Amplifier Remote Controller?
Forum Name: 12v Powered Systems
Forum Description: From Mini-rigs to ICE, all your low voltage audio needs here...
URL: https://forum.speakerplans.com/forum_posts.asp?TID=51613
Printed Date: 26 March 2026 at 6:55pm
Topic: Amplifier Remote Controller?
Posted By: mobiele eenheid
Subject: Amplifier Remote Controller?
Date Posted: 28 April 2011 at 11:26pm
I'm making a 12V rig for use on 30 april (Queensday over here). I've got 2 car amplfiers that both don't work after connection to the battery. My assumption is that it's because the remote control isn't connected (a single wire, so 3 connections total + / - / remote) , is that so? And if that's so, can I just connect it to the main power (+) or (-) to make it work?
Best regards Johan
Posted By: audiomik
Date Posted: 28 April 2011 at 11:32pm
Johan
saw something about this in another thread on here in the 12V Forum - think you need to connect the 'sense' wire to B+ which simulates a switched line from say a CD player on/off switch when installed in a vehicle.
Mik
Warning! May contain Nuts
plus springs, washers, screws, etc, etc.
Posted By: slaz
Date Posted: 28 April 2011 at 11:48pm
Best regards Johan
Just connect "remote" to "+" (or connect a switch across them) ... and you should be good to go ...
Posted By: Saturnus
Date Posted: 29 April 2011 at 7:31am
May I recommend that you connect them with a small fuse or a small resistor of 0R01-100ohm. Doesn't really matter what the value is as long as it's small, and you have it lying around.
Date Posted: 29 April 2011 at 4:55pm
Allright, thanks for the quick answers. Just what I needed to know.
Will look for a resistor or fuse if I have any, free.
One other question popped up; one of the amplifiers I've got is this one:
http://shop.conrad.nl/auto/multimedia/versterkers/eindversterkers/372807.html - http://shop.conrad.nl/auto/multimedia/versterkers/eindversterkers/372807.html  (it's a Dutch site but all  the technical specs known are there). It's a four channel, non-cooled amplfier.
Could I bridge two channels (left/right) without causing problems? I would use the bridged channel for bass, the other two channels for left and right top. The bass cabinet is 8 ohm (so are the tops).
Best regards Johan
