EMU0202 USB soundcard works somtimes, anyone help?
Category: Other Chat
Forum Name: Computer Talk
Forum Description: Help and discussion about your manly PC or girly Mac
URL: https://forum.speakerplans.com/forum_posts.asp?TID=50557
Printed Date: 27 March 2026 at 9:29am Software Version: Web Wiz Forums 12.08 - https://www.webwizforums.com
Topic: EMU0202 USB soundcard works somtimes, anyone help?
Posted By: Timebomb
Subject: EMU0202 USB soundcard works somtimes, anyone help?
Date Posted: 01 April 2011 at 9:58pm
Hi,
Been haveing this problem with my EMU 0202 USB soundcard since i got my new laptop with windows 7, somtimes it boots up and works, somtimes it boots up and says USB device not recognised, sometimes it boots up and recognises the soundcard but you get no audio, somtimes unplugging and plugging it back in gets it going again. If that dosent work then shutting down the PC and unplugging the usb cable, then booting up and plugging in the usb cable once windows 7 has booted normallys gets it going.
it somtimes works fine then stops in the middle of playing audio, and i have to go through the unplug reset etc...
the drivers im using are beta drivers from the emu website, which i suspect is the problem, i was just wondering if anyones got any other ideas as to what it might be?
The soundcard works fine on windows XP BTW
Many thanks.
James
------------- James Secker facebook.com/soundgearuk James@soundgear.co.uk www.soundgear.co.uk
Posted By: Tony Wilkes
Date Posted: 02 April 2011 at 8:37pm
I suspect that it is just windows peeing around with the USB interface, when you plug it in and it does not work have you looked in the Device Manager to see if it recognised?
The 0202 is an old interface and probably will not get the future support it needs. I went Focusrite USB instead and so far has worked faultlessly on XP and Win 7.
USB really is a bit of a wanky interface.
Tony
------------- www.forteaudio.eu - BMS - db-Mark Processors - Lexon (SAE)
Posted By: The Builder
Date Posted: 02 April 2011 at 11:08pm
50% chance this is a power issue. Not enough USB power.
Does the card have the facility for a power supply?
Try it in a Win 7 PC, not laptop.
------------- It just is.
Posted By: Timebomb
Date Posted: 03 April 2011 at 12:40am
Cheers for the replys, When the sound just dosent work it still says its there and working in device manager , if it dosent appear on boot up it says usb device not found in the task bar icon and device manager.
I thought it might be a power issue, i could try it thought a powerd usb hub, ive been meaning to buy one anyway.
Ive tryed the vista drivers and its behaveing exactly the same as with the windows 7 drivers.
Thanks.
James
Posted By: minaximal
Date Posted: 03 April 2011 at 9:23pm
i had an 0404 which never missed a beat using vista drivers in win7 32bit, i thought the 0202 could use usb power but anoyingly the 0404 dragged a bit too much juice from usb so had to be externally powered, i'm assuming your pc is generally running ok and you downloaded the right drivers? i found gearslutz.com a good forum for soundcard discussions.
------------- Subs + Barges = :)
http://www.metaacoustics.com" rel="nofollow - www.metaacoustics.com
Posted By: Timebomb
Date Posted: 04 April 2011 at 12:24am
The 0202 is usb powered, theres no 9V input or anything, im using the beta windows 7 drivers, i tryed the vista drivers but had the same problems, seems like it could be a power issue so i think ill get a powerd usb hub. The laptop is a cheepo acer emachines but everything elce seems to be fine, i might try a windows XP install but theres no graphics drivers or wireless drivers for XP so i might have problems with that. ill try gearslutz, i think there was an emu forum ill try on there too.
Thanks.
james
Date Posted: 04 April 2011 at 9:44am
I'm going with power.
Date Posted: 04 April 2011 at 10:03am
I have a new LMS that I am evaluating, on XP I plug it in it finds the drivers and works, Win 7 50/50 when it does not find the device only a full reboot will get it back to again 50/50. This requires no power so just a driver, timing issue.
Tony
Date Posted: 04 April 2011 at 9:24pm
Not had than in any 7 install yet (lots)
Makes sense though.
Posted By: Timebomb
Date Posted: 05 April 2011 at 12:38am
Think it is a power issue, its been working the last 2 days as ive left the power plugged in, i had been unplugging it at night as it makes a clicking like its de fragging the hard drive when its shut down.
Fingers crossed its ok now.
Thanks for your help guys!
Posted By: Timebomb
Date Posted: 05 April 2011 at 3:58pm
Spoke too soon, booted up today "usb device not recognised" , power was still plugged in.
Posted By: greeef
Date Posted: 06 April 2011 at 2:06am
is it on a front port or a rear one? have you tried different usb sockets?
It's a long shot, but it could be worth installing the drivers as an administrator in XP compatibility mode, and also to turn off onboard sound in the bios.
Date Posted: 06 April 2011 at 8:41am
Presumed the compatibilty mode already.
Onboard sound a good idea
Posted By: Timebomb
Date Posted: 14 April 2011 at 12:03am
Kinda lost patience with this so sorry for not replying, yep i tryed different USB sockets, different things plugged in/not plugged in. I cant disable onboard sound in the bios but i have disabled it in windows.
Ill look into XP compatibility mode, should i try XP drivers? Or windows 7 drivers?
Thanks.
James
