Zero 88 micro 4
Category: Other Chat
Forum Name: Lighting Talk
URL: https://forum.speakerplans.com/forum_posts.asp?TID=35773
Printed Date: 26 March 2026 at 10:56pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Zero 88 micro 4
Posted By: GAZ.
Subject: Zero 88 micro 4
Date Posted: 10 February 2010 at 7:21pm
Just bought one of these off the bay. Tried it out, seemed to be working ok, ran for about 5 minutes then smoke arose!
Anyone have any experience of working on these units?
looking inside revealed a burnt resistor on one channel and a possible dodgey poly capacitor. If I replace these parts will all be well again or is it likely to have done more damage? Cheers
------------- 100% Earth Moving Bass
Posted By: djeddie
Date Posted: 10 February 2010 at 10:55pm
Last time I repaired one of those was 1990! Anyway IIRC, one of the triacs had blown, taking a few other components and bits of the pcb tracks with it... Can't be more help than that sorry.
------------- Chas n Dave : it's like Drum and Bass but with beards. E=mc² ±3dB
Posted By: GAZ.
Date Posted: 11 February 2010 at 12:58am
Yeah its old! Theres a date on one of the test stickers inside from 1985 I think it was! The resistor which has burnt up is on the power board by the chokes. Next to it is the poly capacitor which seems to have cracked. I had an old mode electronics dimmer do a similar thing a while back. Possibly because the capacitors are old?
I think the triacs are ok, I only had 2 channels connected to lights to test and it was still working when the smoke came out. I switched it off quick so hopefully I have limited the damage.
