Determine whether c-audio 606 has been upgraded
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=38642
Printed Date: 27 March 2026 at 2:16am
Topic: Determine whether c-audio 606 has been upgraded
Posted By: _SLN_
Subject: Determine whether c-audio 606 has been upgraded
Date Posted: 30 April 2010 at 12:55am
Did a search and wasn't able to find anything on this.
Does anyone know the easiest way to determine whether a C-Audio 606 has been upgraded to a 707?
Thanks in advance.
Posted By: audiomik
Date Posted: 30 April 2010 at 4:21am
There are a number of posts on other Forums about this,
try:
http://www.blue-room.org.uk/lofiversion/index.php/t15826.html
try measuring the output voltage of one channel using a sinewave input into an 8ohms load just below the level of the clip led coming on,
Calculate the output Power from the Formula:
Voltage (AC Volts) squared, divided by the load resistance (Ohms), equals Power (Watts)
Compare this measured power output to your user manual or other posts on these amps to see which one you have
Hope this helps
Mik
