tilt/spley board
Category: Plans
Forum Name: Punisher and X-tro
Forum Description: Discussion / Questions about the Punisher and X-tro
URL: https://forum.speakerplans.com/forum_posts.asp?TID=31030
Printed Date: 27 March 2026 at 8:37am
Topic: tilt/spley board
Posted By: Saul
Subject: tilt/spley board
Date Posted: 25 September 2009 at 7:22pm
so,
Xtros, with td245 horn and xt8 horn.
60 degree dispersion on td245 and anyone want to punt a guess on the xt8 (those who own them)
i reckon its around 60 also.
so to make the tilt board am i right in thinking i need to put a 60 degree spley on them. or should it be 30.
the other thing is i find the 15" is quite tight on dispersion.
so i guess i need to get the right balance between coverage and dead spots etc.
Posted By: doober
Date Posted: 25 September 2009 at 9:32pm
I think you need to try it. I would start with the cabs splayed very wide, more than 60 degrees. Play some music or a series of sine waves and walk in an arc at some distance from the cabs. The quiet spot should be obvious with a wide splay. Reduce the angle a bit at a time, repeating the listening test. You should hear the quiet spot get narrower. Repeat this until the quiet spot has just gone, and this is your angle, provided you are not now experiencing any excessive combing.
I would guess the best sound will be at around 40 degrees between cabs, but I have never listened to any of the horns you are using, this is based on using other 60 degree horns.
At which frequencies do you find the 15" has tight dispersion? I wouldn't expect it to have any significant control below ~700Hz, but I still haven't heard an xtro.
Kieran
Blahblahblah
Posted By: Saul
Date Posted: 09 January 2010 at 10:40am
is there a mathematical way of working this out?
our xtros keep snapping back square with bass bins vibrating under them.
we also need the tilt when we have the bins stacked 3 high.
Posted By: Father-Francis
Date Posted: 09 January 2010 at 11:55am
is that the bass from the Xtros or from the bassbins if it´s from the bassbins turn that off
cause thats not what you are working with . and you can also try cutting some wedges of ply when you are at the workshop or buy some plastic wedges , this should make things easier.
