pm 80
Forum Name: Electro Frying Forum
Forum Description: Talk about drivers, processors and mixers
URL: https://forum.speakerplans.com/forum_posts.asp?TID=37206
Printed Date: 26 March 2026 at 6:55pm
Topic: pm 80
Posted By: Quantum Sounds
Subject: pm 80
Date Posted: 18 March 2010 at 1:47pm
i have had a pm 80 for a while that originaly didn't work but i have managed to fix (well mostly need soem pot cleaner and poss a couple of new pots and faders) tbh i haven't had to do much, just clean a bit and resolder a wire here remove a randome bit of metal that was shortign the power supplie there
any way i have now also got a crossfader for it but it is confusing me alot, it has a scerial port on the back as well as a 1/4 inch jack in a 1/4 inch jack out and a 3pin plug like a small xlr
this is not like the one in the pic
as it has little number selectors either side of the crosfader
my quenstion is...
how do i plug it in?
the 3 pin plug goes in the power suply on the aux power socet but where do the jacks go??
and what is the serial port for ???
it was mentioned on anouther thread that the crosover is conected with jacks to that
Originally posted by ceharden ceharden wrote:
The crossfader connects via 3.5mm jacks, if your mixer doesn't have the sockets on it, I would expect it's not compatible with it.
but the cross fader has no jacks,
will this have somthing to do with the remote out?
any help will be much appreciated
thanks
ps i willtry to put up pics later but i don't have a camera atm
Posted By: burningbush
Date Posted: 18 March 2010 at 3:18pm
pm JBL-man on here, he knows these units.  In fact AFAIK thats his in the picture.  Lovely isn't it?
Posted By: kedwardsleisure
Date Posted: 19 March 2010 at 7:21pm
Just ring Formula Sound, they're still going
Just a thought, have you got the right versions of crossfader and chassis? The PM80 was re-issued recently and is internally different to the original ancient unit.
North Staffordshire
Posted By: rich21
Date Posted: 19 March 2010 at 7:25pm
the serial port should have a break out to ? number of 3.5mm jacks
they plug in to each input module BUT
each in put mod will need to be fitted with a VCA  and a 3.5mm socket
Rich
PS i had one once !!!
Date Posted: 07 December 2012 at 4:36pm
Bringing this thread back from zombie land, does anyone have a schematic or circuit diagram for the main mixer section?  I plug mine in and it is very very quiet, put it on pfl and it hard clips, but I got it off ebay for £30, so could well be only half of it in there.
Date Posted: 07 December 2012 at 5:01pm
Gavin,make sure the main contact strip bus that connects all the modules together is clean,also clean the pfl function switches on all the modules.
Date Posted: 07 December 2012 at 5:08pm
'kay.Thumbs Up
Posted By: mostyn
Date Posted: 07 December 2012 at 5:41pm
jbl man,the line modules on mine seem very quiet in comparison to the phonos;also i noticed something,the logo on the psu monitor module-like mine-lacks the fs logo though i gave ian at fs the serial number he reckons mine was made about 93?
Date Posted: 07 December 2012 at 5:59pm
I believe mine (the one in the photo above) was made around 1984,DJ Simon Harris bought it new from Formula sound,and used it on his early mixes,even Pete Tong and Froggy used this actual mixer too...Simon originally had it in his first studio.
Posted By: mostyn
Date Posted: 07 December 2012 at 6:02pm
any recommendations on cleaning the rs connectors on the ribbon please?
Posted By: Pinyorouk
Date Posted: 07 December 2012 at 7:15pm
JBL, I have always wanted to ask this question. Is Simon Harris on this forum the same Simon Harris who produced a track called: "Bass, How Low Do You Go?"?
Date Posted: 07 December 2012 at 8:00pm
The very same!
Simon also had a number 1 hit with The Real Thing- You to me are everything.
Date Posted: 07 December 2012 at 8:13pm
The very same!
He is a legend. That is a classic track. The Lyrics are full of meaning and the instrumentation full of Soul! Still sounds great to this day.
Date Posted: 07 December 2012 at 8:20pm
He was the producer on that track Pinyorouk,Simon has a gold disc on his wall for that one.
Date Posted: 08 December 2012 at 3:03pm
In the main power module on the top board there is an empty chip space, I presume for ME5534AN.  Should this be occupied ?  Can I use one out of a channel strip to see if there are any other faults?
Posted By: Daniel S
Date Posted: 12 January 2013 at 11:02am
Burningbush, are you still interested in the schematics for the PM80? If so, PM me.
I have few Formula Sound mixers myself, they are simply awesome mixers Big smile
Posted By: mostyn
Date Posted: 12 January 2013 at 11:09am
i too have a pm 80 and wonder if you have any spare modules for it for sale?
cheers,mozza
Posted By: biskit
Date Posted: 22 October 2014 at 9:31pm
I've just come across this thread by chance, I'm looking for shallow rack cases similar to those shown above for a PM80 mixer, I intend to make up a connector panel to go above the mixer in the rack so only top access is required, and ideally a removeable lid.  Having great trouble finding a suitable case - can anyone suggest a UK supplier of something suitable? I must be searching using the wrong terms. Thanks!
Posted By: ermita
Date Posted: 22 October 2014 at 9:45pm
There's a forum member here before offering custom cases if I remember correctly...im sure you could always try other companies if they can do you a one off according to your requirements.... but obviously this might cost you extra than the standard case.
Posted By: Daniel S
Date Posted: 23 October 2014 at 8:15am
For my mixer I'm using this: http://www.thomann.de/gb/thon_19_koffer_8_he.htm
Distortion is evil
Posted By: pfly
Date Posted: 23 October 2014 at 10:37am
System 2000! gimmegimmegimmegimme!
Date Posted: 23 October 2014 at 10:49am
Very shiny.Heart
Posted By: sasha1126
Date Posted: 02 January 2015 at 11:10pm
hi Good evening to you i have seen your posts on the PM 80 and wonder do you have knowledge of the PM 90 i have one for years and has stood by me through thick and thin. but in the space of a few weeks i loaned it to a friend of mine and he used on a dodgy generator and took out all the regulators on the power supply, i have replaced them and all was ok , now a few weeks later an output channel has died and i have a hissing and popping sound on start up, . i have changed all the ics on the output card (pc 257) still no joy. i am running it in mono mode untill i get time to investigate more but i am hitting a wall , unfortunately i dont have a scope to trace so i am looking for any pointers you might have .
Posted By: Radish
Date Posted: 28 November 2023 at 7:50am
Hi, did you sort this out in the end.  If not happy to help.
Cheers,
Chris.
Posted By: Radish
Date Posted: 28 November 2023 at 9:21am
Hi,
I don't suppose your PM80 crossfader is for sale.  I have been looking for one with the number selectors.
Cheers,
Chris.
my quenstion is...
thanks
Posted By: Radish
Date Posted: 11 May 2024 at 9:26am
I know it was years ago, but did you manage to fix this?   Could be a blown Op Amp in the master module.   I have circuit diagrams and fixed quite a few if you need help. Cheers.
Posted By: Radish
Date Posted: 11 May 2024 at 9:33am
If the missing chip on the top board (that contains the display LEDs) was a 8 pin (DIP-8) IC, then it should be an NE5532AN.
Posted By: Radish
Date Posted: 11 May 2024 at 9:56am
Hi,   I don't suppose you still have the crossfader do you?  Kind regards, Chris.
my quenstion is...
thanks
