Suggested amp power for 4 x 1850
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=32528
Printed Date: 27 March 2026 at 8:45am
Topic: Suggested amp power for 4 x 1850
Posted By: solution
Subject: Suggested amp power for 4 x 1850
Date Posted: 10 November 2009 at 5:00pm
What amp power would people recommend to run 4 of these cabs in 4R rms?
Bassmentality: Ska, reggae, funk & Hip hop every month @ The Cellar, Oxford
Posted By: Saul
Date Posted: 10 November 2009 at 7:00pm
yep - 2 per side.
ideally giving each PD1850 around 1000w.
crown 5000 is good
Posted By: musicman
Date Posted: 16 November 2009 at 12:36am
infi 8 v2
Posted By: Jake_Fielder
Date Posted: 16 November 2009 at 8:50am
I heard 4 the other day, two ran off a bridged proline 2700 (1350w each), and two off an XP5000 (8r stereo)
Sounded incredible, so either of them options would be a good idea imo, and both cost the same i believe (xp5000 or 2x proline 2700) you'll get more power with the prolines but probably 30+kg in weight
Posted By: video_compiler
Date Posted: 16 November 2009 at 8:45pm
4r rms is not a rating, please try to make sense.
Date Posted: 16 November 2009 at 9:10pm
Read the question properly, perhaps punctuation was lacking but read it like this;
What amp power would people recommend to run 4 of these cabs, at 4R, rms?
((What rms power to run 4 cabs at 4r per side.))
Date Posted: 16 November 2009 at 9:14pm
Look at the rating on the loudspeaker, and multiply it by the amount of loudspeakers you wish to drive. It makes perfect sense.
Posted By: Saul
Date Posted: 16 November 2009 at 9:19pm
WRONG, WRONG, WRONG.
look at rating on the loudspeaker, multiply by 1.2 to 2 times
 =  this is what you ideally need to send to the driver - ESPECIALLY the pd1850.
for pd1850, i'd try and get at least 2kw over 2 drivers.
Date Posted: 16 November 2009 at 9:33pm
Yeah Ollies were loving the bridged proline up 'em, rating of 2.7Kw @ 4r.
EDIT; v18-1000s that is... (supporting the 1.2 -2x wattage claim)
Posted By: Saul
Date Posted: 16 November 2009 at 9:34pm
i thought oli used v18-1000?
Date Posted: 16 November 2009 at 9:40pm
Yeah you're right, but the question says cabs not drivers... so 1850horns,
@ Solution. What are you planning on loading them with?
Posted By: Lawaaiige buur
Date Posted: 27 November 2009 at 7:55pm
I run 8 rcf L18P300 loaded 186's on a MC2 E90, so the speakers get they program power, which is 2000 each. Some friends told me it would be too much, but i didn't blow a speaker yet. So i think you can power them at program power with a proper amp..
Posted By: solution
Date Posted: 29 November 2009 at 3:05am
yeah sorry should of been clearer. I'l be running pd 1850's in 1850 cabs. It's always been my understanding that I need to power bass with 1.5 x the rms rating so I'm thinking I'll need to feed each driver with 1500w
Posted By: Speaker Sol
Date Posted: 30 November 2009 at 6:55pm
I have always found bigger amps work better, plenty of power for those transients without clipping.
Just remember not to get greedy, If you start pushing an amp that is already twice the RMS power of the speaker into clipping  it won’t be long before the driver suffers thermal melt down.
I plan on running my 4 Looney’s 2 aside off a Macro Tech 9000i, which should be able to produce a 3.5k burst per channel, although I must say I will be doing some research into how to use the limiters in this amp to keep my speakers safe.
