Beware the one eyed monster!
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=39393
Printed Date: 26 March 2026 at 7:10pm
Topic: Beware the one eyed monster!
Posted By: The Builder
Subject: Beware the one eyed monster!
Date Posted: 22 May 2010 at 7:23pm
http://www.freespeakerplans.com/index.php?option=com_jfusion&Itemid=64&jfile=viewtopic.php&f=7&t=1132 - http://www.freespeakerplans.com/index.php?option=com_jfusion&Itemid=64&jfile=viewtopic.php&f=7&t=1132
It just is.
Posted By: Saul
Date Posted: 22 May 2010 at 7:31pm
i know what that is.....
Date Posted: 22 May 2010 at 7:44pm
Bloody loud that's what that is.
It just is.
Posted By: Teunos
Date Posted: 23 May 2010 at 10:03am
I don't. What is it?
Best regards,
Teun.
Date Posted: 23 May 2010 at 10:20am
It's a symmetrical, folded, tapped horn.
Staips plans, not sure if he is releasing them.
It's only 600mm deep as well.
It just is.
Posted By: staiper
Date Posted: 23 May 2010 at 10:45am
It is just ~45Hz tapped horn.. Basic plan layout idea was few years old when I have designed sub for line array sys. but that cabinet was pretty much larger than this "Cyclops" prototype.
Initiated by Nick's (The Builder)  http://www.freespeakerplans.com/index.php?option=com_jfusion&Itemid=64&jfile=viewtopic.php&f=39&t=1086&start=10 - topic on FSP I came to idea to make some compact (as possible) and loud "universal" -without kick bin bass cabinet to cover ~45 - 130Hz range (in multiples will do 40Hz ..even a bit under I expect).
It is posible to easily modify design to get even single starts very loud stright from 40 Hz but than cabinet size will be larger and goal of "compactness" will be a bit sacrificed.
Dimension of cabinet is H=1052mm, W=576mm (truckpack f.) , D=618mm  ~ 375liters overall which is less than most standard double 18 BR-s
I have few ideas on mind while drawing this plans .. as symetrical cone loading, position of speaker to improve usable upper end or responce, cooling..
It is possible to fit lower extension TH within same dimensions of cabinet but in that case I have to sacrifice some of ideas noted above which will drag cabinet closer to "scoop field" and than kick bin may be required what I have aimed to avoid.
BIG THANKS TO NICK for building and testing.Big smile
Running out for coffe :) ,
    Stipe
Plans:
Higher resolution PDF available on request.
Plans are free for personal use...
not for commercial production (for sale) ..just in case that someone have idea how to get obscene
rich from this plans and buy some... BMW-s (new Tongue) let me know.
edit:typos; plans added
Just do it! ..or do not.. ;)
Posted By: tomschute
Date Posted: 23 May 2010 at 11:01am
you never cease to amaze me Clap
any plots / sims?
www.stableaudio.co.uk
Speaker Building Services
Date Posted: 23 May 2010 at 11:18am
At some point/meet/gathering I'll bring this down (up) for those who know to, "play" measuring with.
Going to buy a Fane 1000 and keep it as, "Central bin" for system or just with two spkrs on sticks.
It just is.
Posted By: breakdabeat pete
Date Posted: 23 May 2010 at 2:26pm
looks interesting! hope to see some plots and maybe plans?? Wink
٩(̾●̮̮̃̾•̃̾)۶
Posted By: Sinfinity
Date Posted: 23 May 2010 at 2:44pm
Could you bring it along to CSG's amp meet ?
Matt at ukamp dot co dot uk
Date Posted: 23 May 2010 at 4:50pm
Where is it?
It just is.
Posted By: staiper
Date Posted: 28 May 2010 at 1:09pm
Plans added on first page Wink
Posted By: bitzo
Date Posted: 28 May 2010 at 3:12pm
opensource warrior!Thumbs Up
http://www.unitedroots.it - United Roots SoundSystem site
Posted By: Saul
Date Posted: 28 May 2010 at 3:15pm
excellent staipe
what do you reckon for live music?
Posted By: staiper
Date Posted: 28 May 2010 at 4:33pm
excellent staipe
Yes in fact I have thought about this as "universal" PA cabinet to be loud and defined for live gigs. Tried to pick benefits of tapped horn tech. but without need for single cabinet to  hit super-low freq.  to keep cabinet size manageable easily enough by two persons.
Date Posted: 28 May 2010 at 4:36pm
looks like a fun build! do you reckon it would work well with cheaper drivers such as celestion ftr 18's / fane xb's ? It would be nice to see hornrep inputs. I wouldnt mind hearing some of these!
٩(̾●̮̮̃̾•̃̾)۶
Posted By: Saul
Date Posted: 28 May 2010 at 4:37pm
might build a prototype :)
Posted By: staiper
Date Posted: 28 May 2010 at 4:50pm
Big smile  Also as you can see I have slight irrational phobia of "aces panels" on cabinets ..so I am trying to avoid them where ever I can .. (OK happened on some designs ..cant help)
+ this one is designed so many panels share same dimensions (color-coded same on part list) which may simplify and help on panel-cutting preparation phase.
Despite layout is pretty straightforward cabinet assembling requires good thought before about gluing/fixing order. Also important to start and keep things absolutely symmetrical.
Posted By: tweeter box
Date Posted: 28 May 2010 at 5:05pm
Thumbs UpClap  top ranking Staiper
PRECISION SOUND SYSTEM.
Posted By: djstefanos
Date Posted: 28 May 2010 at 5:28pm
is it heavy?
system:
20 x MA W8L
12 x MA W8LC
12 x MA W8LM
20 x MA S-218
8 x D.A.S. ST-112
Date Posted: 28 May 2010 at 8:48pm
Yes
It just is.
Date Posted: 28 May 2010 at 8:49pm
Jigsaw puzzle those braces!
It just is.
Posted By: Saul
Date Posted: 28 May 2010 at 10:07pm
yep - don't worry - im kinda good at that..
got the right drivers too.... Smile
looks like we might have a potential new live band bin in the arsenal.
Date Posted: 28 May 2010 at 10:26pm
Deffo, kick drum and bass guitar will be awsome.
It just is.
Posted By: jollygt78
Date Posted: 28 May 2010 at 11:21pm
why are the fane drivers so hard to find in the USA, or am i missing something.
Posted By: Saul
Date Posted: 28 May 2010 at 11:22pm
because they're a british driver perhaps?
Date Posted: 28 May 2010 at 11:30pm
i'm sure this is the case.  i've been looking for a cabinet like this to build for sometime now.
Date Posted: 28 May 2010 at 11:44pm
B&C TBX and 18 sound also simmed great for these.
See posts on Free Speaker Plans
It just is.
Posted By: mrchay
Date Posted: 29 May 2010 at 9:15pm
Can anyone help me with modeling this one?
If its like other tapped horns, i'm guessing it will be ok to build a 12inch version by just adjusting the width of the cabinet to accommodate the smaller driver (leaving the other dimensions the same).
Mainly though, im interested in building a quad-10inch version of this. Can anyone recommend a cheap but big, big xmax 10 inch driver? I was thinking it would be heavy, but it would be an absolutely amazing bass guitar amp as well as an all round bass solution.
Posted By: _djk_
Date Posted: 30 May 2010 at 2:06am
"If its like other tapped horns, i'm guessing it will be ok to build a 12inch version by just adjusting the width of the cabinet to accommodate the smaller driver (leaving the other dimensions the same)."
For best results, learn how to use Hornresp and model it before build.
djk
Posted By: heinrich
Date Posted: 30 May 2010 at 3:11am
since I can't hear this on paper, what about posting HORNRESPONSE plots so we would also know how this thing plays compared to the recent ones (ex. MS18, es18bph, microscoop).....
sorry, I dont trust your earsWink
best regrads
.....power is nothing without control....
Posted By: Xmax extreme
Date Posted: 30 May 2010 at 4:41am
Clap
best regrads
Welcome back bai!!!! For sure we can see your turbosound system right now... Big smile when will we visit
 your place?
@staiper
AMAZINGLY NICE STAIPE!!!ClapClapClap
Maximum Excursion
Don't criticize your own competition, it looks like a publicity of your own commercial products.
Posted By: TDA-Audio
Date Posted: 30 May 2010 at 8:22am
Quote It is just ~45Hz tapped horn.. Basic plan layout idea was few years old when I have designed sub for line array sys. but that cabinet was pretty much larger than this "Cyclops" prototype.
to Stipe Ercegovic
You The Legend !!!!
my be 12" or 2x12" version ????
 or 21" ??? - great Tapped by Stipe??
Posted By: mykey-
Date Posted: 30 May 2010 at 10:07am
to Stipe Ercegovic
You The Legend !!!!
Embarrassed please read this TDA before you go calling someone a legend
"Higher resolution PDF available on request.
not for commercial production (for sale) ..just in case that someone have idea how to get obscene rich from this plans and buy some... BMW-s (new Tongue) let me know."
Date Posted: 30 May 2010 at 10:27am
Quote not for commercial production (for sale)
say this china manufactur
Date Posted: 30 May 2010 at 10:35am
best regrads
And I don't trust computer sims, none on them.
Wood and earsThumbs Up
It just is.
Posted By: joshd963
Date Posted: 30 May 2010 at 12:25pm
12v anyone?
Posted By: djyves
Date Posted: 30 May 2010 at 6:11pm
One Eyed Monster in sketchup: http://rs861.rapidshare.com/files/393339533/kast_zonder_laatste_paneel.skp - click here to download
Posted By: djyves
Date Posted: 30 May 2010 at 7:19pm
does somebody have the hornresp input data, or can somebody tell me how to calculate them in this design?
Posted By: rich_gale
Date Posted: 30 May 2010 at 7:38pm
Originally posted by joshd963 joshd963 wrote:
12v anyone?
in 12" would probably be immense down to 60hz.
how would a jbl 2242 work in this?
Date Posted: 30 May 2010 at 7:41pm
I got the impression that any driver would be in control, just keep power down.
Gotta send the Fane back this week, I'll try a 186 for fun.
Nick
It just is.
Posted By: darkmatter
Date Posted: 31 May 2010 at 4:41pm
My GUESS at hornresp inputs:
Note Le is unknown - I believe this can make a fair bit of difference in a tapped horn.
Nice design Stipe! Like the handle positioning. I've been wanting to do something like this in a 12" version but mine would sacrifice some max output in favour of a little low extension.
This cab seems to have excellent excursion control above 45Hz. I know it's weird but I've got a suspicion that high excursion control at tuning frequency might be what killed my Ciare 12SW (end of coil sitting outside the gap at high power so not much movement to allow cooling). I wonder whether underhung coils (XBL^2?) would get the most from tapped horns?
Date Posted: 31 May 2010 at 8:26pm
im looking at a very high excursion car audio driver for this exact reason.  not underhung, but a 15mm top plate should help get some more heat away.
Posted By: _djk_
Date Posted: 31 May 2010 at 11:08pm
"I know it's weird but I've got a suspicion that high excursion control at tuning frequency might be what killed my Ciare 12SW (end of coil sitting outside the gap at high power so not much movement to allow cooling)."
Look a bit like this, did it?
" I wonder whether underhung coils (XBL^2?) would get the most from tapped horns?"
Run the numbers and see.
http://pasub.com/PASUB460.pdf - http://pasub.com/PASUB460.pdf
5" coil, 20mm underhung x-max.
djk
Posted By: (((THUMPER)))
Date Posted: 03 June 2010 at 2:04am
better late than never;
Give this guy a call, he's a real ace. Kinda weird... but really knows his sh1t.
http://www.usspeaker.com/homepage.htm
He carries several fanes.
"...like a big paper dragon..."
Posted By: streetsounds
Date Posted: 06 June 2010 at 4:33am
Originally posted by Xmax extreme Xmax extreme wrote:
Clap
best regrads
 your place?
@staiper
This is pretty interesting..Im gonna try to build one just to hear it, I dont rely much on sims, ears are better..xmax/heirich you are welcome to visit my place for you to hear it.Wink
Great work Staipe!!!
Bass matters...
Posted By: djyves
Date Posted: 13 June 2010 at 4:46pm
Nick
Already tried the 186?
Date Posted: 14 June 2010 at 11:28am
I have the prototype and 186's, I'll try them at some point soon...
It just is.
Posted By: kiriiz
Date Posted: 14 June 2010 at 2:59pm
Plots plots plots :)
Posted By: djyves
Date Posted: 14 June 2010 at 3:31pm
here are some plots, I used the input parameters from darkmatter:
input screen:
black is void v18-1000 and grey is pd186, (the fane 1000 is the same as v18-1000, at least i don't see any difference between the two)
all drivers do reach xmax at 42 hz with 1000w, so anything above 42 hz under 1000w should be fine.
Posted By: Saul
Date Posted: 14 June 2010 at 4:08pm
Originally posted by djyves djyves wrote:
, the fane 1000 is the same as v18-1000, at least i don't see any difference between the two)
really?????
theyre fairly different drivers
i was potentially planning 4 of these with the fane 1000
Posted By: bitzo
Date Posted: 14 June 2010 at 4:16pm
to me HR isn't good to predict this cab response.
Posted By: Oscar
Date Posted: 14 June 2010 at 5:20pm
I'm not sure if I read your thought in parenthesis correctly, but XBL^2 isn't underhung, since it has multiple gaps
http://www.acousticdev.com/Files/XBLDetails.pdf
Smile
Posted By: djyves
Date Posted: 14 June 2010 at 7:01pm
really?????
I mean, I don't see an difference in the graph, but I will try again.
Posted By: djyves
Date Posted: 14 June 2010 at 7:05pm
here is a good graph of the fane 1000 vs void v18-1000:
the fane 1000 has a higher excursion around 60 hz, they both reach xmax with 1000w 41 hz
Posted By: djyves
Date Posted: 14 June 2010 at 7:12pm
black is fane 1000,
grey is v18-1000
Posted By: djyves
Date Posted: 14 June 2010 at 7:14pm
at +/- 40 and 60hz the fane 1000 goes over xmax
the v18-1000 does not go over xmax at 60 hz
Posted By: bitzo
Date Posted: 14 June 2010 at 9:24pm
akabak sim with b&c 18tbx100, eleven section, I take care of magnet diameter in order to reduce the 10th section.
Date Posted: 28 June 2010 at 8:19am
my be ? recalculated 1x12" ? 2x12" ?
Posted By: bitzo
Date Posted: 28 June 2010 at 9:10am
Interesting but in this way you'll loose the simmetrical load of driver.
Posted By: grec
Date Posted: 28 June 2010 at 9:33am
TDA,
Dima,
in that configuration double 15 gona be  way better.
Posted By: tobiazz
Date Posted: 03 August 2010 at 7:37pm
Hey, can anyone sim the Beyma 18G400 unit for me? i have 4 pcs laying around, it could be nice to have 4 powerfulls subs mad whit them :)
Bast regards Tobias
Posted By: daywalk3r
Date Posted: 12 August 2010 at 7:14pm
Bast regards Tobias
Beyma 18G400 in original (unmodified) CB-18:
SPL 2pi @ 1W (Beyma 18G400, Fane 18-1000)
group delay (Beyma 18G400, Fane 18-1000)
cone displacement @ rated power (400W)
SPL 2pi @ 4*400W (4 cabs on ground)
Relatively good group delay figures. Should be "honk-safe" till at least 130Hz.
The driver is exceeding Xmax at rated power by about 1mm (@58Hz), at least according to the Hornresp guesstimates.. However, 18G400 is an older model, and its specs from times when the BL fudge-factor was not "invented" yet.. By looking at the aged datasheet, it seems that the Xmax value of 7mm was calculated for close to 100% BL - which means that going 1mm over it should not be a problem. Should be safe and sound good from 38Hz+ @ 400W.
Cheers.
Posted By: tobiazz
Date Posted: 15 August 2010 at 4:55pm
Thanks ! looks like it should do quit well in this design :)
Now i just need 8 sheeds of ply and a lot of time !
Cheers
Posted By: Lincoln1
Date Posted: 29 June 2012 at 12:21am
Guys, would anyone please be able to sim the RCF L18P200N driver?
I  have 4 of and keen to try something different to my bp6 boxes. I know these are old drivers but I already have them and they are still not bad, (quite high excursion and power handling).
Cheers,Lincoln.
