is off a old battrey powered invalid carrage and the rest is just bmx. i have just picked
up another 12v amp so i am going to build a sub to go under this cab
Posted By: Jake_Fielder
Date Posted: 24 September 2009 at 9:46pm
Nice setup!
Yeah I well like the bike also!
Posted By: Quantum Sounds
Date Posted: 24 September 2009 at 10:20pm
are you using the steering rack form the invalid wheels or dose the whole assembly rotate?
Posted By: tektonik
Date Posted: 25 September 2009 at 9:19pm
im using the steering rack the forks are welded so they cannot turn and the handle bars are clamped to a shaft that goes through the top of the forks
 the wheels turn on the ends of the axel and there is a piviot in the middle
so the bike can lean when you go round corners
Posted By: lenny b
Date Posted: 28 September 2009 at 11:13pm
sweet man.that's 1 funky bike system!!!!
