X12 Port Sizes
Category: Plans
Forum Name: X10, X12, X15 and XM15
Forum Description: Discussion / Questions about the X10, X12, X15 and XM15
URL: https://forum.speakerplans.com/forum_posts.asp?TID=41771
Printed Date: 27 March 2026 at 8:37am
Topic: X12 Port Sizes
Posted By: Forward Motion SS
Subject: X12 Port Sizes
Date Posted: 02 August 2010 at 10:24pm
Hi all, I'm building a pair of X12's but have made the sides 1000 mm instead of the 900 mm to fit a bigger horn in & need to know what size ports to cut! Can someone please help as I want to cut & fit the baffles tomorrow night Confused
Many thanks
Dodge
Posted By: ceharden
Date Posted: 04 August 2010 at 1:29am
The increase in cabinet volume will actually only reduce the tuning frequency by less than 5Hz so to be honest I'd just leave them as-is.
Date Posted: 04 August 2010 at 4:45pm
Sweeeet!!
Posted By: V-ITAL Sound
Date Posted: 05 August 2010 at 1:00pm
what? so easy?
Posted By: Sequence Empire:::..
Date Posted: 06 September 2010 at 12:36am
I've been playing around with 2 x 18Sound 12ND610 16ohm mid-woofer for an X12 style cab in WINISD,
I get reasonable response with 75L tuned to 65Hz.
If you use the cross-over filter simulation in WINISD, (Highpass 2nd order 180Hz, lowpass 1400Hz 2nd order), what is the relevance of having the ports in the cab??? are they actually doing anything while the cabs are operating this freq band?
Posted By: Glenn
Date Posted: 27 October 2010 at 10:08pm
The variation of x12 I made is 10L bigger (to fit bigger horn as well) and the holes I used are 110mm instead of 100mm. It seemed to be tuned around 60hz when I had it stuffed with dacron.
All cabinet walls/internals were lined with carpet underlay as well. I ended up taking the dacron out and leaving the underlay in as the vocals seemed to sound better to me. I didn't bother to measure tuning again but the bass didn't strike me as being different.
