Simon's 3 way horn loaded mid top
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=45089
Printed Date: 26 March 2026 at 7:10pm Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: Simon's 3 way horn loaded mid top
Posted By: cracker.a
Subject: Simon's 3 way horn loaded mid top
Date Posted: 08 November 2010 at 2:30pm
Local students love to use HD15 for school dance party's. They lite and portable, with kick bass they say it gives a "party coulour"
to the kind of music they play. With a tight budget It was a right
choice for them when we built with very inexpensive mid tops.
Today they requested a design to replace mid tops on the end of they pole mounth.
HD15 pole mount:
 HD15 with inexpensive mid tops:
I have put a design below together to keep it lightweight and compact as possible.
Expect to deliver outstanding SPL with clean transparent sound, not only in
smaller configurations, possible to used with other
loudspeakers to cover frequencies from 180Hz and up.
Compact arrayable trapezoid cabinet, constant 55º dispersion with three-way horn loaded system is intent to perform better without pushing any element to the limit. Switchable active/passive, with a moderate budget to build.
Following version is intent to use on the top of the HD15's pole mount with two-way active system one amp run's HD15 with active crossover from 50Hz to 180Hz (!) second amp powers the passive mid top's from 180Hz and up.
Note, ideally mid top should play from 120Hz but horn size and over all dimensions would drastically change which would be on expense of transportability. It is great compromise made to let opening frequency from 180Hz on the tops.
I welcoming all intelligent suggestions and ideas to improve this design.
Posted By: soundguymatt
Date Posted: 08 November 2010 at 3:47pm
looks very interesting - have you actually made any?
Matt
Posted By: Centauri
Date Posted: 08 November 2010 at 10:15pm
The biggest change I would look at would be setting the HF horn into the timber flares between lo mid and hi mid - this would get the HF physically closer to the hi mid to reduce lobing and allow a higher crossover frequency, and would also set it back a bit to improve time alignment.
If the hi mid driver was a closed back type, the entire rear chamber could be one, which could allow you to port the rear chamber either side of the HF flare for a little more low end extension - a relatively high lo mid to sub crossover point could limit you regarding positioning of both.
Otherwise, looks good!
Posted By: Ibex
Date Posted: 08 November 2010 at 10:58pm
Great design! Looks a little bit like a mini KF-850... What are the driver sizes? 10" LF & 8" MF?
Date Posted: 09 November 2010 at 8:08pm
soundguymatt wrote:
looks very interesting - have you actually made any? |
I have built and molded similar horns from fiberglass long ago. I have posted pictures on other threads. No, I have not made this particular version.
In my opinion, Fundamentals of the horn design has not changed, the
difference from past to today that better transducers and more driver
selection are available and amplification ratio WATT per Dollar become
more affordable.
alignment.
I like your
idea. Unfortunately this would change the over all dimensions in that
case I would consider different design, please see on the
picture below.
If powerful BL quality neo cone drivers are used along with custom made
phase plugs this 3 way version mid top would be a very competitive
sounding with Martin Audio Wavefront W8C.
This version takes a bit of woodworking skills to build, employs 12" / 8" / 1" drivers and will play from 120Hz !
You right ! After I browsed for EAW KF-850 I find similarity. I was not aware of this, generally EAW products would not be my first choice.
If you decide to build your opinion and feedback would be appreciated.
Size of the drivers should be on the print, design # 1 use 10" Mid Low / 8" Mid / 1" HF design # 2 use 12" / 8"/ 1".
Posted By: darkmatter
Date Posted: 09 November 2010 at 8:48pm
Looks really good. I agree with the comment about getting the HF closer to the 8" horn.
For your application, I'd probably consider two way co-axial options using a 12" on a ported horn and a BMS HF driver to allow a lower crossover.
Posted By: imageoven
Date Posted: 09 November 2010 at 9:41pm
Hi Simon,
Thanks for sharing the design! Nice clear plans too
Do you plan to make the horns from fibreglass or wood?
You show a phase bung in the plans, how far along is it's design?
Posted By: AM55
Date Posted: 09 November 2010 at 10:07pm
What are the recommended drivers? Any plots?
------------- https://diy-disco.co" rel="nofollow - Audio Visual Equipment Hire Service
Posted By: Centauri
Date Posted: 09 November 2010 at 10:23pm
cracker.a wrote:
I like your
What I had in mind for the HF would not change box dimensions - something along the lines of
The top and bottom of the HF flare would be trimmed to suit.
Posted By: Louder than loud
Date Posted: 09 November 2010 at 10:37pm
Date Posted: 10 November 2010 at 8:43am
Anyone care to spec drivers and do some plots for this design - looks like you could be onto something.
Matt
Posted By: cravings
Date Posted: 10 November 2010 at 1:02pm
what bass would you use up to 180?
nice looking plan.
Date Posted: 10 November 2010 at 3:53pm
soundguymatt wrote:
Anyone care to spec drivers and do some plots for this design - looks like you could be onto something. |
Building plans has been released for this community in the hope that will start collaboration between forum members.
I wish my time and resources would not have limits to revisit and entertain continuously this and other designs.
As per the request the 10" /8"/1" version will be build for the school students.
imageoven wrote:
Do you plan to make the horns from fibreglass or wood? You show a phase bung in the plans, how far along is it's design? |
This
is wood horn. Long ago when I made fiberglass horns, I use to reverse a
dust cap on the driver, then pour a gypsum plaster, let it cure and use
it to make a negative mold form to specifically custom make center
phase plug for that driver.
Plan above is for a general horn to cover mid range, can be built from
wood and to benefit most DIY members here instead of posting a building
plan for fiberglass mold plan for very specific driver.
Ibex wrote:
Looks a little bit like a mini KF-850... |
Horn
calculations have not changed formulas remain the same. Because of
given constants most horns meant for general parameter drivers will end
up to be much less similar.
Since horns been used in sound reinforcement it's getting hard to have fresh ideas, most designs are exhausted and we have a feeling some have been repeated.
That's the case on my first post when other member pointed out. it looks like a mini version of the EAW KF 850 !
Remember a complex system that works is
invariably found to have evolved from a simple system that works.
amss wrote:
What are the recommended drivers? Any plots? |
To get the most efficiency and smooth frequency response customized horn need to be designed to each individual specific driver.
Sourcing and selecting a driver can take longer than a design process.
With 10" and 12" we can get to about 2 kHz before it gets too
tricky... Tony Andrews from Funktion One gets 6,5 kHz from a horn-loaded 8", but he use
custom drivers and their R&D is way better than any of us, DIY-s,
can dream about...
Centauri wrote:
What I had in mind for the HF would not change box dimensions | Thank
you for your interest and I appreciate for your time to make up a
sketch. I agree that will improve a bit the sounding to relocate the HF horn. Considering that this cabinet is for long range listening. It's debatable how much will improve?
Unfortunately whenever two wavelengths with different pressures are combined, there will be a discontinuity at the juncture of the two.
This discontinuity will be audible as though it were a separate,
non-coherent source ( like delayed loudspeaker).
In my opinion shifting or incorporating in the mid horn a HF horn is rather done for space saving reason. (Note this theory is not the case in pin-pointed Line Array system)
In respect to the fact that is doable to relocate HF horn where your sketch is showing, make a cut out on two wooden horns into cabinet cross support plate.
I wouldn't mind to hear others opinion how beneficial and practical this would be.
My understanding of your first response was to change the cabinet height to fit HF horn between the mid horns and port the rear chamber either side of the HF flare for a little more low end extension. On picture you missing the ports, right?
Posted By: Centauri
Date Posted: 10 November 2010 at 10:28pm
Yes, I didn't include any ports on the drawing, but these could still be brought out either side of the HF flare if required, and the enclosed volume between the hi mid and lo mid flares could also be included in rear volume.
I usually like to get adjacent band components as physically close to each other as possible no matter what the intended listening distance, although at greater distances the listening position would tend to be more on vertical axis.
Date Posted: 13 November 2010 at 12:31am
As per posted plan, custom built passive crossover.
Posted By: p1go
Date Posted: 13 November 2010 at 10:22am
Very nice project
Can you upload the plan in higher resolution?
Posted By: MarjanM
Date Posted: 13 November 2010 at 10:46am
Inductances has to be rotated 90 degrees in relation to each other to avoid interferences.
------------- Marjan Milosevic MM-Acoustics www.mm-acoustics.com https://www.facebook.com/pages/MM-Acoustics/608901282527713
Posted By: Teunos
Date Posted: 13 November 2010 at 11:05am
MarjanM wrote:
Inductances has to be rotated 90 degrees in relation to each other to avoid interferences. |
+1, interference can cause frequency leaking and possibly make low end coming through your tweeter therefore possibly braking it.
Better to turn one of them to a laying down position, and twist one them by 90 degrees. And while you're at it, make sure the location of the filter in the cab will be as far as possible removed from any metal since this can change the induction of the coil.
BTW, what kind of capacitors did you use? the purple one look like some bi-polar capacitors.
------------- Best regards, Teun.
Posted By: daywalk3r
Date Posted: 13 November 2010 at 4:31pm
Teunos wrote:
the purple one look like some bi-polar capacitors. | As far as I can tell from the looks, it seems all are classic electrolytic bi-polars, except the yellow one on the left
Metallized polypropylene film (MKP) capacitors are best suited for audio use, though they are alot more expensive than those pesky bi-polars .
You could get away with using a bipol on the LF, but I would not recommend doing that on the MF/HF if your aim is max sound quality.
Posted By: Teunos
Date Posted: 13 November 2010 at 8:08pm
Yeah that's why i asked, i also am not very keen on using bipolar capacitors, and prefer MKP but if budget restricts you, you can always go for MKT. As far as i know, especially for PA, there won't be a noticeable difference between MKT and MKP, except for general lower max voltage rating at which point the capacitor brakes down on the MKT.
Date Posted: 14 November 2010 at 2:03am
In my experience, the magnetic field generated by every inductor will induce a voltage in every other inductor
regardless to they position on a similar plane on the x-over board. This adds more non linear distortion, and if the crossover can vibrate,
which it must inside the speaker cabinet, yet more non-linear distortion is added. Hence no loudspeaker with
any pretence at quality should ever house a passive crossover inside the bass chamber of a loudspeaker.
The magnetic field
generated can saturate a ferrite core, causing a loud 'crack' sound on really heavy peaks, and a fizz on
smaller peaks.
Air cored inductors do
not suffer from this, but they need many more turns of wire to achieve the same value, which increases the
DC resistance, and makes the heating problem.
In past 20 years I've been using booth vertical and horizontal installation method on crossover boards and haven't experienced any difference or failures neither on board or driver elements.
Date Posted: 14 November 2010 at 8:39pm
Posted By: Teunos
Date Posted: 15 November 2010 at 10:30am
cracker.a wrote:
Looks good. Have you decided yet where you'll be placing the high-horn and if you will be porting the rear chamber?
Date Posted: 18 November 2010 at 6:04pm
Posted By: rass_droid
Date Posted: 18 November 2010 at 11:16pm
the RCF MR10n301 is good in this mid bass horn??? frequency range from 200/250hz to 1700hz???
Date Posted: 19 November 2010 at 4:28am
rass_droid wrote:
the RCF MR10n301 is good in this mid bass horn???frequency range from 200/250hz to 1700hz???
RCF MR10n301 will make this box play from 200Hz. Intend was to make a box play bit lower from 160Hz. Back chamber is ported to front it would be better not to use closed back type driver for lower horn that employs the 10" driver.
For this configuration would be better way to use a not closed back type 10” driver up to 500 Hz and then an 8” driver from
500 Hz up to 2,5 KHz where the HF would take over. This combination
would give you a better result. You could use a 8 “ driver like the MR8N301 is especially designed for horn-loading and line array configurations.
Every detail of this speaker has been optimized to offer the best response and perfect control to the midrange frequencies.
For a fact it have it's own RCF horn flare H6000 see link's below:
http://%20www.toutlehautparleur.com/pavillons/rcf-h6000-p-2804.html -
http://www.toutlehautparleur.com/pavillons/rcf-h6000-p-2804.html
http://%20cgi.ebay.co.uk/RCF-H6000-Phase-Plug-/130453914527 - - http://cgi.ebay.co.uk/RCF-H6000-Phase-Plug-/130453914527
Date Posted: 19 November 2010 at 5:03pm
I would like to use your mid bass horn for my midtop plan
the project consists of: rcf lf15n401 from 60/80 to 200 250 rcf mr10n301 from 200/250hz to 1700/2000hz rcf driver 1,4 nd3020 up to 1700/2000 could you send the sim hr??
Date Posted: 19 November 2010 at 9:03pm
To calculate the theoretical horn response for your own specific driver please download following free program from link below.
http://www.hornresp.net.ms/ - - http://www.hornresp.net.ms/
Posted By: JD01
Date Posted: 22 November 2010 at 1:55am
Again, I wouldn't even consider porting the lowmid section. Has anyone of you taken a look on a CSD of a ported cab tuned to 100Hz or higher? It's just mud getting out of the ports, loosely related to the original signal. If you care about sound quality you'll stay off those ideas.
Also, your design, where the HF horn was mounted in the lowmid section as far to the top of it as possible was just fine. I don't think the hassle of bringing it even nearer to the center of the MF horn is worth the effort.
If budget was higher I would recommend the RCF MR8N301 for the MF horn. The back is sealed, you don't need to construct a sealed volume. Maybe that even offsets the higher price for you. The soundquality is worth the price IMO.
Date Posted: 22 November 2010 at 2:20pm
I agree somewhat with your comment. However size is matter....
How big does a horn have to be? What happens if a horn isn’t big
enough? Is there any way to compensate for a horn not being big enough?
Horn cabinet has to be big enough and long enough to
support the lowest frequency you require. It’s the horn’s length that
determines its cut-off, or how low it can reproduce.
In this design a 10" low mid horn tuned with 200Hz cut off, further a phase plug it occupies space in front of a driver in front chamber has the same effect as a low-pass filter, so keeping the front
chamber as close to zero as possible reduces the low-pass effect and
allows the driver/horn combination to have better high-frequency
performance.
If a horn is not long enough to support the frequency you are
reproducing, theoretically no power will be transmitted down it, as a
horn’s impedance is entirely reactive below its cutoff. In reality some
sound will still be produced by the driver below the cut-off, but with
no assistance from the horn, utilize a rear chamber and port it to the front will recover part of the cut off frequencies and cabinet have a response frequency below 200Hz. Level of sound quality and port noise can be argued...
Using loudspeaker design software
is definitely the way to go to get maximum gain with minimum pain.
However, it is important to resist the temptation to believe that the
figures they produce are the entire truth, this is where past experience have to step in....
Date Posted: 23 November 2010 at 11:48pm
Customized phase plug:
Testing a close fit concave part of the phase plug to dust cap and cone diaphragm.
Posted By: p1go
Date Posted: 24 November 2010 at 1:03am
Nice
Posted By: Quantum Sounds
Date Posted: 24 November 2010 at 7:48pm
good project keep us updated
Date Posted: 27 November 2010 at 7:46pm
Thank you all for the complements. The idea of the phase plug on this project is to equalize the path lengths from the diaphragm to the throat exit.
Posted By: mikey bear
Date Posted: 27 November 2010 at 8:12pm
how efficient are the 10" and 8" horns with your drivers?
Date Posted: 28 November 2010 at 1:42am
10" and 8" paper cone drivers have a smaller voice
coils and will take full advantage of the flux in the pole piece gap.
In my opinion on this design will increase
the efficiency of the transducers allowing the amplifier to work with greater
ease. Since the amplifier has more headroom and the driver handles peaks and
high outputs more efficiently, horns are able to produce much higher SPL's
before they distort.
In the normal operating range, this horns will be faster,
more dynamic, have a better transient response, have less distortion, and are
easier for an amplifier to drive than 12" mid bass driver designs.
Since the 10" and 8" diaphragm is
smaller, it is lighter and thus it accelerates and decelerates faster. This, in
the real world means superb, fast snappy transients. As the excursion of the
diaphragm is very small as compared to most 12" mid bass transducers, the
voice coil is much smaller and again, this translates to a lower moving mass results in fast transients and increases
the efficiency.
Paper cone mid-range diaphragms and comp drivers have special characteristics, I prefer a smoother sounding paper cones over the mid range compression drivers.
Paper is a material that sounds better than it measures ... this is an genuine asset, not a disadvantage.
It can be used with low slope linear-phase crossovers without much trouble, potentially excellent resolution and detail, very flat response potential.
Posted By: atisimi
Date Posted: 08 December 2010 at 3:11pm
Did you take a photo on booth driver's phase plug?
Date Posted: 12 December 2010 at 3:08am
Date Posted: 02 January 2011 at 4:58pm
Because of the phase plugs I'm expecting much higher SPL measurements at
high end than simulated curves below.
8" horn with Eminence ALPHA 8MRA Note: Volume throat chamber, calculated with 90mm X 60mm Dia. (27.9 cm2) phase plug / phase bung.
10" horn with Eminence ALPHA 10A Note: Volume throat chamber, calculated with 120mm X 95mm Dia. (70.8 cm2) phase plug /phase bung. Sealed chamber is reduced to 4.5 liter and oposite to the drawing no ports from rear chamber to the front.
Posted By: Teunos
Date Posted: 02 January 2011 at 7:18pm
That's pretty low for a 10'' speaker horn loaded. Could you post the hornresp input screens for these sims? or is this the ported version?
Date Posted: 03 January 2011 at 2:48am
Post have been updated as per "Tuenos" request.
Posted By: Teunos
Date Posted: 03 January 2011 at 2:07pm
I would have sworn there was a different frequency response on here for the 10'' before input was posted. I see this is the non-ported version, was the other one the ported?
Oh, and in your sim for the 10'' you have L12 Conical and L23 exponential. Judging from your drawing this should be the other way around.
Date Posted: 03 January 2011 at 2:27pm
"Tuenos" you are correct, there was a different frequency response in prior post that I have replaced and indicated that post have been edited.
I was the ported horn version, after I revisited the input data, I believe with wrong input parameters.
I'm appreciated for your comment.
10" horn is relatively short and your suggestion I have simulated makes no difference on SPL response.
Date Posted: 20 April 2011 at 10:40am
Posted By: piers1
Date Posted: 21 April 2011 at 4:14am
rass_droid wrote:
any update??? |
Date Posted: 21 April 2011 at 9:40am
really looking forward to seeing a plot of these boxes once finished, looking fab so far tho.
Matt
Posted By: t.geessounds
Date Posted: 21 April 2011 at 3:03pm
god those cab look so nice
Posted By: doober
Date Posted: 21 April 2011 at 10:10pm
Good stuff
------------- Blahblahblah
Posted By: cravings
Date Posted: 21 April 2011 at 11:23pm
Posted By: djeddie
Date Posted: 21 April 2011 at 11:29pm
Ditto!
------------- Chas n Dave : it's like Drum and Bass but with beards. E=mc² ±3dB
Posted By: DeJaVoo
Date Posted: 21 April 2011 at 11:46pm
not sure on the colour but the look amazing
------------- I want doesn't get..... why not!? :(
Posted By: beggamon speaker
Date Posted: 22 April 2011 at 7:59am
it is possible to see the images of previous pages. because it does not do more than visualize. congratulations on the box
Posted By: Centauri
Date Posted: 22 April 2011 at 8:19am
Seems strange that even the modified image I posted has been removed from Photobucket, so I can only assume the original poster (who has not posted since January) has had them removed for some reason. Pity, as it would have shown the design changes from initial proposition to completed box.
Result does look good, and it would be good to see measurements and/or subjective feedback. Who is piers1 ? - cracker.a reincarnated perhaps ?
Posted By: bitSmasher
Date Posted: 02 August 2012 at 6:45am
A year later... wondering what came of this cab and design? It's a shame the images are no longer viewable, I'm curious as to the mid horn based on an 8MRA...
Posted By: Keen
Date Posted: 04 August 2012 at 9:18am
check out TDA Audio's photo file mid top section for some untested measurments (bottom row).
http://translate.googleusercontent.com/translate_c?hl=en&prev=/search%3Fq%3Dtda%2Baudio%26hl%3Den%26client%3Dfirefox-a%26hs%3DKla%26rls%3Dorg.mozilla:en-US:official%26prmd%3Dimvns&rurl=translate.google.com.au&sl=ru&twu=1&u=http://photo.qip.ru/users/tda-audio/183265/%3Fpage%3D3&usg=ALkJrhg_vnzwQMIUcZNEGV9gkDsBR50vfg
Posted By: piers1
Date Posted: 01 November 2012 at 2:16am
Posted By: mykey-
Date Posted: 01 November 2012 at 2:44am
They almost look edible.
Only thing I would say is the perforated grill isn't transparent enough
------------- BbbBBRAAAAPppBBBBbgushhhhhhhhssshhhhhGrAbRAAAAAAPPPPPp = Dubstep
Date Posted: 01 November 2012 at 6:01am
Posted By: Teunos
Date Posted: 01 November 2012 at 8:02am
Is that a horn with screw on threat? which make/model?
Posted By: piers1
Date Posted: 01 November 2012 at 12:40pm
Teunos wrote:
Is that a horn with screw on threat? which make/model? |
Goldwood GT-300PB http://www.goldwoodsound.com/MidHorns.html" rel="nofollow - http://www.goldwoodsound.com/MidHorns.html
Posted By: T-Bone
Date Posted: 01 November 2012 at 1:04pm
These are beautiful cabinets would like to see someone here do one with the phase plugs used on the Funktion-One cabinets, not attached to the driver of course. Do you have posted frequency response with the Eminence drivers that were used? I also would like to build these active but maybe use the new Eminence Kappalite 3010 MB or LF. I believe Eminence has the MB ready to ship from the factory speaking to a sales guy last week. WICKED!!!
------------- BASS, how low can you go!
Posted By: Timebomb
Date Posted: 01 November 2012 at 4:55pm
They look fantastic
------------- James Secker facebook.com/soundgearuk James@soundgear.co.uk www.soundgear.co.uk
Posted By: graftak
Date Posted: 03 November 2012 at 11:29am
any chance you've got any plots for these? the look fantastic, bet they sound great..whats the crossover points? how about the efeciency?
Cheers, Graftak
Posted By: snape6666
Date Posted: 19 March 2015 at 6:46pm
What chassis do you use and do you have some measurements?
Is there a more detailed plan with some dimensions? I really would like to build 2 of these =)
Date Posted: 21 March 2015 at 7:44pm
It's a shame the plots have disappeared, was just looking into this along side the DMT designs :/
Matt
Posted By: kr1sounds
Date Posted: 21 March 2015 at 8:48pm
this is one of them, i'll try to find the other
------------- I MAN SERVE SELASSIE CONTINUALLY... NO MATTER WHAT THE WEAK HEART SAY
fostonshfs.webs.com
Date Posted: 22 March 2015 at 1:02pm
sad its not easy to read this :D do you have them in better quality? I would be grateful! Thx =)
Date Posted: 22 March 2015 at 9:48pm
pm me your email and ill send them tomorrow
fostonshfs.webs.com
Date Posted: 24 March 2015 at 11:19am
stupid question but iam new here :D how can send you a message? I didnt found a PM button on your profil...
Posted By: nativelayer
Date Posted: 24 March 2015 at 1:39pm
You need a minimum of 10 points to make and recieve PM's
------------- There is no authority but yourself.
Posted By: piers1
Date Posted: 29 March 2015 at 3:09pm
snape6666 wrote:
sad its not easy to read this :D do you have them in better quality? I would be grateful! Thx =) | The final version I have build back in 2010. The way to get started is to quit talking and begin doing... Years ago, I find most members here are talkers, but here are the plans again, for those who are doers... Build it without ports from 10" to the front, close both, the 10" and 8" rear chambers. Horns proven to work with any drivers have following general TS parameters: - FS(Resonant Frequency) 50HZ and above
- EBP(efficiency bandwidth product) High EBP, 150 and above [FS/Qes = EBP]
- Qts (Driver Q) 0.28 and lower
- BL(Driver Motor Strength) 25TM [tesla meters] and above
- Le (inductance value of the coil) 1.2mH and lower
Download from here the better quality plan in PDF: uploads/9799/Simon_3_way_Mid_Top_Rev02.pdf" rel="nofollow - uploads/9799/Simon_3_way_Mid_Top_Rev02.pdf
Date Posted: 29 March 2015 at 3:29pm
^^ 12 & 8 inch
^^ 10 & 8 inch
fostonshfs.webs.com
Posted By: piers1
Date Posted: 29 March 2015 at 6:57pm
Note, those posted drawings by "kr1sounds" was my conceptual plans, has never got built. I ended up with the one I posted above.
Date Posted: 29 March 2015 at 7:10pm
how do they sound?
fostonshfs.webs.com
Posted By: piers1
Date Posted: 31 March 2015 at 9:20pm
kr1sounds wrote:
how do they sound? |
Terrible bad.
Posted By: Thomas Hosker
Date Posted: 31 March 2015 at 9:58pm
This thread is confusing!
Is there any measurements for this box yet? Looks great!
Is it reaching the 120hz lower target you set? And this is a 10"?
------------- WWW.T8Audio.Com
Date Posted: 31 March 2015 at 10:38pm
uploads/18250/Simon_3_way_Mid_Top_Rev02.pdf" rel="nofollow - uploads/18250/Simon_3_way_Mid_Top_Rev02.pdf - thats the final plan there
fostonshfs.webs.com
Date Posted: 01 April 2015 at 10:53am
Yes meassurements would be interessting!
piers1 are you kidding?^^ Or are they really not good?^^
Date Posted: 01 April 2015 at 5:10pm
piers1 what drivers did you use for the 10" version?
Would be thankful if you tell me your setup =)
Posted By: piers1
Date Posted: 02 April 2015 at 5:29am
piers1 are you kidding?^^ Or are they really not good?^^ |
They sound terrible... according to my wife :-)
Look, I have given a fish, and this forum has other members that can teach you how to fish.
In reality here is how it works: Teach a man to
fish, and he will sit in the boat and drink beer all day...
Posted By: Gingerbuilder
Date Posted: 17 February 2024 at 8:29am
Hi is there a higher quality image available for the 12”version please.
