Turbosound Crossover Repair
Forum Name: Electro Frying Forum
Forum Description: Talk about drivers, processors and mixers
URL: https://forum.speakerplans.com/forum_posts.asp?TID=30936
Printed Date: 27 March 2026 at 11:10am
Topic: Turbosound Crossover Repair
Posted By: Jake_Fielder
Subject: Turbosound Crossover Repair
Date Posted: 24 September 2009 at 1:11am
Just to help out others who get the HF failing on a Turbosound midtop. I think it was the 10" and 1" section of a TMS5, i assume this could be the same crossover as the TSE111 and other models with the same 10 + 1 horn module bit.
I repaired the HF Pot/Volume control/Attenuator, when i took it apart i could see the obvious burn marks, Where the attenuator was is circled black;
Heres the inside of the attenuator, Circled blue is the burnt/blackened area, which was still ok, as it was a white insulating material that was the burnt colour, not the wire.
Circled in red is the problem area, all that had happened is the coil had gotten so hot that the solder had melted (must have been around 200 degrees), disconnecting the wire from the terminal, I simply soldered it back on... DONE
This is just for referance as hopefully searchers can find this and if they find similar symptoms* they can attempt this repair even with no electronic knowledge and only basic soldering skills. The Pot/ attenuator doesnt have to be reomoved from the circuit board.
One more pic for good measure
* symptoms as in, HF works on its own but not when used though the crossover, and burn marks around the volume control on the crossover circuit board.
Feel free to correct me on details like the model numbers as im a tad unsure
Posted By: Tedski
Date Posted: 24 September 2009 at 8:58am
Very nice,
but in my experience, after a coil has gotten so hot, it no longer has the same properties as it did before, changing the x-over point.
Date Posted: 24 September 2009 at 9:15am
Realy? It would have to have a changed capacitance or inductance...? Why do you think this happens?
Posted By: Tedski
Date Posted: 24 September 2009 at 10:10am
Not sure, but in the past I have had to replace passive x-overs after the 1" had blow.
All the energy that was meant to go to the 1", goes to the coil, heating it up.
After replacing the 1", it sounded wrong, and had to replace all the coils on the passive x-overs to get it right again. They had visibly deformed and gone darker.
Posted By: hectorberman
Date Posted: 04 May 2023 at 9:23pm
Sorry to revive such an old thread, but can anyone tell me which of the wires out of green and white is positive and negative respectively?
Posted By: Wikl109
Date Posted: 05 May 2023 at 8:25pm
I've never used these particular cabs but looking at the bottom right corner of the first picture it seems to say:
CABLE COLOUR
Black Is Bass (-)
Red Is Bass (+)
Blue Is Mid (-)
Brown Is Mid (+)
That means white and green are the only two left. Again looking at the picture it must be:
Green Is Top (-)
White Is Top (+)
The only problem here is the soldering on the crossover looks like it may have been tampered with as it's not very neat.
It may well be how they came from the factory though.
I'm pretty certain that is what the plate says though so I'd go with that.
Cheers, Chris.
Date Posted: 11 May 2023 at 11:22am
Here are the crossovers in question. I wanted to avoid creating a new thread so thought I'd ask this here too.
While the components differ slightly, as these are from two slightly different models of the same cabinet, one is completely missing a coil?
Can anyone shed any light on what's going on here? Has someone removed it or was it never there?
Posted By: RoadRunnersDust
Date Posted: 21 May 2023 at 12:08pm
If you google for Turbosound tms crossover you’ll find a scan of a hand drawn note by T.A. That will give you a schematic and values for what the TMS crossovers should be :)
www.guildfordcablecompany.co.uk" rel="nofollow - www.guildfordcablecompany.co.uk
