Good match for....
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=3089
Printed Date: 27 March 2026 at 12:38am
Topic: Good match for....
Posted By: P-Trix
Subject: Good match for....
Date Posted: 15 November 2005 at 4:18am
Hi people, i've got a pair of courts designed 18 inch w-bins, and a pair of OHM RW3(with 400w drivers).
I'm looking into buying/getting built another 2 bass bins of some kind, i'm not really too sure what to go for though!
My current choices have been either 2 PD1850s, 2 Punishers or maybe 2 LabHorns.
Would you recomend any of these, or recomend anything else that would compliment what i have already!?
Many thanks, P-Trix!
Posted By: Dom
Date Posted: 15 November 2005 at 1:54pm
I recommend that as early as possible you decide on 1 design of bass bin and make lots of them.
Mixing bass bins that are playing the same frequency range just leads to headaches.
Posted By: ceharden
Date Posted: 15 November 2005 at 2:22pm
I'm with Dom.  Can you get enough measurements off the W-bins to copy them? That might be the way to go if you like the sound of the ones you have.
Posted By: P-Trix
Date Posted: 16 November 2005 at 9:45am
Well the reason i wanted a different set of bass bins, was so i could run it 4-way, would you not recomend that either !?
I guess i could get the desgin up of the w-bins, do like them indeed...but i like other bins too!
So many choices, really don't know what to do haha!
Thanks for the replys guys :)
adiktid to audio visual
Posted By: kevinmcdonough
Date Posted: 16 November 2005 at 8:54pm
I think what the guys mean is not building different cabs that run the same frequency range. The cabs you suggest; Labs, punishers and 1850s, will all cover same frequencies as your current bins and you'll just end up with funny combing and phase problems trying to line everything up.
If your wanting to go 4 way then you have to look at using a kick bin.  Use your current subs for very low bass, and then cross over to a kick bin of some sort (HD15 or Bark etc) to do upper bass, then to your mids and then tops.
kev
