Advice on X10/12
Category: Plans
Forum Name: X10, X12, X15 and XM15
Forum Description: Discussion / Questions about the X10, X12, X15 and XM15
URL: https://forum.speakerplans.com/forum_posts.asp?TID=53945
Printed Date: 27 March 2026 at 7:15am
Topic: Advice on X10/12
Posted By: kingofska
Subject: Advice on X10/12
Date Posted: 28 June 2011 at 10:18am
Hi all !! i was thinking about building a pair of X10/X12 , their purpose will be to give me some some mid-high frequency i'm currently lacking in my barbecue - little free party sound system :D
currently i have a pair of scoop bin as subwoofer, a pair of horn-loaded mid-low unit , and we use monitor loudspeakers as high frequency unit CryAngryDead
i was thinking on this projects becuase when i will not need to much power, i will bring only these 2 x10 (or with a sub) , instead of going around with very big horn loaded loudspeaker in my little car :D
now my main question are:
1) is that really bad using a passive crossover ? i would like not to be bloated to carry around an external active crossover and to bring 2 amp (1 for mid-low, 1 for hf)
wouldn't this fit ?
KFPR 020
 400 Watt max | 8 V | 2 vie | 3,5 kHz
Impedance 4 + 8 V
RMS 200 W
MAX 400 W
X-over 3,5 kHz
Pad12 d
the only problem (if i understood correctly) would be the x-over point which is too high ..
2) are there any other design would you reccomend me ? the main characteristcs i need would be : internal x-over,  mid-high unit and portability
thanks in advance!!
Date Posted: 28 June 2011 at 10:33am
oh i was forgotting, i'm thinking about ciare / monacor components because a friend of mine is a releseller so i can get good prices, as long as i try to find speaker with similar small thiele parameters and power consumption of the one in the original design, they should fit well, right ?
