(Crest 9001 or VZ5000) vs. LA 48
Forum Name: Amp Forum
URL: https://forum.speakerplans.com/forum_posts.asp?TID=44013
Printed Date: 27 March 2026 at 5:30am
Topic: (Crest 9001 or VZ5000) vs. LA 48
Posted By: dOpeShack
Subject: (Crest 9001 or VZ5000) vs. LA 48
Date Posted: 12 October 2010 at 12:04pm
 Hello...
What's your opinion to drive subs about (Crest 9001 or VZ5000) vs.  LA 48? (PD.1850 in Scoops in my case?).
I don't want to get in the debate about Crest 9001 vs VZ5000 as it has been discussed extensively already, and each amp has its own fans, but I'd like to hear people's opinion about "chopped amps" (that's how we say in french but not sure it the same in english Confused )
I know some people are against that kind of new generation amps but the LA 48 seems to be a high end amp having some positive points, specially weight and  lower power supply needs. Price-wise its almost the same range, Crest 9001 or VZ5000 are around 1500euros where LA 48 is around 1700euros...
King HiFi - Heavyweight Dancehall System
Posted By: VentureSound
Date Posted: 12 October 2010 at 12:42pm
By LA48, do you mean L-acoustics brand Lab Gruppen FP6400? If so, then i'm sure people would think they're ok on bass, but prefer the heavy models, for the "heavy sound". Also, kinda depends on what music you're playing- stuff with long basslines or kicky Techno type stuff. Long basslines maybe better with the Crown/ Crest. Techno with the Lab.
Also, in UK you can get Crest or Crown for about 1000 Euros easily, but the Lab is more expensive, maybe 1500-1600 Euros.
If you go for the Crown, I have some available for sale at £900!! Big smile
Date Posted: 12 October 2010 at 12:54pm
I think LA48 and FP6400 are the same amps, but im not sure...
It's for dub music!
Posted By: S DeXter
Date Posted: 12 October 2010 at 1:49pm
Never have been that keen on the 6400 on bass.....
Enjoy your self...... It's later than you think.......
Posted By: TRE4U2NV
Date Posted: 12 October 2010 at 1:59pm
dont shoot me but i think they are one of arthurs amps but only seen la 24 version i could be wrong
Posted By: Spesh
Date Posted: 12 October 2010 at 2:22pm
CA18?
Symmetry Soundsystem
Posted By: Louder than loud
Date Posted: 12 October 2010 at 2:44pm
Yes a LA48 is a Lab 64 no difference :)
Lab are very good but your going to perfer the sound of the VZ5000 mainly due to its poor damping and there subby sound ( these things can help tho )
I've owned Lab 64's, CA18's and the like .... if weight is not a problem stick with the heavy ones but if weight is a problem or a big factor then go lightweight buddy :)
Posted By: paulus
Date Posted: 12 October 2010 at 4:38pm
ca 18 also,smoother than the crown and will not trip the breakers on turn on like the 9001 is prone to doing
TRENDSETTER SOUND SYSTEM
Posted By: YoungBlood
Date Posted: 12 October 2010 at 4:51pm
if buyer use amp most on 13A plug/ring main an dub  CA18 an 9001 not as loud
"chyll wynstan.."
Posted By: TRE4U2NV
Date Posted: 12 October 2010 at 6:52pm
sorry my bad i was thinking of these amps  http://www.ac-pro.net/en/productslist.aspx?bid=894&sid=895 - http://www.ac-pro.net/en/productslist.aspx?bid=894&sid=895
Date Posted: 12 October 2010 at 7:52pm
Im sorry to ask guys.. but could you use punctuation and try making your sentences more comprehensive, it is very hard for me to understand what you are trying to say (im not an english-born speaker)Embarrassed
What does "not trip the breaker on turn on" mean?
If i use on 13A plug on dub, the CA18 and 9001 are not as loud as what?
Hope im not asking for too much.. thanks! Smile
Posted By: kedwardsleisure
Date Posted: 12 October 2010 at 8:28pm
Lab are very good but your going to perfer the sound of the VZ5000 mainly due to its poor damping and there subby sound ( these things can help)
You mean an MA5000VZ?
These have very good damping, over 1000??
North Staffordshire
Posted By: The Builder
Date Posted: 12 October 2010 at 9:56pm
+1000000
The mains, "Trip" or similar. Modern version of fuse (sort of).  Current rush is such that it trips the breaker (same as blow the fuse in the old days, sort of)
Don't knowBig smile
It just is.
Date Posted: 13 October 2010 at 8:08am
That's what i thought as well...
Date Posted: 13 October 2010 at 8:10am
Thanks Builder for your explanations, its the first time I hear about this 9001 problem...
SO if it was a fuse i guess you'd just have to change it and turn the amp on again... But what is the solution with the breaker? Is it hard to fix when it trips?
Bless
