12" bass from 60 to 500 hz
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=31168
Printed Date: 27 March 2026 at 4:06am
Topic: 12" bass from 60 to 500 hz
Posted By: harold
Subject: 12" bass from 60 to 500 hz
Date Posted: 30 September 2009 at 9:15pm
HEllo does someone has any idea what the best non frontloaded enclosure for a 12" is. It has to do 60 hz to 500 hz and has to be around 35 x 40 to 50 cm.
Posted By: Peter Jan
Date Posted: 30 September 2009 at 10:08pm
You mean non-frontloaded as in : hornloaded or 4th order bandpass or what ?
Posted By: harold
Date Posted: 30 September 2009 at 10:12pm
Hornloaded would be fine but i am afraid that then the enclosure will become to big
Date Posted: 30 September 2009 at 10:24pm
The broad range from 60 up to 500 excludes bandpass, so what else is there besides hornloading or/and BR ? In the size you like it to be, I can't see a horn working decent enough in that low region, would be too short in that size to work. Even a shorter horn with BR assist... doubt it. Also the need to bent the horn to get some length in that size is a big no-no for the higher region. Frontloading with straight BR tuning would do the trick easily. Somewhat less SPL than a horn, but not difficult to get it almost flat from 60 to 500.
Posted By: harold
Date Posted: 30 September 2009 at 10:31pm
yes thats what i thought allready but was hoping for some wonder. ;)
Posted By: harold
Date Posted: 30 September 2009 at 10:59pm
  that has to be 250 to 300 ahum
Posted By: darkmatter
Date Posted: 13 October 2009 at 2:27pm
So you want someone to invent a new loading technique? LOL
