t amp ta2400 in parallel mode
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=29949
Printed Date: 26 March 2026 at 1:06pm
Topic: t amp ta2400 in parallel mode
Posted By: davidhodgson
Subject: t amp ta2400 in parallel mode
Date Posted: 23 August 2009 at 2:39pm
hi
if we put our tamp 2400 in parallel  mode and connect 2 peavey ul18,s (8 oms each) to each speaker output will this be ok .the manual says it runs at 8 ohms in bridge /parallel mode.
obviously this will only be in mono but thats ok for subs.
many tx
Posted By: levyte357
Date Posted: 23 August 2009 at 4:47pm
Originally posted by davidhodgson davidhodgson wrote:
hi
many tx
Parallel mode just means one signal applied to both channels.
This is not a quality sub amp, like qsc, crown, crest, so I would'nt drive it into clipping if you value your speakers. Wink
Date Posted: 23 August 2009 at 6:15pm
tx for reply
but what ohmage will the amp be running at
in the manual it says 8 ohms bridge mode
the speakers are both 8 ohm cabs so what will the amp see
Posted By: Timebomb
Date Posted: 23 August 2009 at 6:46pm
4 ohms per channel.
As far as impedance is concerned its that same as running the amp in stereo mode.  Parallel mode just means splitting the input signal and feeding it to both channels.  Each channel has 2 x 8ohm speakers connected so each channel is seeing 4 ohms.
Date Posted: 23 August 2009 at 10:31pm
tx
sorry for confusion there will be only 1 8 ohm speaker connected per channel
