Planar Wave horn
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=4230
Printed Date: 29 March 2024 at 9:00am Software Version: Web Wiz Forums 12.06 - https://www.webwizforums.com
Topic: Planar Wave horn
Posted By: Mircea Bartic
Subject: Planar Wave horn
Date Posted: 12 March 2006 at 4:57am
It looks like I'll have some new toys for a few days
I have a custom order for some really powerfull subs
http://www.stocare.as.ro/PWH18SW1P.gif - Planar wave horn plan
the sub used will be Selenium 18SW1P http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=264-438&ctab=10 - http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7& Partnumber=264-438&ctab=10
------------- general manager & head designer at nexus-acoustics research http://www.facebook.com/nexus.acoustics.research" rel="nofollow - http://www.facebook.com/nexus.acoustics.research
Ex Nexus_3
Date Posted: 12 March 2006 at 4:58am
I'll post some pics as I'll build them next week
Ex Nexus_3
Posted By: tb_mike
Date Posted: 12 March 2006 at 5:25am
Planar horn bass reflex?
18" on BR,decent anyway.
Date Posted: 12 March 2006 at 5:40am
it's a design derived from dynacord Planar wave horn subs
the port ending outside the waveguide helps achieve better subbass reproduction
horn coupling is not necesary
Ex Nexus_3
Posted By: tb_mike
Date Posted: 12 March 2006 at 8:58pm
Ah yes i remember that sub now. When you do make some,could you measure its impedence vs frequency etc? Im interested in how that short tunnel helps it at all.
Posted By: freddyi
Date Posted: 13 March 2006 at 2:28pm
COOL horn expansion rate - PV Low
Rider (if meet spec) look like a drop-in substitute for US
cheapass. Are PV Low Rider 18 OK? -- I've 1808 and they are
way off specification so are now "open baffle woofer"
Date Posted: 13 March 2006 at 2:54pm
one way of testing if other speakers work in the design is this one:
because there is no speaker simulation program capable to polt this design we have to work around that.
1. plot this speaker in bass box as a simple bassreflex box (no horn) 2. load another driver in that enclosure and try to reach the same plot 3. when you have identical plots then it should work ok in the planar horn.
modifications to the reflex ports will be necesary
I know that P-audio c18-650EL works in this design , but you have to shorten the ports by 110 milimeters
Ex Nexus_3
Posted By: tb_mike
Date Posted: 13 March 2006 at 7:19pm
Freddy - Easier to make a K?
Whatabout d&B B2 patent? I want to try it,measure impedence etc,even if it just makes a nice 45hz !
Posted By: djstefanos
Date Posted: 13 March 2006 at 10:28pm
does anyone know where i can get the full plan of the sub above? Those are really easy to make. Just move the baffle half way....
I have heard those (dynacords) in stacks of 6 per side during an outdoor concert in a square. Rattled my glass of wine in the bar i was in.
Posted By: james folkes
Date Posted: 14 March 2006 at 5:44am
probably a silly question, but i'm assuming to load the driver you shimmy it
past the mouth brace and then climb half in side the cab to bolt it in?
pictures would indeed be nice, plots would be nicer.
james.
------------- mardy hippy.
Posted By: Mark James
Date Posted: 14 March 2006 at 8:14am
are they actualy that simple/good? im interested in finding out more!
Posted By: Peter Moller
Date Posted: 15 March 2006 at 5:11pm
2 questions:
Can you explain the hornloading part of this box?.. In other words: How do I do the math to design that horn?... Are we talking Helmholz resonators or ?
Why does the handles on your drawing say "Cobra PWH" :-)... Did you measure a PWH sub or are you just using the outside dimensions and retuning it to suit the Selenium driver?
/peter
Posted By: Dave Slater
Date Posted: 01 April 2006 at 1:01pm
@ nexus where did you get that design from?
i was just about to try simulating it in akabak and it had gone!
Date Posted: 01 April 2006 at 3:03pm
james. |
you got it right James
unfortunately there are no building pics for this one
I hope the customer will send me some pics when he has time
Ex Nexus_3
Date Posted: 01 April 2006 at 3:13pm
2 questions:
/peter |
1. the design is still using a Helmhols resonator, but beside that there is a waveguide in front of the speaker.
this subwoofer acts like a horn above 60Hz but below it's like any bassreflex design, It's a bit weird, but it is not based on sims and serious design, for the simple reason that I have no programs that can simulate this thing.
Trial and error is the key word.
2. it says cobra pwh because I used the picture of the cab made by dynacord to draw that picture.
P.S. Dynacord subs do not look like that on the inside They use resonators inside the mouth of the waveguide, and that causes some problems, because in theyr design the sub sounds BAD at close range By extending the resonators at the waveguide mouth we were able to corect some phase abnomalies thay ocured in the previous design, and make it sound much better at close range. Dynacord's problem came from the fact that the resonators worked inside a horn that was not able to sustain the long wavelenght that they produced.
this design is smaller than dynacord's by about 30% and sounds better
Ex Nexus_3
Date Posted: 01 April 2006 at 3:14pm
that design is posted on my forum
I used a free hosting to store it, but now it should work again.
Ex Nexus_3
Date Posted: 01 April 2006 at 5:34pm
Ex Nexus_3
Date Posted: 03 April 2006 at 7:00am
cool i'll see what i can do
Posted By: TDA-Audio
Date Posted: 03 April 2006 at 1:14pm
Posted By: PoteirosCorp
Date Posted: 04 April 2006 at 9:16am
Hey TDA, have you more information from de plan of your photo ?? Size of the ports, wich drivers use, ect, etc ??
Thank you
Posted By: freddyi
Date Posted: 06 April 2006 at 6:25pm
~like yamaha patent?
link by DJK when trying to figure out "basspipe"
http://164.195.100.11/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=/netahtml/srchnum.htm&r=1&f=G&l=50&s1=5313525.WKU.&OS=PN/5313525&RS=PN/5313525 - http://164.195.100.11/netacgi/nph-Parser?Sect1=PTO1&Sect 2=HITOFF&d=PALL&p=1&u=/netahtml/srchnum.htm& r=1&f=G&l=50&s1=5313525.WKU.&OS=PN/5313525&a mp;RS=PN/5313525
http://164.195.100.11/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=/netahtml/srchnum.htm&r=1&f=G&l=50&s1=5313 -
Posted By: navsys
Date Posted: 07 April 2006 at 7:21am
Looks like that patent has expired, so no problems with making this type of speaker.
I was wondering what frequency have you made the front waveguide resonate at? The front waveguide looks a little short to me, so whilst the extra width pulls the resonant frequency down, doesn't it reduce the loading on the driver at the higher frequencies?
Would a small triangular section in front of the speaker to act as a throat into a small section of horn load the speaker better?
They look rather attractive in that you can ( with a few modifications to the dimensions) make one out of a single sheet of ply (apart from the bracing and vents)
Posted By: _djk_
Date Posted: 08 April 2006 at 12:46am
"Looks like that patent has expired, so no problems with making this type of speaker"
The Yamaha patent is still active, but may not be a problem unless you are going to build for retail sale.
This type of patent runs for 17 years from date of issue. Newer patents run 20 years from date of application (after being granted). This ends up being about the same length of time as it takes about 3 years after applicatin before they issue.
Paul Voigt used a 1/4 W stub with his designs back in the '30s, I doubt if a modern patent would stand up to litigation.
The design from Nexus_3 looks well thought out.
------------- djk
Date Posted: 08 April 2006 at 5:35am
Ex Nexus_3
Posted By: MarjanM
Date Posted: 08 April 2006 at 7:55am
Very nice indeed.
Can you tell more of how do they sound.
I am trying to find the right home for my 12 18Sound 18W800.
Mybe this box will do.
Please give us some more coments and pictures.
How would a cluster of 6 or 8 sound?
Regards
MarjanM
Posted By: navsys
Date Posted: 08 April 2006 at 10:43am
I realise that time wise it hasn't expired however according to my checks they never paid the fees for the patent so it actualy expired some time ago!
Having looked at nexus's picture, I somehow think my woodworking skills arent in the same league - but thanks for the pics, it has given me some clues on how to go about it . I'm having ago at building some 18 BPH's this week, then I'll have a crack at one of these. Somehow I don't think I'll be posting pictures though.....
Date Posted: 09 April 2006 at 4:03am
MarjanM wrote:
Very nice indeed.
Regards
MarjanM |
a cluster of 8, ( 4/side), in free air, made my vision blurry about 4 years ago, fed with about 8KW of drive
the event was a techno festival held here in Romania
plenty of subbass
Ex Nexus_3
Posted By: MarjanM
Date Posted: 09 April 2006 at 7:19am
I was more thinking of 8 per side.
What is the advantage comparing to the BR design with the same driver?
Anyhow, can you post more pictures plizzzz.
And what are those tops?
Date Posted: 09 April 2006 at 8:36am
ditto [pictures that is] |
------------- me so horny me love you long throw horn loaded for her pleasure
Date Posted: 10 April 2006 at 4:35am
That sub looks great. Also, what tops are those??
Nexus, I was checking your forum and see a mini planar sub with 2x15", did you build one or just exists on paper??
What will be best, this proyecto or the 2x15 >??
Keep on the good work
Date Posted: 11 April 2006 at 7:26am
those are a version of the F17PWH from dynacord, but with mid drivers on them
the 2x15 version is not fully tested yet
I would encourage you to build this planar horn using the 18" driver
Ex Nexus_3
Posted By: djtosco
Date Posted: 11 April 2006 at 1:38pm
The plan is very similar to the Stage Accompany XL-Bin. Look at www.stageaccompany.com
Date Posted: 12 April 2006 at 6:53am
Do really your planar will need a mid-bass cab ?? or can be used to 150hz
I guess that version of F17PWH will have the mid drivers closed.
I'm thinking on your planar charged with LX60 from Beyma (specs are like the selenium) and on a non-distance future put them plateamps and turn them to active systems (a friend build them at a good price). Of course modifications to the ports will be necesary.
On the other side, how is your opernsource midtop going on??
Cheers
Posted By: mykey
Date Posted: 12 April 2006 at 10:15am
djtosco wrote:
The plan is very similar to the Stage Accompany XL-Bin. Look at www.stageaccompany.com | thats what i thought i saw them back in 96/97 im sure it was a double version, they must have been the first i rekon
------------- ......just all them hanging there like giant bananas.
Date Posted: 19 April 2006 at 9:05pm
Any more photos Nexus ???
Date Posted: 20 April 2006 at 2:44pm
Cheers
1. the planar horn goes happily past 150Hz just fine 2. you guessend right 3. interesting ideea of putting plate amps on the subs (I presume there will be some beefy amps inside) 4. opens source mid top is stagnating at the moment, but I'm sure that as the weather warms there will be more activity (warm weather means prototype building)
Ex Nexus_3
unfortunately no
I'll post more when there will be more taken
Ex Nexus_3
Date Posted: 21 April 2006 at 3:12am
I dont know what beefy means (translator doesn`t reckon that word)
The plateamps I can get will be 750rms at 8ohms.
Currently working on a stage scenario (helping a friend buying the beers and snacks meanwhile he is soldering and stuff)
Posted By: login4
Date Posted: 23 April 2006 at 4:58am
Im looking at those pics and the ports are set back on the baffle i thought the ports go all the way to the front?
------------- CELTIC SUBSONIC SOUND SYSTEMS
Date Posted: 23 April 2006 at 6:31am
they was an earlier version before the improvement was made
Ex Nexus_3
Posted By: login4
Date Posted: 24 April 2006 at 5:11am
so is this design the improved one or the older one, i need to get this all sorted cuz im about to sell my system and start a new build and im thinking of using two of these bins per side for bass. as much info as possable would be really appreciated
Date Posted: 24 April 2006 at 5:33am
the one with the ports all the way to the front is the most advanced version
it hass less phase issues, and goes lower
Ex Nexus_3
Posted By: login4
Date Posted: 24 April 2006 at 6:07am
thanks for the quick reply. im going to try and get my plan up on here to see what you think
Posted By: login4
Date Posted: 24 April 2006 at 6:23am
Here's what im thinking of for now then doubling it in time...
Date Posted: 24 April 2006 at 8:53am
not good
if you'll use those mid tops you'll not be able to hear any mids because of the huge amount of bass.
trust me.
you need something like this:
http://www.dynacord.de/pdf/58_355_download.pdf
I happen to know how it's made on the inside, and what components you can use from P-audio to build it
Ex Nexus_3
Date Posted: 24 April 2006 at 4:11pm
So, are you gonna give that information to the publici, or you want to send me a PM for that top ??
Posted By: MarjanM
Date Posted: 24 April 2006 at 6:09pm
I would also like to know all about that box
Date Posted: 24 April 2006 at 7:06pm
http://zmatek.jinak.cz/diy/pbaudio/coaxialhorn12-2/show_construction.asp.html - http://zmatek.jinak.cz/diy/pbaudio/coaxialhorn12-2/show_cons truction.asp.html similar to this?
[not quite but it looks similar!]
Posted By: JD01
Date Posted: 24 April 2006 at 8:47pm
First of all the original 'planar wave horn' is nothing else than a 7th order bandpass, and that's how it sounds. It does NOT play well above 100Hz (which is why Dynacord demonstrated the Cobra4 system with PWHs from 35 to 60Hz and direct radiating 18" bassreflex boxes from 60 to 125Hz). By putting the rear chamber ports to the front you'll get a 6th order bandpass. Yes, the tunnel in front of the cone does NOT act as a horn, but as a box resonator (it's still helmholtz). You can simulate this by selecting a bandpass of 6th order and set the front port area to the area of the tunnel and the length for the port to about the length of the tunnel. Of course frequencies above the high roll off will come out of the box, because nothing is blocking them, so you measure a slight dropoff of around 2 or 3dB per octave above the calculated high rolloff, but the sound above 100Hz will be muddy.
If your smaller version does sound better this is for a simple reason: The smaller, shorter chamber pushes the high rolloff to a higher frequency. Again, this is in no way a horn....
The F12 top is very weak on mids, of course this can be resolved with a new crossover (which you will need to do anyway because you will use other speakers). It is very important to crossover from the 12" to the HF-driver at or below 800Hz (the original is crossed over at 800Hz), because this horn has no phaseplug and will start to roll off at 700Hz. The sensitivity of the 12" is around 103 to 104dB in the original, so not that much. The second top shown on the cz site is surely more efficient and better sounding in the lower mids.
Posted By: login4
Date Posted: 25 April 2006 at 4:18am
im just not shure what to make next maybe ill keep things simple and build a pair of G-Subs (218) and four 2x15" + Horn fullrange cabs.
What do ya recon
Posted By: mykey
Date Posted: 25 April 2006 at 11:42am
or like this
Posted By: Mike Severloh
Date Posted: 10 May 2006 at 4:23am
Planar Wave horn and matching top
Hi all !
Last info about the original PWH-subs was they sound horrible, letīs hear if the outside-the-guide ending ports will do better.
Using AJ-Horn5 this construction should not be too hard to simulate. Give it a try.
I recon the JAN Audio-horns for the tops surely are excellent material. Your pic shows an MX12. Recently I try to make them sell a single mid-sized 12inch flare, that will be an M12.
Anybody got experience with the M10, M210 or the M212 ?
Itīs http://www.janaudio.com - www.janaudio.com
Mike.
Posted By: MarjanM
Date Posted: 10 May 2006 at 7:16am
Can someone PM me the price for MX12
Date Posted: 16 May 2006 at 5:46pm
I've been busy the past 2 days
Ex Nexus_3
Date Posted: 16 May 2006 at 5:49pm
tops
P-audio WN-15S+ BM-D750 on PH-2723
subs
Selenium 18SW1P
Ex Nexus_3
Posted By: mykey
Date Posted: 17 May 2006 at 3:55am
how do they sound?
help me out here nexus!
i have heard the D&B and Dinacorde bins and rate them both
my question is are they the same cab??
Date Posted: 18 May 2006 at 4:40pm
this design in a version of the Dynacord F18 PWH
it has the ports venting outside the horn for better bottom end in small numnbers (read a few pages back for the exact description)
I didn't know that D&B makes something similar, please give me a link..
They sound lovely, especially when powered by a Phonic Max 2500bridged / bin
Ex Nexus_3
Date Posted: 18 May 2006 at 6:35pm
Posted By: Ken-Tech
Date Posted: 19 May 2006 at 12:22am
Date Posted: 22 May 2006 at 4:06pm
the tops
p-audio Wn15S+BM-D750 on ph2723 horn
subs during testing (thought my house will come down on me)
Selenium 18sw1P
Ex Nexus_3
Posted By: Dr Burnz
Date Posted: 24 May 2006 at 11:52am
BASS IN YOUR FACE! Very nice Nexus, how do they compare to the X1? Sounds like this sub has all the benifits of a reflex and a horn design in one box!
------------- Everyone is a bass junkie, they just don't know it yet.
Date Posted: 24 May 2006 at 12:39pm
I don;t know how it compares to the x1 because i never built one
the planar horn defenately sounds better and trows sound farther away in open air conditions than an X1
Ex Nexus_3
Posted By: JD01
Date Posted: 25 May 2006 at 1:17pm
F#%kin' hell, again, THIS HAS NOTHING TO DO WITH A HORN! It's a bloody bandpass!
Date Posted: 25 May 2006 at 4:17pm
the guy from dynacord who desighed this thing thinks otherwise
He had read this thread, and has confirmed that this design DOES act like a horn
I hope he'll post here soon
Ex Nexus_3
Date Posted: 25 May 2006 at 4:23pm
i think he meant that the x1 is a bandpass
the planar is a horn hybrid, defo has horn quilitys [like hd15 has horn hybridisms within] the planar is a horn hybrid [a nice looking one too!]
how low? and whats the size?
Date Posted: 28 May 2006 at 4:49pm
35 Hz (-6 dB) size is 640x640x900mm
Ex Nexus_3
Posted By: JD01
Date Posted: 30 May 2006 at 11:09am
I'm talking PWH. It IS a bandpass. A horn has ALWAYS an extending flare aka a flare rate above 1. That's the way it works. A non-extending flare aka tunnel is a resonator! In addition a working horn sounds COMPLETELY different. If you want to simulate, what the front resonator does to the sound coming from the cone you just have to use WinIDS, set it for 6th order BP and set the front port to the length of the tunnel in front of the speaker and the port area to the front area of the tunnel. Of course it will play higher than the frequecy the simulation will show, because the direct sound of the cone will go straight through the tunnel, but it won't sound that good. In fact Dynacord demonstrated the Cobra system on last years PL&S with PWH subs only used up to 60 or 70Hz, using direct radiating Cobra subs for upper bass and low mids!
BTW I know the head of developement from Dynacord. He supplied me with a full Cobra4 setup including 8 PWH subs about 1 1/2 years ago to test them. Cobra Tops great, Cobra PWH Sub simply put NOT, sorry. And that's what I told them. I think the people at Dynacord know now who I am and contact me directly, if they have problems with my statement.
Date Posted: 08 June 2006 at 6:34am
Ex Nexus_3
Date Posted: 08 June 2006 at 9:31am
nice!!!
Date Posted: 13 June 2006 at 3:28pm
testing, testing, 1,2,3,
Ex Nexus_3
Posted By: merlin gerwin
Date Posted: 13 June 2006 at 8:17pm
Well.......
Don't just stand there looking at it.
Dance or something.
Which one is you Nexus 3.
Those willing to sacrifice freedoms for security deserve neither
Date Posted: 14 June 2006 at 2:13am
merlin gerwin wrote:
Well.......
Dance or something. |
we were too blown away
Which one is you Nexus 3. |
neither, I was taking the picture with my phone
Ex Nexus_3
Posted By: Ambrocio
Date Posted: 18 June 2006 at 11:38am
Sup guys, First of all let me tell you. I've been reading all your posts and I just love this site.
I want to find a home for 8 EAW LC 1827 ( I dont hve any specs on them)
On a forum someone told me that they ware RCF L18/300. Any way.. will
these drivers work on the planer horn? Im planing to push them with 2
QSC USA 1300.
Thanks
------------- Life begins at 179dB!
Date Posted: 18 June 2006 at 12:38pm
can you post t/s for that driver? I can't find t/s on it...
Ex Nexus_3
Posted By: Ambrocio
Date Posted: 18 June 2006 at 3:09pm
I don't have them, I've made a post on Easter Acoustic Works bulletin
for some help but they didnt reply and I have had no luck finding them.
Posted By: ceharden
Date Posted: 18 June 2006 at 4:14pm
A lot of EAW drivers are Eminence OEM but that's easy to tell if you
can see the driver and especially the magnet. If they are OEM
versions of the RCF driver then they might be ok in the PWH.
Posted By: mikael h
Date Posted: 02 July 2006 at 12:43pm
>>>Nexus! Do you think eminence omega pro 18 can work in this design?
Date Posted: 02 July 2006 at 12:50pm
yes
Ex Nexus_3
Posted By: mikael h
Date Posted: 02 July 2006 at 1:09pm
Good Thinking on build one for test and then build more if im happy with it
Did you have the design on that dynacord speaker you talk about and witch components from P-audio are the best to use?
Date Posted: 02 July 2006 at 1:47pm
what driver would you want to use
C18-650EL SD-18EL pop into my mind now
Ex Nexus_3
Posted By: mikael h
Date Posted: 02 July 2006 at 3:30pm
my bad. my question wasn't that good I mean for the dynacord speaker. have you some design on the inside of it?
And how is the sound of the sub? can it be used to both hard dance music and also live concert's?
Posted By: Ambrocio
Date Posted: 03 July 2006 at 1:47am
Hey come to know that my 6 EAW are Eminence Magnum Pro 18-LF, I built a
pair of planer wave horn and I must say they really work nice. Im
pushing them with a QSC USA1310 in mono at 4 ohms. Ill post some pice
up tomorrow.
Date Posted: 03 July 2006 at 2:48pm
And how is the sound of the sub? can it be used to both hard dance music and also live concert's? |
I would rather use something different for hard dance music (wih a bit more kick)
for live usage they are great dough
I had the plan for the Dynacord sub somewere here, but it's not verry diiferent
it has a large port venting inside the waveguie
Dynacord is using the EVX 180 A driver (electrovoice)
Ex Nexus_3
Posted By: mikael h
Date Posted: 03 July 2006 at 3:04pm
Okey! Do you think I have to modify the length of the ports if I load them with omega pro 18?
Date Posted: 03 July 2006 at 3:35pm
absolutely no modifications
the Omega pro 18A acts exactly like the Selenium 18SW1P , the only drawback is the considerably smaller X-max
A highpass is absolutely necesarry @ 40Hz
Ex Nexus_3
Posted By: mikael h
Date Posted: 03 July 2006 at 4:02pm
Thank you!
I post some pics if i build one or two
Posted By: basscreator
Date Posted: 10 July 2006 at 1:15pm
will i have to reduce the port length if i use (choice of 3)
a:- Fane 18xb600
b:- PD186
c:- PD184
its just i like the look of the planar sub, and i have these drivers kicking round at home...
Posted By: zALTEC
Date Posted: 18 August 2006 at 5:33pm
Hi Nexus, have you already plotted this sub?
Date Posted: 19 August 2006 at 1:52pm
nope
Ex Nexus_3
Posted By: Tekasis
Date Posted: 20 August 2006 at 5:50am
Hi Nexus 3,
I like the look of your Planar Sub Bas Box.
Can I ask, do you know what it would sound like using a Void V-18 1000w or PD1850 800w driver in there ?
Cheers.
Posted By: zALTEC
Date Posted: 20 August 2006 at 8:16am
Nexus_3 wrote:
nope
What are you waiting?
It would be interesting to see how they perform against a 2x18" 320L-40HZ, a 1x18" 150L-40HZ, and real horn enclosures like Punisher.
Actually i need something to go under my HD215 (30/35-80Hz) and i've not decided yet if go on 2x18" reflex or something horn loaded like WSXtra and Punisher or this hybrid.
Performance/price/weight/dimensions wise.
Outdoor/indoor events, live rock and techno use, max 700-800ppl.
Posted By: Triggerfish
Date Posted: 21 August 2006 at 2:52pm
Hi im lookin for a system to start of with for Playing mainly house/Dirty techno would you recommend this system setup:
4x Planer Wave Horn Subs loaded with PD184's
4x Mid tops loaded with Fane cresendo 15mb's + Eminence ASD comp Drivers
+5kw Amp power
any help would be much appereciated thanks
Posted By: mykey
Date Posted: 22 August 2006 at 2:44am
2 x http://www.janaudio.com/products/detail.php?cat=Fibreglass%20Horns%20and%20Speakers%20Cabinets&id=8&coll_page=1 - http://www.janaudio.com/products/detail.php?cat=Fibreglass%20Horns%20and%20Speakers%20Cabinets&id=8&coll_page=1
Date Posted: 22 August 2006 at 4:27am
good one mykey
Ex Nexus_3
Posted By: Hugo Biermann
Date Posted: 28 August 2006 at 4:00pm
Can you give us al list of recommended
dirivers, in order, if you can Nexus
Posted By: rbuszka
Date Posted: 31 August 2006 at 10:39am
Can this subwoofer be modeled as a sixth-order bandpass with a front chamber volume of zero and a vent as large and long as the planar horn? I plan to test this theory, but if someone could just tell me that it can be done, it would save me a bit of time.
Date Posted: 31 August 2006 at 11:49am
nope, you can't
Ex Nexus_3
Posted By: Heathrow_B_line
Date Posted: 24 November 2006 at 2:20pm
Three-Bee wrote:
Can you give us al list of recommended dirivers, in order, if you can Nexus |
i would also like to see this list!
------------- Produce a killer sound. Take no prisoners.
Date Posted: 30 December 2006 at 9:34pm
Just had a look at PD184 in the vented cab part of this design ( I ran it as a 130 litre vented cab, 400 sq cm vents 490mm long.. ) It looks like it will do the trick aswell... Xmax limit @ full power just below 30 Hz (-9 dB or something, but not really relevant as the horn should give some sort of boost aswell ?)..
Can anyone confirm that the PD184 will survive in this cab without retuning ?
/peter
------------- real phone no: +45 four zero six two four four nine eight ( using obvious anti phone spam encryption )
Posted By: puffah
Date Posted: 31 December 2006 at 3:18am
These look like the EAW cabinates??? is there a large slot in the middle with the port on the baffle???
------------- vicious bass since 1988
