LabHorn build pics
Category: Plans
Forum Name: Other plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=48448
Printed Date: 27 March 2026 at 8:37am
Topic: LabHorn build pics
Posted By: tekoffensive
Subject: LabHorn build pics
Date Posted: 09 February 2011 at 7:48pm
difficult build but worth it, started a pair last week
this one was a pain in the arse so ended up using mdf
tested them for the first time today and we couldnt be more chuffed with them, thanks to anyone thats been answering our questions for the last two weeks.
don't quote me on that...
Posted By: Spesh
Date Posted: 09 February 2011 at 8:31pm
I'm not surprised you like them. I love mine. Get some USB's above them and jobs a goodun.
Symmetry Soundsystem
Date Posted: 10 February 2011 at 11:14am
we have 4 hd215s and a pair of turbo floods on top, we already built the hds so making usbs isnt really an option now as we want more labs! the hds sit perfectly on top tho, same width and sound perfect to my ears.
using them properly tomorrow and cant wait, weve only had them about half volume so far and cant believe how they sounded
Posted By: Spesh
Date Posted: 10 February 2011 at 11:54pm
Fairplay.
Date Posted: 11 February 2011 at 11:16am
what do yuo run yours with and what freq do you play thru them? you meantioned something about not putting much more than the rms in them?
were planning to run one off each side of a matrix xp5000 playin 35hz with a long slope up to 80hz not sure how much power theyll be getting but am gonna be careful with the levels and limit them just in case
Posted By: mattd
Date Posted: 18 July 2011 at 8:35pm
We used our for the first time this weekend gave them around 1200w with a crossover of 35HZ LR24 Db slope. Sounded good like this started out with a 48Db slope but was advised warmth of the sound was far better with the LR 24 which it was. Think i'm generally going to cross them at 37HZ just so im not paranoid we were running them off a proline 2700 which had good results considering how cheap the amp is..
Posted By: tomschute
Date Posted: 19 July 2011 at 8:06pm
nice work - great build.
Don't want to be a fly in the ointment but might be worth asking some other Lab users what they HP at. I'd have thought 30Hz should be fine - the driver will already be at full excursion in the mid 30s and you might even benefit from increased cooling from extra cone movement... HP at 35 or 37 you will already be few dB under that at that point.... might as well run cab half the size.
As you only have 2 I could be wrong...
www.stableaudio.co.uk
Speaker Building Services
Posted By: geritass
Date Posted: 07 February 2016 at 3:57am
Hi my friend, do you have labhorn plans? may you share ? what speaker inside?
thanks
Posted By: sn95
Date Posted: 07 February 2016 at 1:06pm
http://www.prosoundweb.com/article/lsp_documentation_page_drawings_photos_specs_and_more/. Thecspeaker is a lab 12 by Eminence speakers.
Posted By: geritass
Date Posted: 07 February 2016 at 6:14pm
Wow so fast reply  sn95, thanks a lot!.
thanks, thanks, thanks....
Geritass.
Clap
Posted By: geritass
Date Posted: 07 February 2016 at 6:24pm
Hi, sn95.
May I use the Eminence LAB12C ?
 is it ok?
thanks,
Posted By: geritass
Date Posted: 07 February 2016 at 6:25pm
Hi, sn95.
May I use te LAB12C,
thanks.
Posted By: all bass
Date Posted: 07 February 2016 at 8:13pm
The Lab 12C is a 4 Ohm driver, 2X parallel might be a tough load for your amps.
Posted By: geritass
Date Posted: 07 February 2016 at 9:53pm
Thanks,  all bass for your help.
Ok, I understand.
Hi everybody:
Is the LABHORN the best subwoofer about fidelity, sensibility and low frecuencie term.
or
Which one will be the Champion one?.... Martin audio WSX, Bill Fitmaurice Tuba60,  Nexo CD18 , etc
Please comment so I need a subwoofer system for a concert event.
thanks
Posted By: sn95
No Lab12 not the C
Posted By: sn95
Date Posted: 07 February 2016 at 10:04pm
How big of a a kit are you going to run? T60,s are BIG and Lab,s need 4 or 6 to work
Posted By: geritass
Date Posted: 07 February 2016 at 10:14pm
I need to cover 100' X 150' (wideX large) area,  10,000 peoples
Big smile
Posted By: sn95
Date Posted: 07 February 2016 at 11:54pm
WSX or some big FLH
Posted By: geritass
Date Posted: 08 February 2016 at 4:34am
Ok, is it the Void acoustic V18-1000 the best driver for the WSX cabinet? alternative one is the RCF  L18p300 driver .  are there additional options drivers for that cabinet.
thanks again Mr. sn95
Thumbs Up
Posted By: MarjanM
Date Posted: 08 February 2016 at 8:05am
Where are you located?
Posted By: geritass
Date Posted: 08 February 2016 at 5:12pm
Hi, MarjanM.
I'm in the United States.
Posted By: sn95
Date Posted: 08 February 2016 at 8:33pm
100 × 150 yrs?
Posted By: geritass
Date Posted: 08 February 2016 at 9:16pm
No, 100X150 feet.
Smile
Posted By: all bass
Date Posted: 08 February 2016 at 9:55pm
WSX, with drivers available in the US.
I don't think the Void V1000 is sold over there.
Posted By: geritass
Date Posted: 08 February 2016 at 10:02pm
that s correct. May be rcf 181P300 or 18 sound NLW9601 or ......?
Hi everybody
Posted By: geritass
Date Posted: 10 February 2016 at 7:51am
May you please help me about choose the best driver for the WSX?
txs
Hi everybody
Posted By: corell
Date Posted: 10 February 2016 at 8:12am
Im sure the 18nlw9601 would be a killer, but i did not heard one yet.
18nw100 is great choice aswell, as is the faital 18hp1022.
