Missing pannel
Category: Plans
URL: https://forum.speakerplans.com/forum_posts.asp?TID=54291
Printed Date: 27 March 2026 at 8:53am
Topic: Missing pannel
Posted By: Audio Hallucinations
Subject: Missing pannel
Date Posted: 07 July 2011 at 5:09pm
Hi my mate has 2 1850s and i want to put 2 void v1000s in them for a party, however the 1850s are missing the pannel where the plate with the speakons go and im told that due to changes in the pressure this could damage my drivers. Obviously it also means that they wont funktion as well.
whats the truth in this?
also its only really for a one off occasion rather than regular use
Posted By: Adam_Iron_Horse
Date Posted: 07 July 2011 at 7:10pm
Don't think I really get what you mean...
How big is the missing panel?
Posted By: andycw
Date Posted: 07 July 2011 at 10:32pm
The back?!?
Posted By: Pirlo
Date Posted: 07 July 2011 at 11:15pm
I think he mean the "devider" of the speaker/rear-chamber to the unused space under it (top right on the plan).
Who the fu&k is Mr. Phanton, and why he has so much power!?
Date Posted: 08 July 2011 at 1:00pm
There not my 1850s mate, but i think he means theres a hole in the back where a pannel with speakons in goes
Posted By: mrchay
Date Posted: 08 July 2011 at 1:21pm
the hole needs to be blocked up completely, otherwise it will like a fat man taking a crap.
block up this and any other holes apart from the one you want the air to come out of. otherwise its like firing a musket with the breach open.
think about it simply: the speaker cone moves forward, pushing air into the horn. the air needs to go out the front of the horn mouth as god intended, not out of little holes. And it will go out of little holes if it can, and the result will be dreadful.
Posted By: hmaudio
do you mean the hatch? as in the peice of wood you remove to get to the driver like this..
Posted By: ermita
Date Posted: 08 July 2011 at 1:29pm
Got any pics.... If it is just a missing panel surely you can just measure it and get one cut out from your local hardware. By the way is the speakon terminal has been moveConfused
