Punishers blew away our old 18" reflexs
Category: Plans
Forum Name: Punisher and X-tro
Forum Description: Discussion / Questions about the Punisher and X-tro
URL: https://forum.speakerplans.com/forum_posts.asp?TID=3288
Printed Date: 27 March 2026 at 12:38am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Punishers blew away our old 18" reflexs
Posted By: Lyndon A
Subject: Punishers blew away our old 18" reflexs
Date Posted: 12 December 2005 at 10:08am
We worked really hard the last week to get the punisher ready for sat
night, working into the early hours of the morning. The result
though, was by far worth it!!! We had our old pair of OHM 18"
running about 400w each, and a single punisher at about 800w.
The Punisher was easily a lot bassier than the two reflexs, probably
double. The sound was a lot more intense too, it's hard to
explain! We were rattling the floor and roof of a small 50
capacity skittle alley.
Now to make about 7 more
We would have run the punisher and other bins harder, but we were lacking top for once (see other thread).
Posted By: whitehousejamie
Date Posted: 12 December 2005 at 10:14am
How well does the single Punisher perform? What amp did you run it with? And what crossover points etc?
Posted By: Lyndon A
Date Posted: 12 December 2005 at 12:18pm
I'm guessing it all depends how large a venue you want to fill. I
was high passing at 40Hz, and to me it didn't miss anything in the bass
department, tested with techno and dnb. It was tested on the
actual night, very little time for sound checks.
I had one of our 3G amps bridged into it, so could have given it close to 1500 watts.
As the setup time was so small, and I'm running it with 12" mids it was
running 40Hz to 120Hz. Over time I'll be playing with those
values.
Date Posted: 12 December 2005 at 12:31pm
I would really like to try a pair, but not sure who could build them properly for me / how much it's going to cost.
Currently using 4 stacks of EV MT2, but want to cut the weight and size down a bit.
Posted By: Mircea Bartic
Date Posted: 12 December 2005 at 12:47pm
Damn, I can't wait for my P-audio SD-12's to arrive , so I can start bulding my own 4 punishers
------------- general manager & head designer at nexus-acoustics research http://www.facebook.com/nexus.acoustics.research" rel="nofollow - http://www.facebook.com/nexus.acoustics.research
Ex Nexus_3
Posted By: norty303
Date Posted: 12 December 2005 at 1:05pm
but not sure who could build them properly for me |
Try loophole on SJ. He's done some very nice ones for other people first and now he knows what it'll take, could prob give you an accurate quote
------------- My laser stuff: http://www.facebook.com/SubsonicSystems" rel="nofollow - Frikkin Lasers
Posted By: chilli
Date Posted: 12 December 2005 at 2:18pm
or ask agentried from on here, his mate marcus is a bit handy with a
bit of old ply... reckoned the punisher would be a piece of piss after
the wsx.
Posted By: loophole
Date Posted: 12 December 2005 at 3:58pm
ahh jamie you should have got in touch with me a fortnight ago! im building 8 this month, but ive just got all the ply cut :(
im at uni now so building periods are a bit intermittent, but let me know if you still want some come april-ish
i think ive seen pictures of 'marcus's work (was it him building that huge batch of punishers fairly recently?), i imagine he'd be an equally good, if not better, alternative ;)
Posted By: Lyndon A
Date Posted: 12 December 2005 at 4:21pm
I'm redesigning the plans so that all all the internal panels slot into
routed side panels. The first one was a nightmare,spent most of
the time thinking which bits to assemble, how and when.
Posted By: james folkes
Date Posted: 13 December 2005 at 4:27am
slot into routed side panels. |
do it!! it's the way forwards... plus you have the added advantage that if you
make up templates to cut nearly everything out you can virtually production
line the little blighters (when i've finished my martins etc...). have you got
any piccies of your punisher build flipside?
james.
------------- mardy hippy.
Posted By: Lyndon A
Date Posted: 13 December 2005 at 10:20am
Yep, we got lots of photos!
http://flipsidevibe.com/forum/forum/forum_posts.asp?TID=24 &PN=1&TPN=4
Theres some more on previous pages too on that forum. You can see
how we did the access panels, thought that was the best way. A
lot more space to get your hands in without any battens.
I'll start on them plans over the xmas holidays, need to ask the wood
cutters how much pre routed panels on theri CNC router wil cost.
Date Posted: 13 December 2005 at 10:39am
Excuse me for being stupid,but what size driver do these punisher horns take? hard to make it out from the photos.thanks.
------------- Be seeing you.
Date Posted: 13 December 2005 at 11:55am
12"
Ex Nexus_3
Posted By: Tom Umney
Date Posted: 13 December 2005 at 11:56am
Yes it is a 12 inch Ciare 12.00SW driver used in the Punisher horn.
Posted By: Contour
Date Posted: 13 December 2005 at 12:11pm
Hello,
That Punisher looks really good!
Nice to hear they did well compared to the 18" reflex. Remember the more Punishers you add the more impressive they become. Compared with a stack of two a single Punisher really is less effective. Also that 800W is a bit shy, the Punisher likes about 1500W of clean signal. In thay case it really starts to move the air.
Keep up the good work, your system with 8 Punishers should offer some serious bass.
Best regards,
Walt
Date Posted: 13 December 2005 at 12:27pm
jbl_man wrote:
what size driver do these punisher horns take? |
ian, dude, where have you been!!
punishers are this season's 'must have' bass horn. ludicrous performance
from a winkum ickle box, they have been described as 1850 killers... if i
din't need to find homes for 16 15" drivers then i'm sure the punisher (with
it's £100 driver, oh yes) would be well up the list, closely followed by a pair
of x-tros!
james.
Date Posted: 13 December 2005 at 2:26pm
will a 15" not fit into it james?..is there simply not the space to accommodate a 15"?
Posted By: Contour
Date Posted: 13 December 2005 at 4:30pm
Hello,
Using a 15" driver in the Punisher would not give good results. The compression ratio would be too large. This would mean some serious forces acting on the cone.
Also the horn is designed around the Ciare 12.00SW and based on that T/S parameters. Using a 15" would mean you would have to redesign the whole box and it will not be a Punisher anymore. I have not seen many 15" horn designs with a long horn, it seems most long basshorns either use 12" or 18" drivers. The 15" is very popular in short (midbass) horns. But of course with the correct T/S parameters a longer horn design should well be possible.
As for the 12" Ciare driver, too bad in some countries they are hard to get or expensive. Here in the netherlands they are cheaper than most 18" drivers while offering about the same magnet/voicecoil size. That means lot of power to drive the small strong cone for maximum output.
Best regards,
Walt
Date Posted: 13 December 2005 at 5:06pm
in the countries where ciare 12.00SW is to expennsive or not available, aparently you could use the P-udio SD-12
4 units will be built in february or March by me (that's when the drivers arrive), and loaded with the SD
Plots look good, even better than the ciare in some places, I hope the end results will be similar
Anyway I would NOT encurage anyone to try using a SD-12 in the punisher until I will make mine ant test them properly.
I something goes horribly wrong, at least I will be the only one to lose
Ex Nexus_3
Posted By: Contour
Date Posted: 13 December 2005 at 5:27pm
Hello,
I think you have to A/B your Punisher loaded with P-Audio against one loaded with the Ciare. My concerns with the P-Audio are its small lineair x-max which mean the BL factor will drop when the coil leaves the airgap when driven hard. But I agree the P-Audio T/S look good. Too bad with P-audio you never know what specs will be on the actual box in which the drivers arrive. These specs always seem to differ from what can be found on the P-audio website...
Best regards,
Walt
Posted By: MixMan X
Date Posted: 13 December 2005 at 5:38pm
I've often thought about designing a horn similar to the Punisher, based around the Ciare 15.00 SW.
Walt, do you think this is an option?
Date Posted: 14 December 2005 at 1:42am
Contrary to common believes, a bigger driver will not necesary meam more spl or lower extension in a horn
Big driver = shorter horn, or bigger enclosure, so You see , there's no free lunch
Ex Nexus_3
Posted By: MixMan X
Date Posted: 14 December 2005 at 5:03am
I did mean in a bigger enclosure, would be nice if it could go a bit lower than the Punisher.
On a different note, I've found that Ciare do an in car equivalent of the 12.00 SW with two 2ohm voice coils, I'm toying with the idea of building a system into a car with two reworked Punishers in the boot, reckon it could do some serious SPL. I'm thinking about using to rear screen as one side for the final section/mouth of the horn.
Any thoughts?
Posted By: IAIN RENDLE
Date Posted: 14 December 2005 at 5:35am
sounds like a plan. would have a very large mouth
btw
whats the sensitivity of the punisher?
------------- -=vortex sound systems=-
www.vortexsound.co.uk
Posted By: MixMan X
Date Posted: 14 December 2005 at 6:41am
Punisher is only 102dB sensitivity, but with two and the huge mouth of the horn, combined with the enclosed environment of the car, I think it would be pretty loud. I've found an amp that will put out 1500w RMS @ 1ohm, so a pair of them should power the system nicely!
Only an idea at the moment, but it could be fum to upset a few people in the world of in car SPL with some interesting horn designs.
Date Posted: 14 December 2005 at 12:22pm
little bit off topic. but does any one know the sense of an 186 bin? and max SPL.
planning of having 16 in my rig
will it hit 150db?
iain
Posted By: Jay Lawless
Date Posted: 15 December 2005 at 1:54am
i'm sure you'l hit 150db with 16 bins...
@Mixman, would be nice to see that idea go to work. should try it out
------------- Previously known as NeverWinter
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist
Posted By: kevinmcdonough
Date Posted: 24 May 2006 at 2:34pm
Hey flipside
Sorry to drag up an old topic, but am planning my punishers and would
like to ask about your access hatch, as I'm playing about with
dimentions and seeing how best to rout the access hatch so that there
are no battens, in a similar manner to what you have done.
i'm just wondering what you use to attach the access hatch to the cabinate. Do you use T-nuts or just screw directly into the wood?
The part of the side pannel that you have had to rout away and that the
side pannel will be touching/screwing in to, is directly above the side
walls of the rear chamber on the other side so would have been very
hard to get T-nuts into. Just wondering if you managed it and if so
then how?
(just read that back hope it makes sense )
kev
Posted By: loophole
Date Posted: 24 May 2006 at 3:42pm
kev, if you make your removable battens as one piece, in a ring, and make it precisely, you wont have a problem with leaks etc. i make mine like this, and then bolt them in tight on all sides while the box is gluing, so the panels making up the rear chamber have a good tight fit with the battens.
unless you want to use woodscrews as you mentioned above, the only other way would be to recess the hatch to half depth right beyond the rear chamber panels, so the nuts have a clear space to sit in.
however if you did this the hatch would have very extended thin flimsy edges - i would probably opt for an aluminium plate instead if i was going to do it this way...
Posted By: Lyndon A
Date Posted: 24 May 2006 at 4:03pm
We just routed 7.5mm deep from both the access panel and the side panel. We chose 20mm as the width of route.
We used screws to hold the access panel on. It's unlikely you'll need to get in them again, the drivers seem so solid.
One inside edge of the side panel will need an additional piece of scrap wood screwed inside. This is because the screw wouldn't grip onto much. All the other screws can go into the edges.
I don't know if that makes much sense, perhaps a diagram would be better?!!!!
Posted By: Deej
Date Posted: 24 May 2006 at 4:24pm
I did exactly the same thing as Flipside on my punishers and i havnt found that using screws is a problem. Although it isnt ideal, as long as you dont over tighten the screws you should be able to take the access panels off at least five times without damaging the threads (which you wont need to do unless you are seriously overpowering the drivers)
