x12 / x15 with Eminence and Selenium
Category: Plans
Forum Name: X10, X12, X15 and XM15
Forum Description: Discussion / Questions about the X10, X12, X15 and XM15
URL: https://forum.speakerplans.com/forum_posts.asp?TID=39445
Printed Date: 27 March 2026 at 8:37am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: x12 / x15 with Eminence and Selenium
Posted By: skejack
Subject: x12 / x15 with Eminence and Selenium
Date Posted: 24 May 2010 at 9:07pm
Hi, i'm from Uruguay, and I'm trying to design a PA system for live sound...
Now, I can't to get a PAudio components, and I thought of using the speaker: Eminece Kappa Pro 12a and the driver: Selenium 3305 TI...
Eminence specs: http://www.eminence.com/pdf/kappapro-12a.pdf - http://www.eminence.com/pdf/kappapro-12a.pdf
Selenium specs: http://www.selenium.com.br/#/Produtos?c=1&m=0&f=0&l=13&r=0.1212192764505744 - http://www.selenium.com.br/#/Produtos?c=1&m=0&f=0&l=13&r=0.1212192764505744
Another possibility is to use two x15 cabinets instead of one x12 per side with Eminence Kappa Pro 15a, and the same driver...
Do you think? Which option will have better results? Have you a suggested design for my components? (everything is for mid/high range)
Thanks!
Posted By: skejack
Date Posted: 24 May 2010 at 9:10pm
I forgot!
In the Eminence's website have a cabinet design for a Kappa 12a, but, i can't understand this information..
This is here: http://www.eminence.com/pdf/cab-kappapro-12a.pdf - http://www.eminence.com/pdf/cab-kappapro-12a.pdf
