1850 - Horn build
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=33639
Printed Date: 27 March 2026 at 2:16am
Topic: 1850 - Horn build
Posted By: Chrise
Subject: 1850 - Horn build
Date Posted: 13 December 2009 at 4:17pm
Edit
[GER-User]
Posted By: odc04r
Date Posted: 13 December 2009 at 4:22pm
Looking very nice so far, that is going to be a sturdy box.
Posted By: studio45
Date Posted: 13 December 2009 at 5:12pm
Biscuit tastic! Are you in Germany then? Are you using Festool equipment? I <heart> the festool :)
Posted By: Chrise
Date Posted: 13 December 2009 at 5:26pm
Yea, I use Festool equipment, Nice stuff!
[GER-User]
Posted By: djyves
Date Posted: 13 December 2009 at 6:03pm
biscuitsClap
you are making 4 1850s?
Posted By: Chrise
Date Posted: 13 December 2009 at 7:29pm
Yep.
E:
At which watt is the xmax of the VOID V18 1000 in the 1850 horn?
Can anyone simulate that?
Regards, Chrise
[GER-User]
Posted By: djyves
Date Posted: 17 December 2009 at 4:08pm
1850horn with v18-1000
1000w, 89,44v
10,5mm x-max
input data
Posted By: breakdabeat pete
Date Posted: 17 December 2009 at 5:13pm
im pretty sure the length of an 1850 horns path is not 210!
iv always used 166cm
٩(̾●̮̮̃̾•̃̾)۶
Posted By: djyves
Date Posted: 17 December 2009 at 5:43pm
i found it on here:  http://forum.speakerplans.com/database-simulation_topic16974.html - http://forum.speakerplans.com/database-simulation_topic16974.html
i don't know witch one is right 160 or 210
but the sim with 160:
input:
Posted By: Chrise
Date Posted: 19 December 2009 at 6:41pm
Edit
[GER-User]
Posted By: djyves
Date Posted: 26 December 2009 at 10:21am
nice,
like the front brace
Posted By: Chrise
Date Posted: 26 December 2009 at 4:51pm
Edit
[GER-User]
Posted By: studio45
Date Posted: 26 December 2009 at 5:25pm
Why don't you like bi-amped tops? they are better in every way!
 If it's because you want to be able to use only two,  2-channel amplifiers to run this system, just run in Mono until you can get another amp! Most amps will easily drive 2x tweeters from one channel and 2x woofers from the other...
It is true the Turbosound models you mentioned are old, but they are still very, very good, and would be a good match for your horns. The woodwork is of a similar high standard, for a start :) You may want a mid-bass box or kick-bin between them, though.
If you don't like "selfmade" ("DIY" is a better way of saying that) midtops, you haven't heard a good one!
(....like mine Cool)
Posted By: Chrise
Date Posted: 26 December 2009 at 5:39pm
Edit
[GER-User]
Posted By: Chrise
Date Posted: 16 January 2010 at 6:12pm
Edit
[GER-User]
Date Posted: 16 January 2010 at 11:11pm
Originally posted by Chrise Chrise wrote:
Ok,
What is the difference between TMS-2 and TMS-4?
Which would you prefer?
Amping is already here for bi-amped tops, Embarrassed
What is a "good one DIY" top?
id strongly consider the mt121 crossing from the 1850's at around 130hz
٩(̾●̮̮̃̾•̃̾)۶
Posted By: Saul
Date Posted: 16 January 2010 at 11:16pm
what's the big slot on the back of your boxes for?
i like the brace design - is it part MDF, part Ply though?
Posted By: cravings
Date Posted: 17 January 2010 at 12:21am
the construction is excellent. the braces do look slightly dangerous though! some drunk head falling against one may not come off too well. am i being overly negative?
Posted By: Chrise
Date Posted: 17 January 2010 at 2:26am
its a handle ... if you stand behind the cab and you must pull them backward ... ;)
Jep, basicly MDF, but now I have some cheap ply (6,80€ m²)
So I have made the rest of ply.
[GER-User]
Posted By: Chrise
Date Posted: 17 January 2010 at 2:27am
Ok,
No not a mt121, out there are many better midtops ...
[GER-User]
Posted By: DjJosh
Date Posted: 17 January 2010 at 3:35pm
mt 130 :)
Posted By: Chrise
Date Posted: 17 January 2010 at 8:24pm
e.g. :D
[GER-User]
Posted By: DjJosh
Date Posted: 18 January 2010 at 4:38pm
http://www.freespeakerplans.com/mt-130.html - http://www.freespeakerplans.com/mt-130.html
Posted By: AlfieDring
Date Posted: 18 January 2010 at 5:11pm
No vertical expansion?? Whats the intended crossover point?
Alf
Posted By: djeddie
Date Posted: 18 January 2010 at 7:37pm
From what it says on the FSP page, 120Hz and up...
unless you meant the higher x-over point!
Posted By: Chrise
Date Posted: 22 January 2010 at 11:19am
Edit
[GER-User]
Posted By: DjJosh
Date Posted: 23 January 2010 at 12:42pm
I emailed :)
http://hornplans.free.fr/mt130.html
Hi,
I found your design, looks quite nice - somewhat like mt122 from speakerplans but with no information concerning  frequency response or anything. Do you have any information about those boxes- how they perform etc?
All the best,
Hi
Thank for your interest
The MT-130 must be compared to the MT121 (Half of a MT122 in low mid). The MT-130 has a little more sensitivity, is more flat, frequencie response goes higher (low mid section), cost less with better sound, easy to build, .
F3 is similar to MT121.
MT-130 response curve of the low-mid section in attached file.
Marc.
Alf
