amps to run Xtros
Category: Plans
Forum Name: Punisher and X-tro
Forum Description: Discussion / Questions about the Punisher and X-tro
URL: https://forum.speakerplans.com/forum_posts.asp?TID=34524
Printed Date: 27 March 2026 at 11:10am
Topic: amps to run Xtros
Posted By: Father-Francis
Subject: amps to run Xtros
Date Posted: 11 January 2010 at 10:18am
4x Xtros
beyma cp380x2 run off one side of XP3000
b&c 8PE21x 2 run off one side of XP3000
18sound 15nd930x4 run off one XP5000
that should work fine ??
so i need 2xXP3000/2xXP5000
Posted By: Saul
Date Posted: 11 January 2010 at 10:30am
beyma cp380m on an xp3000??
jeeez
Posted By: Saul
Date Posted: 11 January 2010 at 10:31am
also 4 xtros will have twice that number of drivers.
run two a side- should be fine. make sure that xp3000 is correctly limited tho!
EDIT:
or you could run 2x Xtros per side.
all 8x 15" on both sides of an xp5000.
all 4x 8" off one side of an ukp2100
all 4x 1" off one side of an ukp1300.
Date Posted: 11 January 2010 at 11:22am
EDIT:
4x 15" xp3000
2x 8"   xp2100
2x 1"    xp1300
I´d like 2 ampracks for when am using two small rigs Saul
then use the xp5000 on the bass running 4xV18-1000
