Which speaker to use?
Category: Plans
Forum Name: MT122
Forum Description: Discussion / Questions about the MT122
URL: https://forum.speakerplans.com/forum_posts.asp?TID=34970
Printed Date: 27 March 2026 at 8:45am
Topic: Which speaker to use?
Posted By: Chris.
Subject: Which speaker to use?
Date Posted: 22 January 2010 at 12:43am
I am about to build two MT 212 which will be in charge for the mids. The bass will be run by 4 hd 15 (PD 154) and 4 superscoops (PD 186). Since there are several speaker you can use in a MT 212 i would like to get some oppinions which of the four speakers are best for the mid application (est. 200 Hz up to  more or less 2 khz, maybe a bit higher).
1. PD 123 - 400W/ 8 ohm - up to 5 khz - 97 db
or
2. Eighteensound 12MB700 - 450W - up to 5 khz, 101,5 db
or
3. Beyma 12 MI 100 - 350W - 40-4000 Hz, 100 db
or
4. RCF L12P110K, 12", 500W RMS, 8 Ohm, 60Hz - 2kHz, 101dB
Volt speakers would be awsome, at least designwise, but hard to get and expensive i guess (?).
I would appreciate an advice since i don't know how they sound. Any expertise and recommendations?
cheers,
chris
Posted By: PauliePaul
Date Posted: 22 January 2010 at 3:21pm
Have a read of this.... just to confuse things a little more....
http://forum.speakerplans.com/pd-neos-vs-pd-ceramics_topic34254.html - http://forum.speakerplans.com/pd-neos-vs-pd-ceramics_topic34254.html
Posted By: COZY PILLOW
Date Posted: 22 January 2010 at 8:46pm
PDN12.MH25 are unbeleivable in MT120's They are a superb alternative. PM me and I can give you some more details.
Wink CP.
COZY
Posted By: Tony Wilkes
Date Posted: 06 March 2010 at 8:33am
Another one to throw in the mix BMS 12S310 , I only ever use Neo's so this one had completely passed me by.
Tony
Posted By: stereo
Date Posted: 06 March 2010 at 10:49am
Tony,who retails this speaker inn the uk?
