15'' 1850s plans?
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=46007
Printed Date: 26 March 2026 at 8:16pm
Topic: 15'' 1850s plans?
Posted By: korsager
Subject: 15'' 1850s plans?
Date Posted: 04 December 2010 at 5:02am
Does anyone have the plans for the 1850s horns with a 15'' bass?
Posted By: luke_0301
Date Posted: 04 December 2010 at 7:09am
think it been done before,but doesnt work that well
more bass please
Posted By: Ohmen Sounds
Date Posted: 04 December 2010 at 11:44am
you are better offf just building the 1850 the way it should be, theyre worth the time, i dont really see other reason for wanting a 15" version other than needing a smaller cab, if that what your looking for you might aswell go for a different more compact design.
PENG PENG WOOSH WOOSH
Posted By: djyves
Date Posted: 04 December 2010 at 11:51am
I once saw a sp member that made the 1850 plan suitable for a 15'' driver.
His name was Swesound then, I thought he changed it to Lhudjager.
Posted By: Dref
Date Posted: 04 December 2010 at 12:07pm
The PD1550 simulates almost identical to the PD1850 in the 1850 horn.
If you take the difference Re into account it is hard to tell the diffrence in the responseplot in Honresp (not exactly the right way to do i know, but interesting).
Black is 1550 at 3.0V and gray is 1850 at 2.83V. If the 1550 is given 2.83V it will be a little bit lower than the 1850.
4 x PD1550 in 1850 horns with 600watt each should give you 140db from 46hz and up.
The PD1850 would of course be better because it has higher power rating, lower power compression, more surface area and higher Xmax. And would therefore play louder and have a little bit more low end extension.
Date Posted: 04 December 2010 at 4:07pm
im sure after 'swesound' tested it,he said it didnt work well
more bass please
Posted By: Dref
Date Posted: 04 December 2010 at 7:40pm
The best idea would be to design a horn for the specific 15".
If a horn is scaled down it will result in less performance. (Lower sensitivity, less low-end and probably a more peaky response.)
Posted By: hmaudio
Date Posted: 05 December 2010 at 12:54am
Posted By: djyves
Date Posted: 05 December 2010 at 9:07am
He made it for the eminence kappa lf.
It was the best simming driver in that cab.
Posted By: LjudLahger
Date Posted: 22 January 2011 at 12:12am
They still play nice!
http://www.youtube.com/watch?v=1qAOfIJbGXE&hd=1 - http://www.youtube.com/watch?v=1qAOfIJbGXE&hd=1
Posted By: rich_gale
Date Posted: 22 January 2011 at 7:03am
id sooner build some sl36 clones scaled for 15" drivers.  more direct horn path.  18" version has similar size and performance to 1850 horn. once scaled to 15" you open up more kick horn opportunities in sl36 style cab when you realise that the 15" version doesnt drop as low as you'd hoped.
Posted By: Big-G
Date Posted: 22 January 2011 at 10:43am
Agreed, to my ears the sl36 was a better sounding cab anyway, it dropped lower and went higher without sounding honky.
They know what is what but they don't know what is what they just strut what the .
Posted By: Matejic
Date Posted: 18 March 2011 at 6:02pm
I want to built swesound cab and is it better to use RCF MB15N401 or PD1550 driver?
tnx anyway
Posted By: biotec
Date Posted: 18 March 2011 at 6:06pm
tnx anyway
The 1550 without a doubt.
Th mb15n401 is not a proper bass driver.
Date Posted: 08 July 2011 at 6:16pm
tnx anyway
Even if 1550 driver is a fine one, this does not fit this "1550 horn" as good as Eminence Kappa 15LF. No one does. I have done sims on alot of highend drivers and no one give a nice curve like kappa15LF does....good lowend (50Hz) and punch in the 110-140Hz aria...
You could go with the Kappa pro and you get more X-max and X-mech but lose 1-2dB in sensitivity.
I like PD but not in this one...(from my hornresp sims;)
Posted By: smoore
Date Posted: 21 July 2011 at 5:39pm
http://www.speakerstore.nl/constructions/show/10
 - What im in the process of building. Going to use kappa lf's in it too. Its only my 3rd cab build so not sure how it'l turn out, will post pics later
Date Posted: 13 May 2013 at 11:19pm
I have now tryed a driver with a higher bl of 22 and it sounded more "hifi", control and more below 60hz. It's a shame that they are so hard to build :-(
Posted By: JR.junior
Date Posted: 14 May 2013 at 7:06am
build scoop, much more output power.
Posted By: ovidias
Date Posted: 28 July 2014 at 7:33am
can anyone post input data for Horn resp?
Posted By: Keen
Date Posted: 28 July 2014 at 8:28am
Approx (close enough) input data for plan on page 1.
2PI
S1:300
S2:3200
L12:150 (exp)
VRC:33
LRC:21
VTC:5000
ATC:200
Leave everything else as is, and put your driver info in.
Date Posted: 28 July 2014 at 8:38am
S1-453
S2-717
Con-35,4
S3-1220
Con-52,5
S4-1917,3
Con-22,8
S5-3187
Con-18,8
VRC-33
LRC-21
VTC-14000
ATC-1550
Posted By: Keen
Date Posted: 28 July 2014 at 8:54am
or yeah, see LjudLahger's data for simulations starting from the first fold. Personally I dont think that's as accurate (no offense intended LL). One thing with that data is ATC needs to be recalculated because the if you're taking the throat to be everthing up to the first fold then horn resp will calculate the orientation of the throat to be at right angles to the driver. won't make a difference to the response but.
e: spell
Posted By: DennisTheMeerkat
Date Posted: 23 September 2022 at 8:24pm
I know this is a old post, but I just wanted to add to the records that I have done this. I have downscaled the 1850 horns (I have the modified plans aswell if they are wanted) to 15 inch versions. I have built 2 cabinets, and got them loaded with Eminence Kappa Pro 15LFA drivers. They play surprisingly deep, and with these drivers they can play much deeper than they are specified for without any problems, aswell as handle some serious abuse. Indoors I have no problems playing them down to 30 ish hertz, and they sound great. I have 4 ordinary old bass reflex 15 inch cabinets, and the 1850 horns completely dominate in comparison to those. Outdoors, I find that they start dropping off around 40hz. But they get very loud, and sound really nice. Outdoors you don't have any use for anything below 40-50 ish hertz anyways, you won't be able to hear it or feel it really anyways. I have my crossover point around 100hz, and my high pass around 25, with a 12db/oct slope. They sound really good, so downscaling them works just fine. I had to do some slight modifications to the pressure chambers to allow fitment of these rather big drivers, but it was worth it. With these monsters in them, they perform absolutely incredible. I have never had any problems with these drivers bottoming out or running into overexcursion. very good suspension on these, makes a huge difference. There is also 18 inch versions of these drivers available, for those of you who want to build the fullsize. Big smileWinkSmile
Posted By: cas123456
Date Posted: 09 September 2025 at 12:48pm
Cool! Could you maybe share those plans @Dennis?
Date Posted: 26 September 2025 at 7:13pm
I believe I still have them plans somewhere! I’ll have to try to dig them out! I think I know where they are! Very fun to hear that you want to build some too! I’m excited to see what you’ll think of yours!
