X12 spec drivers: UK alternative needed please
Category: Plans
Forum Name: X10, X12, X15 and XM15
Forum Description: Discussion / Questions about the X10, X12, X15 and XM15
URL: https://forum.speakerplans.com/forum_posts.asp?TID=30095
Printed Date: 27 March 2026 at 11:10am
Topic: X12 spec drivers: UK alternative needed please
Posted By: tendril
Subject: X12 spec drivers: UK alternative needed please
Date Posted: 28 August 2009 at 1:17pm
P Audio x12 spec drivers discontinued. As a novice I wouldn't know what to replace them with. The cabinets have been built to spec and I don't want to bugger about retuning them, so your recommendations for a UK build alternative please.
(I realise that there are many threads about this already but from various builders in various countries. This thread is Uk specific.)
ta muchly.
Tendril
A mistake is a mistake only if one learns nothing from it.
Posted By: ceharden
Date Posted: 28 August 2009 at 2:19pm
There are lots of options of drivers available in the UK.
From PD there is the PD123ER if you want heavy (available from Bluearan) or 12MH25 if you want lightweight.
From B&C you could use the 12PLB76 or 12NDL76 or 12HPL76
There are Beyma options but I'm not as familiar with their drivers.
Posted By: Tony Wilkes
Date Posted: 29 August 2009 at 8:43am
I have said many times the original and only X12's were equiped with budget drivers. To get comparable performance there is no need to look beyond the Celestion TN1225's.
The important part is then the Comp. You can either build them as a M-T-M arrangement which allows you to use any number of 1" comps crossed as low as 1.8K or in more typical M-M-T arrangement and either use a 1-1/4" comp crossed at around 1.2K or one of the BMS 1" drivers crossed as low as 1K although this is probably not cost effective giving the budget nature of the Bass-Mid driver.
Tony
Posted By: boycey
Date Posted: 30 August 2009 at 6:11pm
unfortunately these cabs are already built tony so MTM isn't an option but i'm curious as to why that arrangement would allow a higher crossover freq. sorry if it's a bit of a basic question Embarrassed
the only thing more dangerous than a person who doesn't give a f**k is a person who gives a sh*t.
Date Posted: 31 August 2009 at 8:43am
It keeps the relative path lengths for the 3 drivers as close as possible assuming listening on the comp axis. With a double bass mid arrangement there is always some anomaly because of the physical distance from the comp to the lower bass unit.
Lowering the x-over frequency also helps which is why you see a lot of 2" units used in this arrangement crossed at 800-1000hz. But these often sound sub-optimal.
No arrangement is perfect its all about managing the compromises.
Tony
Posted By: boycey
Date Posted: 31 August 2009 at 8:56am
this seems to be true for nearly all aspects of speaker design, thanks for the answer Smile
