no same setting for indoor and outdoor, to check for correct time alignment you do this: Pick a frequency to cross over from one bin to the next eg about 80Hz for your Wbins into your HD's. Set this up on the crossover with zero delay. Now get out your SPL meter and play a test tone at 80hz, it should come out of both bins at the same volume when listened to individually (one at a time) If it's not then turn one cab up or down till they are about the same. Its easiest to do this with just one of each type of cab playing even if there are more in the stack. Now invert the phase of one cab EG the HD15. - this means reverse its polarity (Yes these terms have meanings outside of Star Trek episodes!). There may be a button marked Phase, Polarity or Φ on the crossover or you may have to swap the red and black wires on the amplifier. Now play the test tone again thru both cabs at the same time, it may have got quieter or louder, don't worry. Now you adjust the delay. Starting at zero mS, advance the delay on the HD15. The SPL reading should decrease and decrease to a point and then start to increase again as you add more delay. What you want is the delay value at the point of minimum SPL. This means that at that delay value the waves from the "in-phase" W bin and "out-of-phase" HD15 are cancelling each other as perfectly as possible. You should be able to hear this as well as the difference should be about 10dB SPL. Now put the connections/phase setting on the HD15's back to normal (button out/red to red and black to black.) Now the waves from each bin will be nearly perfectly in phase at the crossover frequency and reinforce instead of cancelling. This is what you are trying to achieve. (you can also do this without the phase reversal steps, but then you are looking for a peak in SPL which is harder to hear though still readable with the meter.)
Now repeat for the other frequency bands using appropriate test tones.
As you get up to the tweeter bands things become more difficult as the difference between the "right" and "wrong" delay value gets exceedingly small and SPL measurements are affected by reflections from the room boundaries. But this does not mean you should delay your tweets differently for indoor and outdoor gigs even if your meter says so! Try moving it 5cm left and watch the reading change 6dB...aargh.... You can also measure the length of your horns and use that to get approximate delay values, not taking into account group delay (look it up). IE if your W bins have around 1m horn and the HDs have about a 50cm horn, you'll want to delay the HD's by about (50cm/100cm)/344ms-1 = 0.00145 seconds = 1.45 mS. SO thats (short horn/m÷long horn/m)÷speed of sound (344m/s)x1000=delay in mS.
For a ported design like your W's though group delay is quite important so you want to take it into account, and try and use the measurement method. Ding ding, tickets please....
------------- Studio45 - Repairs & Building Commotion Soundsystem -Mobile PA
