B&C 18PS76 in 1850 vs Low Rider 18 in 186 Horn
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=46831
Printed Date: 27 March 2026 at 8:45am
Topic: B&C 18PS76 in 1850 vs Low Rider 18 in 186 Horn
Posted By: iceman1575
Subject: B&C 18PS76 in 1850 vs Low Rider 18 in 186 Horn
Date Posted: 31 December 2010 at 9:09pm
Which would be a better choice?  Both will be on the same amount of power, 2400 watts (set correctly for no clipping, overpowering signals, etc) per pair, mainly for mainstream hiphop/pop, but techno/rock/country/electro, a little bit of everything played.  I will be making 4 total.  Thanks
Ice Cold Entertainment Pro Sound Services - Ashland, KY
Presonus Studiolive 24.4.2 : Electro-Voice LiveX Powered Rig
FOH: 2x115P, 2x118P - Monitor: 4x112P
Posted By: king david
Date Posted: 06 January 2011 at 9:59am
i just installed 18ps76 in reflex cabinets, and in my opinion 2400w for 2 of them is way too much
Date Posted: 07 January 2011 at 5:01am
Hm.  Have you used the Peavey's?  And how would they compare?
Date Posted: 07 January 2011 at 9:34am
no, sorry, no experience with those
Posted By: RealitySound
Date Posted: 04 May 2012 at 2:01am
Anybody tried a lowrider in a 186 horn yet? Or do I have to be the first?
  • Impedance: 8 Ohms
  • - Power Capacity: 3200 Peak 1600 W Program 800 W Continuous
  • - Sensitivity: 93.7 dB / 1 W 1 m
  • - Usable Freq. Range: 25 Hz ~ 1 kHz
  • - Cone: Kevlar® impregnated cellulose
  • - Voice Coil Diameter: 4.0"/ 100 mm
  • - Voice Coil Material: Polyimide coated copper ribbon wire Polyimide-impregnated fiberglass former Nomex® stiffener Solderless diffusion welded OFHC copper leads
  • - Net weight: 22 lbs./ 10 kg
  • - Znom (ohms): 8
  • - Revc (ohms): 6.21
  • - Sd (Square Meters): 0.134
  • - BL (T/M): 22.17
  • - Fo (Hz): 28.9
  • - Vas (liters): 288.0
  • - Cms (uM/N): 113.3
  • - Mms (gm): 198.20
  • - Qms: 9.07
  • - Qes: 0.451
  • - Qts: 0.429
  • - Xmax (mm): 9.6
  • - Le (mH): 0.87
  • - SPL (1W 1m): 96.0
  • - No (%): 2.65%
  • - Vd (cu. in. /ml): 145/2375
  • - Pmax (Watts pgm.): 1600
  • - Disp (cu.in./ml): 235/3852
  • - 18"
They successfully built a folded horn for the lowrider, so how different could the cabs be? Peavey claims it goes down to 30hz.
http://peavey.com/news/article.cfm/action/view/id/266/20072807.cfm
When you gonna send me some $$ mate ?
